#99 |
Drives: GBS Limited 6MT
I've updated the numbers but I noticed as I decrease the dampening the system seems to become more damped. Check out the difference in the step response when I change damping constant 'b' from 6000 to 25000. That can't be right?
#100 |
Drives: Subarus
Are you using the standard definition of MR or the "racing" definition. Racing definition is WMD or Wheel = MR*Damper
Damn, I was hoping to not have to review controls, but I will do so now... :[ |
#101 | |
Frosty Carrot
Drives: The Atomic Carrot
The way I've always heard is from the suspension design perspective: motion ratio = (distance from pivot to shock mount) / (distance from pivot to knuckle) OptimumG and others explain it from a vehicle dynamics perspective as: motion ratio = tire travel / shock travel Both versions make sense, but just a matter of convention. Which version do you plan to use?
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
#102 |
Drives: Subarus
I prefer tire/shock since that's just the way I've learned it. Plus WMD is easy to remember, weapons of mass displacement ;]
#103 |
That only has a minor effect on the spring rate, and is done before the rate is even put into the program (for now). The problem with the damping is larger than that, although this does remind me that I need to consider the motion ratio of the damper as well.
#104 |
Drives: 2019 Mazda Miata RF
Quick question, and I apologize if I missed it in the thread...also looked on the google doc spread sheet...
Does anyone know what the OEM scrub radius is? I'm looking at wheels, and want to discuss the possible offsets vs. scrub changes with my boss. |
#105 | |
Drives: asphalt FR-S
I used K=36998 N/m, sprung weight=244.5 kg, motion ratio=1.299. |
#106 | |
sorry, I'm a little late in the game here, but this is a really interesting thread |
#107 |
Drives: '13 BRZ Ltd
Springs, Swaybars, Wheel Rates and Frequency
I put together some calculations to give some context to spring rates, swaybar rates, wheel rates, and undamped frequencies.
Here are some assumptions I used for to calculate wheel rates due to springs and bars: Front Spring Motion Ratio 1.0 Front Spring Angle (based on nominal SAI) 15.5 degrees Front Bar Motion Ratio (same as Front Spring combined MR due to attachment to the strut): 0.964 Rear Spring Motion Ratio (measured) 0.78 Rear Bar Motion Ratio (measured) 0.59 Rear Spring Angle (still needs to be verified – I know it’s not perfectly vertical but it doesn’t look that large either; as long as it remains smallish it shouldn’t affect calcs much) 4 degrees BRZ Spring Rates (measured by Vorshlag http://www.vorshlag.com/forums/showp...16&postcount=5) 160 Front / 200 Rear lb/in FRS Spring Rates (measured by Vorshlag http://www.vorshlag.com/forums/showp...16&postcount=5) 125 Front / 220 Rear lb/in Front Swaybar Diameter 18 mm Rear Swaybar Diameter 14 mm Front Swaybar Spring rate (measured by Eibach http://www.phastekperformance.com/20...-sway-bars.htm) 141 lb/in Rear Swaybar Spring Rate (measured by Eibach http://www.phastekperformance.com/20...-sway-bars.htm) 113 lb/in To get wheel rates, I multiplied the rated spring rate by the square of the product of the Motion Ratio and Cosine of the Spring Angle. The calcs: Code:
Spring Spring Wheel Wheel
Rate Rate Rate Rate Front Rear
Front Rear Front Rear Dist Dist
Springs (lb/in) (lb/in) (lb/in) (lb/in) (%) (%)
OEM BRZ 160 200 149 121 0.55 0.45
OEM FRS 125 220 111 133 0.46 0.54
Code:
Bar Bar Bar Bar Wheel Wheel
Dia Rate Dia Rate Rate Rate Front Rear
Front Front Rear Rear Front Rear Dist Dist
Bars (in) (lb/in)(in) (lb/in)(lb/in) (lb/in) (%) (%)
OEM FRZ 18 141 14 113 262 79 0.77 0.23
The "Front Dist" and "Rear Dist" columns indicate how biased the total wheel rates (front + rear) are front to rear. This isn't that relevant without weights (and hence frequencies which I'll touch on below), but it's interesting to compare it to the 55/45 weight distribution of the car. I've seen with other cars how wheel rate front/rear bias closely matches the weight distribution of the car, which makes sense. Notice how much work the front bar is doing – it provides a lot more wheel rate than the springs do. So looking at the springs and bars combined in roll: Code:
Front Rear
Spring Spring
Front Rear Roll Roll
System WRf WRr WRtot Dist Dist Share Share
Config (lb/in)(lb/in) (lb/in) (%) (%) (%) (%)
OEM BRZ 410 200 610 0.67 0.33 0.36 0.61
OEM FRS 373 212 585 0.64 0.36 0.30 0.63
