Old 03-20-2014, 04:14 PM   #15
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by mokinbird87 View Post
I have a similar problem. For me it's the backrest. There is a slight play in my backrest and it squeaks back and forth I took it to the dealership and after about an hour the guy comes back sayin "sit in a brand new one and see if you can replicate it".
Surely enough the backrest on a brand new brz also had the exact same problem minus the squeak... I'm just gonna buy recaro seats in the future anyways but this rly pisses me off everytime I drive the car.
It's what makes a Subaru a Subaru.
Weird, my backrest is solid, try sitting in another "new" brz...
Deathalo is offline   Reply With Quote
Old 09-14-2014, 06:57 PM   #16
ZeHeadBanger
Stuck like Glue
ZeHeadBanger's Avatar
Drives: WRB BRZ Limited
I think I have the same noise. It sounds like its coming from the seat and it sounds like a squeaky spring mattress that has all rusted out springs.
The noise is probably coming from the seat belt clip rubbing against your seat. For me, the noise is present only when I'm on a bumpy road ( I live in Michigan, so that's every time). THe next time you hear the noise, try pushing the seat belt clip away from the body and the noise should go away. I'm still trying to find a solution to the problem. Maybe some kind of a cloth/layer between the seat belt clip and the seat?
ZeHeadBanger is offline   Reply With Quote
Old 09-14-2014, 07:27 PM   #17
JB86'd
JB86'd's Avatar
Drives: JAWS
I sprayed white lithium grease into the connections for the seat belt clip and my squeak went away.
JB86'd is offline   Reply With Quote
Old 12-22-2014, 04:49 PM   #18
tm86
Drives: 2013 Dark Grey 86B
I have the same problem and moving the seat belt clip seems to fix it temporarily. Did you find a better solution?
tm86 is offline   Reply With Quote
Old 01-24-2015, 09:39 AM   #19
ZeHeadBanger
Stuck like Glue
I took it to the dealer and they said they would replace the seat belt clip and that should solve the problem. They still haven't got the part yet and I'm waiting for their call - also, I'm out of town so it might be sometime before I get back and get this fixed.
Will keep you updated as and when I get it replaced.
Old 01-30-2015, 05:49 AM   #20
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
subd
"Careful though, I've seen many of my friends turn from ironic bros to full on bros by accident." - cfusionpm
bdanisi is offline   Reply With Quote
Squeaky clutch V1B Engine, Exhaust, Transmission 24 06-16-2016 04:48 AM
Squeaky Brakes? Jester Issues | Warranty | Recalls / TSB 24 06-26-2015 03:46 PM
FS: High End Panasonic EP30005KU Massage Chair fukamoto Miscellaneous 0 02-28-2014 05:44 PM
RED FR-S with DG Squeaky Clean Hamza7 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 02-01-2014 02:48 AM
Squeaky Panel?? Dispect Scion FR-S / Toyota 86 GT86 General Forum 25 01-08-2013 04:56 AM
