Old 03-18-2014, 10:10 PM   #1527
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by cjsporl1996 View Post
Post it up to datazap where it will be easier to view.
Luckrider is offline   Reply With Quote
Old 03-18-2014, 10:48 PM   #1528
SpatulaCS
SpatulaCS's Avatar
Drives: 2013 Scion FR-S Ultramarine
My OFT came today and flashed the 1.55 stage 2 UEL tune. The car is a whole different animal. It pulls much stronger and smoother. This is how the car should have come from the factory! My first WOT pull to redline left me giggling like a little girl. There's a small dead spot at initial pedal movement but I'm assuming the ecu will eventually learn and correct that.
A big thanks to @shiv@vishnu for producing a great product!
SpatulaCS is offline   Reply With Quote
Old 03-18-2014, 10:55 PM   #1529
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I had this as well but it didn't change. I have been back to stock for a while trying to see if a CEL will come back, but I was on E85 for around 1000 miles and had the Stage 1 map loaded for a week or so prior to that (easily a few hundred miles for me). I thought I was imagining things, but when a friend drove my car, he commented on the pedal doing just this.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
SpatulaCS (03-18-2014)
Old 03-18-2014, 11:11 PM   #1530
steve99
Drives: FT86
This is normal, ECU learning zero throttle settings
after flash if you let it idle for a couple of minutes speeds process.
Old 03-18-2014, 11:22 PM   #1531
SpatulaCS
SpatulaCS's Avatar
After I flashed, I turned the key to ON and moved the pedal through it's full travel ten times. I then started the car and let it idle for five minutes. I only have about 50 miles on the tune though, so I expect it will get better.
Old 03-18-2014, 11:23 PM   #1532
Captain Insano
Curious... are we supposed to be switching to 1.56b now? I saw it on the OFT site and didn't see 1.55b anymore.
Captain Insano is offline   Reply With Quote
Old 03-18-2014, 11:26 PM   #1533
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Take a peek at the release notes/read me file. It will describe changes between different versions. IIRC, the difference between 1.55 and 1.56 is just added ROM ID support for non-USDM OFT users. Mapping is unchanged.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Captain Insano (03-18-2014)
Old 03-18-2014, 11:27 PM   #1534
Captain Insano
Cool I will keep running 1.55 then.
Thanks!!
Old 03-19-2014, 07:15 AM   #1535
Lytheum
Drives: 2013 BRZ Premium 6MT
anyone car to take a look at my log? looks a little lean through the first half of the rev range.
http://www.datazap.me/u/lytheum/kn-d...g=0&data=1-2-9
only mods are k&n drop in and silicone intake hose.
3rd gear pull from about 2500rpm to redline. v1.55 map
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 03-19-2014, 09:02 AM   #1536
Kodename47
Kodename47's Avatar
Drives: UK GT86
I think that looks fine. Personally I think under 12 is a little rich for N/A, although I would taper it to run richer at the top end. Don't forget that the OFT is a one-fits-all type map, like the OEM one but better, so Shiv is always going to play things safe.
.: Stealth 86 :.
Kodename 47 DJ:
Luckrider (03-19-2014)
Old 03-19-2014, 10:10 AM   #1537
Tbor
Drives: Firestorm FR-S
Just a quick question,
Last night I flashed my car to Stage1 and was testing it out, I noticed that my engine sounded a little raspier when accelerating at certain points. or it could be something else rattling. Anyway, is this normal since we are pushing the engine a little more?
Tbor is offline   Reply With Quote
Old 03-19-2014, 10:21 AM   #1538
Luckrider
Luckrider's Avatar
3800-4000 RPM exhaust resonance due to aggressive exhaust timing to eliminate the dip. It goes away with the stage 2 UEL tune because the timing changes aren't needed to eliminate the power with an UnEqual Length header.
The Following User Says Thank You to Luckrider For This Useful Post:
Tbor (03-19-2014)
Old 03-19-2014, 10:49 AM   #1539
celica73
Are there any changes to engine braking in the OFT maps? Somewhere I read that the stock ECU (sorry, I can't seem to find the post anymore) leaves a lot of throttle opening when lifting off, while that it great for coasting/gas mileage, it sucks for getting the car to set the nose and actually turn-in in a motorsport setting.
Can anyone confirm this behavior?
Old 03-19-2014, 11:40 AM   #1540
Tbor
That makes perfect sense! Thank you, guess ill just have to wait for my OFH to come before i switch to stage 2.
One last question, I am completely stock, but want to run an e85 map.
Even tho stage 2 is designed for catless aftermarket headers, can i still run the stage 2 EL e85 map?
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
