Old 03-20-2014, 12:15 PM   #645
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by AVOturboworld View Post
It's the fuel injectors and fuel pump that adds the most on the Stage 3.
You can get most of the Stage 3 by getting the Stage 2 Billet Turbo option, that will add on the 3" turbo discharge pipe, 3" crossover, and 3" front pipe and everything else from the Stage 3 except for the fuel pump, injectors, and 3" catback. The "Tuner" option, as you will, for $6600 with the catted front pipe, and $6395.00 without.
That sounds a lot more reasonable, thanks for that clarification
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
ZionsWrath (03-21-2014)
Old 03-20-2014, 12:22 PM   #646
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
So the injectors, pump and Catback amount to around $2400...
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 03-20-2014, 12:33 PM   #647
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
well, my boost solenoid, upgraded wastegate actuator, over pipe, flex fuel kit, fuel pump (thanks to @Sportsguy83 for the tips) are installed. just got my new base map from ptuning. hopefully this "snow storm" they are talking about early next week is a bust so i can drop the car off tuesday night and have it before the weekend. really interested in seeing how this kit does on e85 with a good dyno tune. only other one i know of made 350 at 15psi on the same dyno ptuning uses so im using that as a guide. i believe my car made more than his on 93 though so its up in the air at this point lol
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
Sportsguy83 (03-20-2014), ZionsWrath (03-21-2014)
Old 03-20-2014, 12:42 PM   #648
Sportsguy83
Drives: Limited BRZ
I made 335 @ 16 psi but it wasn't the best of tunes
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
sklimo (03-20-2014), ZionsWrath (03-21-2014)
Old 03-20-2014, 12:44 PM   #649
spitfire481
Drives: 2JZ FRS
didnt know you ever ran e85? im at 298 @ 10psi on pump. 350-360 would make me very happy. but i really dont know what to expect.
Old 03-20-2014, 12:45 PM   #650
Sportsguy83
Drives: Limited BRZ
Dyno chart is buried somewhere. 255 wtq. E85 of course.
It was fun.
Old 03-20-2014, 12:50 PM   #651
spitfire481
Drives: 2JZ FRS
It was fun.
nice, i always thought you were only on 93. we love e85 around here. everyone runs it with great results. with such high compression i am really looking forward to it in this car. mostly for cooling purposes. the power/higher boost is just a bonus for those heavy right foot moments
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 03-20-2014, 12:54 PM   #652
Sportsguy83
Drives: Limited BRZ
It is an entire different ballgame. You won't believe the things your car can do once tuned with the corn. I am starting corn tune in my new kit, and even in the same boost level, just adding corn and 3 degrees of timing, the difference is ridiculous.
Old 03-20-2014, 01:00 PM   #653
spitfire481
Drives: 2JZ FRS
we run e85 on a vw drag car that we built. made 650-700 on a stock 12v vr6 engine (with bigger cams) for 2 race seasons before it let go. on 93 that would have let go in probably half a season, if that long. now that car has rods/pistons on corn and has been 9.07@164 lol. should be into the 8's this season with a new turbo manifold. been running a base kit cast manifold for years. it was time to step up
Old 03-21-2014, 05:25 AM   #654
ZionsWrath
Thanks
ZionsWrath's Avatar
Anyone AVO with a resonated 2.5" header back?
Old 03-21-2014, 08:13 AM   #655
spitfire481
Drives: 2JZ FRS
I used to have the base kit with stock over pipe/front pipe and a resonated 2.5" Perrin. Sounded like a stock car. I traded for a non resonated and installed a catless front pipe. It's still a quiet car in my opinion. I can roll next to police and not have any cares about getting pulled over for noise
Old 03-21-2014, 09:02 AM   #656
ZionsWrath
Thanks
ZionsWrath's Avatar
Yea that is why I am asking, I am thinking about my exhaust setup. Honestly I'd like to go 2.5" catless resonated with stock muffler so it looks stock and is quiet.
Old 03-21-2014, 09:25 AM   #657
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
I have a Stage 1 kit with an Invidia catles front pipe and stock catback. Very quiet. The only giveaway is the inter cooler.
andrewFT86 is offline   Reply With Quote
Old 03-22-2014, 12:24 AM   #658
MFB
Avo Turboworld Phil Rep
Drives: Forester 2009 XT on e85
Hi Doc,
From the front, the intercooler is barely seen as well due it being stealth black. You really have to look inside to see the fmic. :-)
MFB is offline   Reply With Quote
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
