Old 03-20-2014, 12:21 AM   #15
orthojoe
Originally Posted by leicaboss View Post
Sorry for going a bit off topic (but the rest of the thread is super helpful, as I practically had the same questions). But how exactly were you able to get two cameras synced + the data shown like that? It's such an amazing video - and great lap! The data you can keep track of is amazing, with throttle input, G's and even location on the track... super jealous!
I've been trying to figure out a setup before going to track and don't know which options are any good. Already have a smartphone + GoPro Hero 3+ BE...
David
Thanks. BTW, just fyi, I'm not braking mid corner as the telemetry is showing. I didn't bother turning off traction control completely and VSC sport was ON, so the system logs VSC intervention, which is why it looks like I'm tapping the brakes mid corner. Don't do that. LOL.
The setup I'm using consists of gopro cameras linked via wifi remote. Data is collected using the AiM solo DL. Data and video are merged with trackvision software, and multiple views are processed with adobe premiere elements. You have to be a video geek like me to want to bother with all of it.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
The Following 2 Users Say Thank You to orthojoe For This Useful Post:
leicaboss (03-20-2014), Wepeel (03-20-2014)
Old 03-20-2014, 12:47 AM   #16
im2lazy789
Drives: BRZ Limited DGM
How do the stock Primacy tires hold up durability and temperature wise on the track? My experience last summer in my Mustang GT was that the stock tires, granted they were Pirelli P-Zero Nero "ultra high performance all seasons" just shredded and overheated. Right now I am leaning towards going to a dedicated wheel and tire combo (RPF1s and ZII's) for the track and autocross pretty much just for wear and brake dust reasons, although a more progressive breakaway would be a big plus to train on as well.
im2lazy789 is offline   Reply With Quote
Old 03-20-2014, 01:21 AM   #17
orthojoe
The outer shoulders of the OEM primacy's will chunk off. Adding more negative camber will help, but the shoulders still get demolished. I haven't had issues with the tires overheating, but I try to to drive very smoothly and don't overdrive the tires since that's the faster way around a course. I can tell you that I lost about .1G of performance during a 106F ambient temp track day on the OEM tires. My understanding is that the performance of the OEM primacy's will drop of significantly after a set number of heat cycles. The tire will heat cycle out way before the tread wears out. I never got a chance to test that because I blew one of my tires on a curb and then switched all 4 to MPSS afterwards.
2013 Subaru BRZ
im2lazy789 (03-20-2014), zdr93523 (05-12-2014)
Old 03-20-2014, 01:24 AM   #18
Porsche
Drives: 2013 BRZ Ltd. MT
Originally Posted by jsimon7777 View Post
I find the G's claim hard to believe.
Understandable, but...
When @orthojoe talks ... I listen.
Porsche is offline   Reply With Quote
The Following 3 Users Say Thank You to Porsche For This Useful Post:
im2lazy789 (03-20-2014), orthojoe (03-20-2014), zdr93523 (05-12-2014)
Old 03-20-2014, 01:57 AM   #19
orthojoe
LMAO. I'm honored and flattered.
Hey, I'm with all of you. I was expecting a lot more out of the MPSS myself and was just as surprised as all of you. Data doesn't lie, though.
If you want a big change in grip, bump up to RS3 or BFG rivals.
2013 Subaru BRZ
Ganthrithor (03-20-2014), Porsche (03-20-2014)
Old 03-20-2014, 02:21 AM   #20
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
lol.
I don't know what tire quality this is called, but the car sticks through bumps better now. Certain bumps would send the tail out. Now it sticks. Definitely the superior road tire. If I run out of stock tire on the track, I'll be able to AB them.
Old 03-20-2014, 02:50 AM   #21
im2lazy789
lol.
If I were to wager a guess, the MPSSs probably have better cold grip cold adhesion properties due to compound then the PHPs. My impression from the PHPs is that when cold they are pretty much rock hard with little grip, however, I do not have much experience with them at very hot temperatures, just whatever I can get them up to on a hot July day blasting through some canyons repeatedly. Nor do I have any experience with the MPSSs. So perhaps at track temperature the PHPs may come into their own and exhibit similar sustained load capabilities to the MPSSs at temperature.
TL/DR: MPSSs may work over a wider range of temps than PHPs
The Following User Says Thank You to im2lazy789 For This Useful Post:
Old 03-20-2014, 02:54 AM   #22
im2lazy789
Thanks orthojoe, depending on my pocketbook by the start of Summer I will probably get a dedicated set of wheels and tires for the track and keep the PHPs for putting on mileage on the street and avoid the shoulder chunking. Will order some crash bolts as well. Now off to read everyone's thoughts on camber setting.
Old 03-20-2014, 09:45 AM   #23
Porsche
Old 03-20-2014, 10:06 AM   #24
Wepeel
Drives: '13 BRZ Ltd
Which ones were faster on and/or did one show more grip than the other? And what is the rest of your setup?
Wepeel is offline   Reply With Quote
Old 03-20-2014, 11:09 AM   #25
orthojoe
I can't tell you which one is faster. I only have data on the BFG rivals because my friend runs them. I am just assuming the RS3 is equivalent to the BFG. No hard data to support.
My setup:
whiteline front camber bolts maxxed out to -1.5
Project mu club racer brake pads for the track
MPSS tire (OEM size on OEM wheels)
That's it.
2013 Subaru BRZ
The Following User Says Thank You to orthojoe For This Useful Post:
Wepeel (03-20-2014)
Old 03-20-2014, 09:52 PM   #26
icemang17
Drives: Scion FR-S/ Subaru BRZ
Simon
Okay....you are much like I was many years ago...I was a "data" guy...this test says this tire does XYZ....but this other tires does the same -.05%....so clearly the 1st tire is better.....
The real world is MUCH different.... As I always say....any type of driving on track is EXPENSIVE....so why not wear out the perfectly good tires that came on the car....I PREACH to mod as little as you can.....there is no sense in making the car much faster than you can handle as a driver....that is the path you are heading down....how do I know...BEEN THERE DONE THAT...and lost thousands $$$
I understand this is what you don't want to hear....its not cool or fun.... But I will ask this of you....I am running Ft86 cup at Thunderhill in a 100% bone stock car....nothing has been changed....lets see where a bone stock FRS times end up overall.....I don't expect to be FTD (fast time of day)...not even close...but I think my bone stock time will be pretty respectable....
icemang17 is offline   Reply With Quote
How to warranty your stock tires and save money on Pilot Super Sports SpeedR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 81 03-31-2016 10:48 PM
Michelin Pilot Super sport vs hankook vs nitto ft86me Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 03-21-2015 05:43 PM
Michelin Pilot Super Sport 225/40/18 FastLane1000 Wheels and Tires 2 09-03-2013 01:04 PM
Michelin Pilot Super Sport - 245/35ZR18 Staf00 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 08-30-2013 07:13 PM
Michelin Pilot Super Sport 17 inch DieselBoXXer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-05-2012 11:17 PM
