Old 03-18-2014, 10:24 PM   #463
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Originally Posted by transition View Post
Well it would sure be a coincidence that the person emailing them is posting the same exact photos right?
No because didnt get your photos. Thats why I asked if you could send them again.
JDLAutoDesign is offline   Reply With Quote
Old 03-18-2014, 10:33 PM   #464
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
I don't smoke weed.... but this guy could totally use a joint.
It's just a car and some parts.
Shit happens sometimes... and it sounds like JDL will do what's needed to handle it.
uspspro is offline   Reply With Quote
Old 03-18-2014, 10:40 PM   #465
transition
Jesse has privately messaged me and i'm done discussing the issue as i've shared my $0.02 with him. Anything that can be said has been. Have a nice jay.
transition is offline   Reply With Quote
Old 03-18-2014, 11:02 PM   #466
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
What's wrong here? I don't see anything wrong with these pics.
No, I'm not trying to troll, I just don't what the problem is.
Old 03-18-2014, 11:09 PM   #467
transition
Where all the collectors merge into a point you'll see separation between them. I've been told this is normal and nothing to be worried about but i've never seen it from all the posts i've seen. Just sharing the photo since i've never seen something like this discussed here.
Old 03-18-2014, 11:12 PM   #468
Captain Snooze
Drives: Red Herring
Let me find the post that has mentioned this before. It may take me a while.
Old 03-18-2014, 11:18 PM   #469
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
I'll post some pictures tomorrow of how the collectors are welded. With the metal only being 16g steel they are only welded on the outside and then a plate we have cut is welded in the center. Sometimes after welding the runners to the collector it causes a slight separation like seen above. If we ground the metal down anymore it would become too thin and weak and more than likely once ran and heat up a few time the metal will move back into place. Thin wall stainless like this will expand and contract quite a bit with heat cycles.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 03-18-2014, 11:19 PM   #470
Lee@JDLAutoDesign
Lee@JDLAutoDesign's Avatar
Drives: Corrado
The collectors are all hand cut, fit up, welded (on the exterior of the pipe) and then hand ported. The separation you are seeing between pieces is just normal tolerance stack up from the manual nature of the assembly process.
There are absolutely no durability or performance issues with the end result. Please let me know if I need to elaborate on any of these points.
edit - Jesse beat me to it...
Lee@JDLAutoDesign is offline   Reply With Quote
Old 03-18-2014, 11:32 PM   #471
Captain Snooze
Drives: Red Herring
PROVISO:I am not arguing the issue you have had with JDL.
In my mind the collector shown displays high workmanship/quality. Collectors are welded from the outside so the inside is has to match up from the way the tube is cut.
Originally Posted by Hawk77FT View Post
Not even a fan of JDL but have a look at this but this alone makes me reconsider. Look at BORLA fnish and look at JDL. Which one has a better finish? Second, third batch who gives a rats a$$. MJ Fox has shaky hands due to his Parkinson illness hence the joke of the shaky/all over the place welds of the Borla collector.
This is a bad collector from Borla:
Old 03-18-2014, 11:37 PM   #472
transition
PROVISO:
Ah yea. That's like 4 pipes that happen to sort of end up in the same location. Also known as cheap labor and zero quality control.
Old 03-19-2014, 12:01 PM   #473
cfordart
cfordart's Avatar
Drives: 2014 FR-S
Talking header installed - awesome sound!
So, I got my JDL UEL header, overpipe and catted front pipe installed. Put a bung after the cat in the front pipe and with a 36" extension moved the secondary O2 sensor back there. No CEL! Hooray!
Along with the above I have the stock midpipe/resonator and the quad-tip TRD exhaust...and I have to say the sound is exactly what I wanted. Awesome. Deep rumble, UEL burble (is that a word? lol). Almost weirdly quiet at idle, but QUICKLY wakes up with applied throttle. Sounds good sitting still and revving, but really shows its stuff when driving. With absolutely NO DRONE!
Pulls stronger now from 4 grand on up, but still has a bit of a bog in the midrange, like it had when stock. Will work on that with a tune, hopefully. If I was more savvy I'd try to upload some sound, ain't happening yet. Maybe I can get some of these crazy kids and their phones to help me with it. lol
Was a bit self conscious about the volume on the first day or so, but now I think its just right. Nothing's changed except my perception of what it is and what it should be. And it's not loud at all if you stay out of it, it won't be a cop-magnet. I've now adjusted my driving habits and drive a little more by ear rather than driving by butt-feel. But OMG! this thing is obnoxious in the first 15 seconds or so when starting cold and that valve overlap is going on! Have to close my garage door when first starting every morning because the back of my car faces my neighbor's bedroom. Don't need pissed-off neighbors. lol
Thanks JDL for a quality product. My shop had a few issues with some leaks when first tightening everything up, but nothing a little fiddling with couldn't fix. And I think any header is going to have to be juggled a little to make them fit right. Just the nature of the beast.
Now that I'm comfortable with these and that I'm not getting any CELs, I'll explore a tune. Open Flash Tablet seems to be a good inexpensive (relatively) option for that, to me anyway, although I'm open to suggestons. What I want is something that won't break the bank, is reversible, and would be easy for me to manage. Is there any certain "tune" through OFT that would suit my set-up? This car will not see any track, just a daily driver that I want to look and sound good, and to give some good performance when I want it to, and to be dependable.
Thanks!
cfordart is offline   Reply With Quote
Old 03-19-2014, 02:49 PM   #474
SpatulaCS
SpatulaCS's Avatar
Drives: 2013 Scion FR-S Ultramarine
Thanks!
I'm running the stage 2 UEL tune from the OFT with these headers and it's great. Relatively cheap and easy to flash and the car really responds well to it. Torque dip is basically nonexistent and the car pulls harder and stronger all the way to the redline. I also don't track mine and just do some spirited daily driving so I'm sure this tune will work well for you too.
SpatulaCS is offline   Reply With Quote
Old 03-19-2014, 02:51 PM   #475
nelsmar
Thanks!
What intake do you have?
My flickr - Canibeat
Local magazine scout
Old 03-19-2014, 05:28 PM   #476
cfordart
cfordart's Avatar
Drives: 2014 FR-S
Sorry, forgot to mention it. I've got the TRD intake.
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 10:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 12:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 07:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 08:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 09:05 PM
