Old 03-18-2014, 08:44 PM   #1
BIL90
BIL90's Avatar
Third brake light causing rattle
Just installed a subwoofer and the rear windshield significantly rattles now during some notes of bass. I started to track down what exactly was causing it and found it was due to the third brake light rattling against the window. Does anyone know how to lower the third brake light, even the slightest bit? I pressed down on it with my hand and the rattle immediately disappeared.
BIL90 is offline   Reply With Quote
Old 03-18-2014, 08:46 PM   #2
Drive
Crickets...
Drive's Avatar
Drives: FR-S 10 Series
I have the same issue.
Smile on every turn.
Drive is offline   Reply With Quote
Old 03-18-2014, 08:52 PM   #3
BIL90
BIL90's Avatar
Do u just deal with it? If I can't find a way to lower it, I may try and squeeze a small rubber strip between the two. Hopefully that might work. It's driving me nuts!
Old 03-18-2014, 09:06 PM   #4
dnieves
How about double sided foam tape? It'll stay put and cushion at the same time!
dnieves is offline   Reply With Quote
Old 03-18-2014, 09:42 PM   #5
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Mine had this issue after getting a sub. I tried to wedge some rubber stoppers between the 3rd brake light and back windshield. It fixed the problem, but then one day I saw my 3rd brake light had warped under the pressure from the rubber stoppers. I removed the rubber stoppers and also found out that they had partially melted to the rear windshield...
I ended up pressing the 3rd brake light enclosure back together and then just dealing with the rattle. I've been wanting to get like Dynamat or something similar, but I just haven't had the time.
ericmpena is offline   Reply With Quote
Old 03-18-2014, 09:51 PM   #6
buzznasa
LOL PWR
buzznasa's Avatar
Drives: Whiteout FR-S; Scion tC
That is similar to what I used. Build thread here. Some door trim insulation around the third light and it has been silent ever since and my sub shakes the whole car.
It's not a midlife crisis if you never grow up.
buzznasa is offline   Reply With Quote
Old 03-18-2014, 10:34 PM   #7
BIL90
BIL90's Avatar
Thanks for the idea! Where did u pick up the insulation from?
Old 03-19-2014, 12:12 AM   #8
buzznasa
LOL PWR
buzznasa's Avatar
Home Depot... $3
Not that I am a cheap bastard but I like to save money when I can
*edit* My wife wants me to clarify that I am indeed a cheap bastard
The Following User Says Thank You to buzznasa For This Useful Post:
husker741 (03-19-2014)
Old 03-19-2014, 12:15 AM   #9
BIL90
BIL90's Avatar
Home Depot... $3
Thanks! How did u put it on? Did u just slide the top portion of the light or did u remove the whole rear deck and base of the light?
Old 03-19-2014, 12:37 AM   #10
Tromatic
Turn down the one-note bass?
Old 03-19-2014, 12:52 AM   #11
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
Don't fix it!
As soon as you fix it, you'll hear the next thing that's rattling which will be much harder to fix or ignore...
993Fan is offline   Reply With Quote
Old 03-19-2014, 02:31 AM   #12
buzznasa
LOL PWR
buzznasa's Avatar
Had to unbolt and lower the amp to get to the bolts holding the third brake light in. Pulled light assembly off of rear deck, installed insulation on the light (not the rear window), trimmed with a fresh razor, and reinstalled everything. Took a little time but the results were worth it.
Old 03-19-2014, 06:37 AM   #13
dnieves
Here's another one that's temperature proof -clear silicon!
Old 03-19-2014, 10:23 AM   #14
buzznasa
LOL PWR
buzznasa's Avatar
Rattle from break light behind rear windshield! Danny Issues | Warranty | Recalls / TSB 2 06-30-2014 11:26 PM
Major bump in the road causing TPMS light? Chauntalei Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-20-2013 12:56 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
Subwoofer 3rd Brake Light Rattle mmieszanek Electronics | Audio | NAV | Infotainment 5 05-01-2013 12:21 PM
Stereo + Rear Brake Rattle ckcrown84 Electronics | Audio | NAV | Infotainment 13 04-30-2013 08:29 AM
