Old 03-18-2014, 05:40 PM   #15
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I couldn't get the oil much past 230F or so on track with the oil cooler, and this is at a fairly quick pace.
We were at 245whp from a 172whp baseline with JUST the kit on and no oil cooler, and no other modifications. The 245whp wasn't a hero run. Rather, it was fully heat soaked, and what you'd see in a real world condition. The car does make more power with an oil cooler, since the tune will compensate for the lower oil temperatures.
Did you get another dyno run after adding the oil cooler or it was a different car? I wonder how it does with OEM exhaust without the heat soak issues
glamcem is offline   Reply With Quote
Old 03-18-2014, 06:47 PM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I have.
Oil temps will universally be higher on a turbo car that has an oil cooled turbo. You'll need a cooler that can keep up. Under hood temps will be higher with the turbo car, even with a vented hood.
IAT will vary, but assuming a similar level of boost the Turbo car (with base AVO turbo) will have a higher IAT as well. With similar boost, the AVO car will have a small AUC advantage, but that AUC advantage is not sustainable. At heat-soak equilibrium conditions, the JR kit will make similar AUC.
With a turbo car you add power with a bigger turbo (diminished transient response), or more boost (higher IAT); your cats are probably deleted to begin with. With a SC car, you can add power with more boost (higher IAT), or increasing VE (deleting cats, same boost).
Do you have specific questions?
Directly related to the setup being discussed do you have thoughts and/or data on the Forestor DIT oil cooler (Cusco style essentially) vs. Other air cooled like Perrin or JR?
I am NA now and am looking to address cooling this year with a Koyo rad and forestor oil cooler I have an AT also that gets cooled via the rad as well. May or may not end up with a seperate tranny cooler as there isnt much data yet. I may go SC in a few years and would like to not buy something twice.
Sent from my LT30at using Tapatalk
Old 03-18-2014, 07:56 PM   #17
CSG Mike
CSG Mike's Avatar
Hard data? No. Anecdotal evidence? Yes. Thoughts? Yes.
Quite simply, the Forester oil cooler will not be enough. It's one of the first items swapped out for an oil-air cooler on WRX/STIs that are driven hard.
Old 03-19-2014, 02:06 AM   #18
sw20kosh
Drives: 2013 Black FR-S
Thoughts on the Robispec oil-water cooler / radiator combo?
Old 03-19-2014, 02:32 AM   #19
FAER
Drives: Silver BRZ
i really want this radiator but i've heard some bad things about her.
FAER is offline   Reply With Quote
Old 03-19-2014, 12:44 PM   #20
sw20kosh
Like she is too big? What else?
Old 03-19-2014, 12:52 PM   #21
FAER
Drives: Silver BRZ
Like if you make a date with her to do a little under the hood work she doesn't show up for sometimes months...
Old 03-19-2014, 01:17 PM   #22
CSG Mike
CSG Mike's Avatar
It works?
We went a different route with our car, but the main thing is to keep the car cool. Nobody knows the limit of the Robispec cooler because it's never been pushed hard enough. :shrug:
Old 03-19-2014, 01:48 PM   #23
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I was lucky and recieved mine very FAST, but have heard and read a few horror stories of 5+ months after paid full....
Old 03-19-2014, 02:02 PM   #24
FAER
Drives: Silver BRZ
how do you like it?
this is what i'm considering going with
Old 03-19-2014, 02:05 PM   #25
Sportsguy83
Drives: Limited BRZ
how do you like it?
The fitment was TIGHT, needed to hack a little here and there, but the end result is just incredible.
There is nothing I can throw at it to make it get hot... Back to back to back pulls, back to back to back 1/4 runs, I haven't tracked it in a road course, yes, but I've done about everything but... 5 back to back to back dyno pulls, 35 in 3 hours, nothing gets it uncomfortable.
Old 03-19-2014, 03:58 PM   #26
sw20kosh
It works?
Robi never pushed it?!
Old 03-19-2014, 04:00 PM   #27
CSG Mike
CSG Mike's Avatar
He never made enough power to really push it. He also ran E85, which has some insane cooling properties...
Old 03-19-2014, 04:33 PM   #28
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Interested to hear more from folks who've tracked these cars with FI.
What kit setups, what supporting mods (particularly cooling), what power levels?
So far the CSG Rotrex car seems to be good on track running the base tune. Any turbo kits proven to be reliable as well?
The AVO kit looks solid for a good price but i'd like to see some real world examples. The Ptuning kit looks interesting as well due to the low mount turbo set up. Imperious Rex's Greddy turbo car seems to run well too.
Any verdict between front/top mounted turbos versus low mounted ones?
I'd really like a 'set it and forget it' type solution...something that's reasonably easy to set up and won't blow up in my face assuming routine maintenance.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Transient ignition and knock count brn12345 Software Tuning 19 06-10-2014 11:46 PM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
Avo turbo heat management on track ICantAffordAnLFA Forced Induction 18 09-09-2013 11:00 AM
MP3 management software for PC? mit_peid Electronics | Audio | NAV | Infotainment 9 06-08-2013 08:14 AM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 05:57 PM
