Old 03-18-2014, 10:30 PM   #3879
Sonolin
Hmm stock catback seems to be the way to go for quietness. Wow, just realized that's with header as well. Awesome stuff.
Did nameless scrape the idea of making this with a cat? I didn't see the option on their website...
Sonolin is offline   Reply With Quote
Old 03-18-2014, 10:45 PM   #3880
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Quite a few pages back.
Originally Posted by Ryan@Nameless View Post
A cat would defeat the purpose of that collector and interrupt the flow characteristics that we found with this iteration of the header.
There may be a catted version in the future, but as of now there is not a specific timeline available for that.
-Ryan @ Nameless
Dustin is offline   Reply With Quote
Old 03-18-2014, 10:46 PM   #3881
Sonolin
WTF I thought they were trying to go for STX legal?
Strange, but for most performance no cat is obviously better.
Old 03-18-2014, 11:11 PM   #3882
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Their "workaround" is for you to leave a cat in your frontpipe.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 03-18-2014, 11:15 PM   #3883
Sonolin
OK well I guess that works. I'd just also like a cat for noise levels.
Loving this headers sound so far though, full exhaust seems to sound better to me than most UEL + full exhaust, at the top end. I guess I like the EL sound better & the fact its a better design.
Anybody with full exhaust 2.5" ? How loud is it?
Old 03-19-2014, 12:11 AM   #3884
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Just get a catted front pipe or keep the stock front pipe. The gains from removing the header cat are significantly greater than from removing the second cat.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-19-2014, 12:58 AM   #3885
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I'm running the stock cbe.... Might run something at a later date. Definitely quiet at cruise and loud on cold start and semi loud above 4k under load.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 03-19-2014, 11:13 AM   #3886
Sargy
Long Distance Driver
Sargy's Avatar
Any more coated pics from anybody?
Sargy is offline   Reply With Quote
Old 03-19-2014, 12:14 PM   #3887
mad_sb
Drives: 2013 Asphalt FR-S
I got a couple yesterday, but im at work. Will post latter. Just picture the uncoated one painted flat black... that's what it looks like
The Following User Says Thank You to mad_sb For This Useful Post:
Sargy (03-19-2014)
Old 03-19-2014, 01:33 PM   #3888
Dustin
Twin Screw You
Dustin's Avatar
@14BRZ I'll retract what I said before about no rattle. This morning, there was a small rattle on intitial startup, but after a few seconds it went away.
Old 03-19-2014, 01:48 PM   #3889
wparsons
wparsons's Avatar
Originally Posted by w00t692 View Post
No, merely that the harmonics associated are COMPLETELY different than the ones in an intake manifold that shift power around.
You can design a header to make power anywhere and lose power anywhere, but that does NOT mean the power was shifted, merely lost.
Whereas a differently designed intake manifold will literally make an identical torque graph 5-1000 rpms shifted to the "right", a header will instead just lose VE in one spot to gain it in another.
Also, don't put words in my mouth, it happens very often on here.
I'm failing to see a difference in the two, except in how you're describing them.
Tuning runner length/diameter on an intake manifold to shift power does the exact same thing as tuning primary/secondary length/diameter on a header.
You optimize them so the harmonics work in your favour at the RPM range you want.
flickr
Dimman (03-19-2014)
Old 03-19-2014, 05:59 PM   #3890
Gshoxx
Drives: 07 AcuraTL-s,2013 ScionFRS hotlava
Still no consumer dyno upto now?
Gshoxx is offline   Reply With Quote
Old 03-19-2014, 06:34 PM   #3891
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
I'll have a dyno Friday with a JDL EL comparison from another day.
RiskyTrousers is offline   Reply With Quote
The Following 4 Users Say Thank You to RiskyTrousers For This Useful Post:
coolaron (03-19-2014), FrsDuke (03-19-2014), Gshoxx (03-21-2014), JB86'd (03-19-2014)
Old 03-19-2014, 10:51 PM   #3892
Deathreaper
Drives: 2013 Scion FRS
Just received the coated version, they are black / dark grey. Build quality is exceptional as per usual for Nameless. I will post some photos sometime tomorrow.
For those who installed the header, would you mind going through what would be the easiest process? I assume you would:
-Completely remove O2 sensors from OEM header (disconnect the entire wires)
-Remove OEM header
-Clean up area and contact points + install new gaskets (Look here for part # http://www.villagescionparts.com/sho...sembly=1103630)
-Install O2 sensors back into Nameless header (Should spacers be added or is there no point?)
-Lift engine 1-2 inches via oil pan (unbolt passenger side mount)
-Bolt Nameless header onto engine block (Anyone have the torque specs? Has anyone been able to use a torque wrench for those or is space too limited?)
-Use the 2 provided nut and bolts to attach header to front pipe
-Relocate fan connector with provided ziptie
Also - I usually grease most bolts and nuts I remove on a car before putting them back. I know it's not the same situation as an exhaust gets extremely hot, but would you guys apply a graphite grease or something similar to these various bolts and nuts?
Thanks!
Deathreaper is offline   Reply With Quote
The Following User Says Thank You to Deathreaper For This Useful Post:
Sargy (03-20-2014)
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