WRr = Wheel Rate Rear WRtot = WRf + WRr The BRZ is overall about 4% stiffer than the FRS, but it is also more front biased. What the “Roll Share” columns are calculating is how much of the wheel rates in roll are due to the springs and bars (i.e. for the BRZ, in the front, the springs are providing 36% of the roll resistance, while the bar is providing the remaining 64% of the roll resistance – so ~2/3 of the roll resistance is coming from the bar). For the rears the springs are doing more work than the bar. If you run the calculations for front and rear combined, the bars are providing 56% of the total roll resistance for the BRZ and 58% for the FRS. Adding a little more context, it's useful to calculate the undamped natural frequency of the suspension as a normalization to determine "how stiff" a car actually is. Calculating the NF takes into account spring rates and weights and results in a metric that can be compared across different cars. And in general, there are ranges of frequencies that are desirable based on what you want to do with the car (smooth ride, sporty street, low speed track, high speed track, etc). Assumptions: I started with the published curb weight of the BRZ Limited (2776 lbs), assumed a 55/45 weight distribution, 90 lbs front unsprung mass, 83 lbs rear unsprung mass, 60 lbs less over the rear axle due to lower fuel, and added 145 lbs to both axles for driver weight. Also assumed symmetrical left/right weights. This comes to corner weights of 707 lbs per front and 548 lbs per rear. Obviously more accurate numbers could be attained from corner weighting. The equation to calculate NF is 3.13*sqrt(kw/m), where kw is the corner wheel rate in lb/in, and m is the corner weight in lbs. Using these corner weights and the wheel rates above: Code:
System Front NF Rear NF Front NF Rear NF Config Ride Ride Roll Roll ------------------------------------------------ OEM BRZ 1.43 1.47 2.38 1.89 OEM FRS 1.24 1.54 2.27 1.95 The information isn’t that surprising – Ride NFs are right in line with sporty cars (similar to a stock 2008 STI), Roll NFs are also similar, although for the twins there is a lot less rear roll stiffness (mainly due to the disproportionately small bar). So knowing all the equations and motion ratios, it should be straightforward to calculate individual setups. E.g., adding only a Strano front bar to the mix (advertised as 85% stiffer than the stock front and common for stock class autocrossers) increases overall roll stiffness by 36% and biases the overall roll rate to 76% front (up from 67%). Another setup – the RCE T2s that come in 400/400 result in NFs of 2.27 Hz Front and 2.16 Hz rear. Check my numbers? |
| The Following 9 Users Say Thank You to Wepeel For This Useful Post: | autobrz (09-05-2013), Dimman (09-05-2013), fstlane (03-13-2014), MaximeT (02-08-2017), normancw (01-02-2014), Racecomp Engineering (09-24-2015), RJasonKlein (09-21-2015), Shankenstein (09-09-2013), solidONE (09-05-2013) |
#108 |
Frosty Carrot
Much appreciated guys!
I have updated the original post to reflect the corrected numbers and included Wepeel in my "Thanks" line. Excellent work, and it's obvious that you know ALOT about suspension design. Much appreciated Grodenglaive! The tire diameter in my wheel section does line up with your number. The natural frequency calculation was definitely off. Thanks! So the Strano sway bar may only add 36% stiffness and RCE definitely makes for a more harsh ride... but the suspension is no longer dominated by sway bar dynamics.
| The Following User Says Thank You to Shankenstein For This Useful Post: | Wepeel (10-01-2013) |
#109 | |
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Wepeel (10-01-2013) |
#110 |
Drives: 2008 Cayman S
Great looking thread, guys. Kudos to @Shankenstein for starting this and adding a lot of useful information.
I stumbled upon this while looking for a computational model of the BRZ suspension. I am a mathematician with a slight theoretical physics background and strong computer science skills. So not much engineering experience. Does anyone have suggestions on a resource for rapidly learning the ME side of a good suspension setup? Specifically what the ultimate, theoretical goals of an ideal setup are, and the fundamental theory that drives suspension design. Books, technical papers, online articles, forum posts, etc would all be appreciated. I would be happy to help out with this project once I get up to speed, looks like it's off to a great start! |
#111 |
Frosty Carrot
Quick update. Added the stock shock manufacturer and shock dyno data from RaceComp Engineering. It's old news, but I didn't read the "official" suspension/brake thread from here: LINK
| The Following User Says Thank You to Shankenstein For This Useful Post: | Racecomp Engineering (03-24-2014) |
#112 | |
i'm annoying...sorry!
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Shankenstein (03-24-2014) |
| New Rumor: Subaru Developing Turbo 4 2.0T for BRZ | Hachiroku | BRZ First-Gen (2012+) — General Topics | 350 | 02-02-2013 01:52 PM |
| Need opinions on two new items we're developing! | yospeed | Cosmetic Modification (Interior/Exterior/Lighting) | 56 | 12-03-2012 02:13 AM |
| Chances of Someone Developing 5x114.3 HUBS (not spacers)? | Entropy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-04-2012 03:35 PM |
| Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) | switchlanez | BRZ First-Gen (2012+) — General Topics | 68 | 02-14-2012 07:16 AM |
