Old 03-20-2014, 05:54 PM   #463
juliog
juliog's Avatar
Drives: 86
I want functionality, but also a relatively stock, or clean appearance.
Check out my clean "level 1" aero brah, APR lip and Voltex wing:
juliog is offline   Reply With Quote
The Following 2 Users Say Thank You to juliog For This Useful Post:
CSG Mike (03-20-2014), kavanagh (03-20-2014)
Old 03-20-2014, 05:56 PM   #464
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Trying to keep the car shiny side up this time?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 03-20-2014, 05:59 PM   #465
juliog
juliog's Avatar
Drives: 86
WSIR is cursed I tell you... in my first time back this year, I saw someone else flip a brand new FRS coming out of T2.
Old 03-20-2014, 06:26 PM   #466
smbstyle
smbstyle's Avatar
That is crazy; how did that one hold up? From all of the rollovers Ive seen of this car, the roof is pretty damn sturdy.
2013 SWP BRZ
Old 03-20-2014, 06:26 PM   #467
yohan04
yohan04's Avatar
Drives: Your sister
If I run 10mm spacers w/ extended studs, would I lose any steering feel? Not really concerned about the added stress on the wheel bearings.
yohan04 is offline   Reply With Quote
Old 03-20-2014, 06:28 PM   #468
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
The roof was indeed pretty damn sturdy...
ImperiousRex is offline   Reply With Quote
Old 03-20-2014, 06:31 PM   #469
juliog
juliog's Avatar
Drives: 86
Driver walked out uninjured, roof didn't collapse but car was in bad shape overall.
Old 03-20-2014, 09:56 PM   #470
CSG Mike
CSG Mike's Avatar
Nope. Your net wheel offfset may not change, depending on your wheel setup.
Old 03-20-2014, 10:07 PM   #471
THEmailman
Drives: Raven 6MT
Mike,
I have ~19,000 miles on the car right now and nine track days. I have two more weekends planned within the next month, two days each, so another four total days on track. One of the tracks will be about 1000 miles round trip and the other will be 400. I also have to drive back from my temporary duty station here in Oklahoma to my permanent one in NC in the middle of June, which is almost 1500 miles. In addition to all that, the FRS is my only car and it sees plenty of DD use, so I'm potentially looking at 25000+ miles on my car (and 13+ track days, with more to come) in about a year and a quarter of owning it. Is there anything I should be worried about as far as maintenance or look out for? I want to make sure the car is as track ready/capable as possible and I don't want to miss events because of something I should have checked/changed.
I'm starting to think about getting a truck to DD mainly and also tow the FRS to the track, just to spare it the miles and wear on parts (tires, fuel, oil, brakes, etc). I love this car and its a lot of fun but I know its not "the" car, and after another year or two I'll get out of it for something else so I'd like to save some of it's value (if that's even remotely possible at this point).
Thanks for your help.
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 03-20-2014, 10:10 PM   #472
kavanagh
Fat on Corn Syrup
That's sexy.
Old 03-20-2014, 10:19 PM   #473
CSG Mike
CSG Mike's Avatar
Originally Posted by THEmailman View Post
Mike,
Maintain like any other tracked car; just be vigilant on fluids, and inspect everything every 15k miles or so for leaks/cracks. Otherwise, you'll be fine.
Old 03-22-2014, 11:48 PM   #474
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Not sure if it was posted, but what do you recommend for tire pressure for track days? I was always told a general rule of thumb is max pressure of tire rating to allow sidewall stiffness. But that just seems excessive? My max tire rating is 50psi, so that seems like just too much. Obviously a good gauge and temp probe would help, but for a decent starting point, what should i be looking at?
What are some of you guys doing on here?
gdrider77 is offline   Reply With Quote
Old 03-23-2014, 01:31 AM   #475
CSG Mike
CSG Mike's Avatar
For street tires, 35-40 is a general guideline. What tire are you using?
Old 03-23-2014, 01:42 AM   #476
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by Mirko View Post
Question: I bought a new set of 17x9.0 rims for my car. Handling is very important to me as I will be tracking my car this summer. I found a good deal for Advans AD08 tyres, and I know (or at least, I think) the best tyre size would be 245/45/17... because of local laws I need to remain as close as possible to the original size. Would 225/45/17 be that bad for track use?
This is too big. 245/40/17 is nearly identical to stock size. 45 is too big.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
Mirko (03-23-2014)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
