Old 03-18-2014, 10:48 PM   #1
TONY_BRZ
Drives: 2015 BRZ
Installing Overpipe Question
I've searched the threads but couldn't find a clear-cut answer. I'm most likely going the route of raising the engine instead of trying to wiggle the pipe out with the heat shield off. So, I heard you have to remove the passenger side engine mount. Can anyone provide a picture or a detailed description to where this is? Thank you in advance
TONY_BRZ is offline   Reply With Quote
Old 03-18-2014, 10:49 PM   #2
jonbonazza
I dont have any pics, but i did it recently and there were two mounts that i unbolted to get it out. The two mounts (maybe you can do with only one, i dunno) become obvious once you are under there.
Sent from my Nexus 4 using Tapatalk
jonbonazza is offline   Reply With Quote
Old 03-18-2014, 10:58 PM   #3
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Why would you do that?
Muaddib is offline   Reply With Quote
Old 03-18-2014, 11:02 PM   #4
TONY_BRZ
Drives: 2015 BRZ
How many bolts were there? Do you remember? Thanks man
Old 03-18-2014, 11:02 PM   #5
TONY_BRZ
Drives: 2015 BRZ
To provide clearance to remove the overpipe
Old 03-18-2014, 11:04 PM   #6
jonbonazza
Bolts for what?
Each mount i.. Er... Unmounted had 1 bolt, so 2 total.
The Following User Says Thank You to jonbonazza For This Useful Post:
TONY_BRZ (03-18-2014)
Old 03-18-2014, 11:04 PM   #7
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
You just remove the nut on the motor mount. Just one on each side. The motor can then be jacked up very easily to get you the clearance needed. On this car doing this is super easy, and takes about 1-2 minutes vs the hour of frustration of trying to squeeze it out without moving the motor.
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
Sonolin (03-18-2014), spitfire481 (03-18-2014), TONY_BRZ (03-18-2014)
Old 03-18-2014, 11:05 PM   #8
Mike86
Drives: Scion frs
Just one bolt on the lower mount near the overpipe just remove it and raise the engine with a block of wood on oil pan just make sure you dont lift too high so the bolt comes all the way out cause it might be a pain to get back in!! You can get a good inch extra of clearance install was a breeze after that!!
Hope it helps good luck
Mike
Mike86 is offline   Reply With Quote
The Following User Says Thank You to Mike86 For This Useful Post:
Old 03-18-2014, 11:15 PM   #9
TONY_BRZ
Drives: 2015 BRZ
thanks for the help guys!
Old 03-19-2014, 12:24 AM   #10
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
For anyone installing an overpipe, here is a video on how the engine lift is done.
[ame="http://www.youtube.com/watch?v=a9jGtvmtflA"]Perrin Performance Over Pipe and Front Pipe - Unboxing, Install and Review - 2013 Subaru BRZ - YouTube[/ame]
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following 3 Users Say Thank You to Apoc For This Useful Post:
Andrew025 (05-28-2014), SirBrass (04-17-2014), transition (03-19-2014)
Old 03-19-2014, 12:28 AM   #11
transition
I just removed my over-pipe today fairly easily after removing all the heat shields. Although i must admit the header was not in the car so that might have played a factor.
I think i spent more time trying to remove the O2 sensor clips without damaging them.
transition is offline   Reply With Quote
Old 03-19-2014, 12:30 AM   #12
transition
That's a great video. Wish i would have seen that before!
Old 03-19-2014, 01:35 AM   #13
THA STI GUY
DRIFT BUILD
THA STI GUY's Avatar
Drives: 2013 FRS
Just take the couple bolts off the heat shields and remove them and it comes right out i did not have to lift my engine.
2013 FRS Rocket bunny- PETE
THA STI GUY is offline   Reply With Quote
Old 03-19-2014, 01:46 AM   #14
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
I took the heat shield off as well and then pushed the engine up by hand and wiggled the over pipe out.
h4nh is offline   Reply With Quote
Simple question about overpipe/ front pipe... GDL Engine, Exhaust, Transmission 6 02-17-2014 02:18 AM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 03:03 AM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 02:17 PM
OVERPIPE+FRONT PIPE QUESTION MontrealFRS Engine, Exhaust, Transmission 10 04-27-2013 02:59 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 02:18 AM
