Old 03-17-2014, 04:28 PM   #71
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Originally Posted by BaeK View Post
April, 2013 for mine.
hm okay. Mine is june I believe. why can't we find any correlation besides just adjusting the clutch pedal?
86-tundra is offline   Reply With Quote
Old 03-17-2014, 06:17 PM   #72
JB86'd
JB86'd's Avatar
Drives: JAWS
Have you tried taking it to the dealership? I know @trevorovert and I have taken the car to the dealership without any results, but it doesn't hurt to try.
Also, could you record a short clip of the problem you are having?
Mine is August 2013. More than likely that adjustment was the cause of mine, it started shortly after. You both make a good point on taking it to the dealer. I'll post a video this weekend and see what you all think.
JB86'd is offline   Reply With Quote
Old 03-18-2014, 08:43 AM   #73
BaeK
BaeK's Avatar
Drives: 2013 Whiteout FRS
Maybe it was the same lady that torqued down the bolt.
Sounds good man. I'm curious how your noise sounds like.
retrofit
BaeK is offline   Reply With Quote
The Following User Says Thank You to BaeK For This Useful Post:
86-tundra (03-18-2014)
Old 03-19-2014, 12:11 AM   #74
BaeK
BaeK's Avatar
@trevorovert and @JB86'd
I think I found the real solution!!!!
So my sound came back earlier today when driving and I was planning on loosening the bolt a bit more tonight. However when I was showering, I had this idea of tightening the bolt down really hard while pressing down on the clutch. (I just couldnt understand why loosening the bolt made the sound/feel more subtle, but didn't make it go away)
So I removed the nylon washer and made the bolt as tight as I can while pressing down on the clutch all the way (with my right hand). Once I tightened down the bolt as much as I can, i took my hand off the clutch and used both hands to tighten it more until I felt that it was super tight.
I just took a 5-10 minute drive (yes, at 12 am) and I'm super excited to say that I didn't hear nor felt the popping noise at all!! I pressed down on the clutch at least 30 times without a hint of the popping sound and feel.
I will post more results tmrw morning after my drive to work! Fingers crossed!
retrofit
unsurety (04-02-2014)
Old 03-19-2014, 12:27 AM   #75
86-tundra
Troll Hunter
86-tundra's Avatar
ahhhhh this definitely makes sense.. time to stumble out to my car. (at 11:30 pm )
The Following User Says Thank You to 86-tundra For This Useful Post:
BaeK (03-19-2014)
Old 03-19-2014, 12:44 AM   #76
86-tundra
Troll Hunter
86-tundra's Avatar
Didn't work for me.pretty hard to do both at the same time, so if it comes back, I will try it again. But that click/pop definitely has something to do with that bolt.
Old 03-19-2014, 01:51 AM   #77
JB86'd
JB86'd's Avatar
Drives: JAWS
@BaeK hmm that's strange. I'll give that a shot before doing any further troubleshooting this weekend. Hopefully that fixes it for you!
Old 03-19-2014, 08:28 AM   #78
BaeK
BaeK's Avatar
Did you remove the nylon washer before tightening the bolt?
I hit a massive stop-and-go traffic on my way to work this morning, which lasted for about 30 minutes, and I didn't get a single click.
I was thinking... maybe it's the thin plate of metal (where the bolt head touches) is rubbing against the threads of the bolt when the clutch is engaged. Last night I tried engaging the clutch with the bolt removed, and there was too much play on the thin plate itself.
(pic stolen from you Trevorovert)
Alrighty, let me know if this works for you.
retrofit
Old 03-19-2014, 08:59 AM   #79
Rod117
Rod117's Avatar
Drives: 2014 Scion FR-S Firestorm
Wow you guys are a knowledge bank! I had just started hearing this noise of the clutch this morning when I pushed the clutch in to turn the car on. I thought, "Hmmm, that doesn't sound too good...hope it wasn't something I did." I'll give this Nylon washer fix a try later today and report back. I think I'll also try to press the clutch in at the same time. Can't hurt to try both methods to quiet down the "clicky" clutch.
Rod117 is offline   Reply With Quote
Old 03-19-2014, 09:52 AM   #80
86-tundra
Troll Hunter
86-tundra's Avatar
Definitely play with how tight the bolt is. I loosened mine up pretty good last night and haven't heard a click sense. There is a tiny bit of play now, but it doesn't bother me.
Old 03-19-2014, 09:54 AM   #81
86-tundra
Troll Hunter
86-tundra's Avatar
I did remove the nylon washer first. And I think you're right. This would explain why your fix would have worked. Same here, with the bolt removed, that plate moves around a lot. Maybe I just need some more torque to get it to work. It was a bit hard to get a solid grip on the wrench while pushing the clutch in
Old 03-19-2014, 10:10 AM   #82
BaeK
BaeK's Avatar
Yeah, I used a torque ratchet with an extension to tighten mine. If you can have someone help you press down on the clutch while tightening the bolt, it should be pretty easy.
Try that out sometime today and let me know how it goes.
retrofit
Old 03-21-2014, 09:23 AM   #83
wheelhaus
wheelhaus's Avatar
I don't have this problem fortunately, but I'm confused by the diagnosis. I don't understand how the hell that bolt clicks when it's tight, but not when it's loose. Sounds so backwards. How can something make noise when it can't move? Are you guys certain it's the bolt that's making this noise and not another part of the assembly nearby?
Old 03-21-2014, 09:34 AM   #84
BaeK
BaeK's Avatar
In my case, the clicking sound/feel was subdued with the nylon washer + loose bolt method. If my theory is correct (that the thin metal plate rubbing against the thread of the bolt produces the noise), it would make sense that the clicking noise is a lot louder when the bolt is tight, but not "tight enough".
It's been 2 days since I went the opposite route, over-torquing the bolt instead of using the nylon washer + loose bolt method, and I can confirm that I've had 0 clicking noise/feel when engaging the clutch pedal.
retrofit
Clutch pedal springy sound pdreams Issues | Warranty | Recalls / TSB 16 06-01-2015 02:33 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
Clutch Pedal Noise Help!! ZackZ Scion FR-S / Toyota 86 GT86 General Forum 6 09-06-2013 05:35 PM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 09:52 AM
Popping/Clicking Dead Pedal BRaZinDave BRZ First-Gen (2012+) — General Topics 6 12-08-2012 04:14 AM
