#85 |
Time Traveller
I think a lot of folks are mistaking 8k for 10k.
8k is more blue than 6k (which is more white), 10k is more purple than 8k (which is more blue).
| The Following User Says Thank You to DAEMANO For This Useful Post: | Efferalgan (04-22-2014) |
#86 |
Drives: 13 Whiteout 6MT
The problem with that color map is that not every company adheres to it when marketing. Someone's 8000k is another man's 6000k, etc.
Even trying to match LED to HID from the SAME company can be difficult. That said, if these ARE close to 6000-8000, it'd probably still look good on most. |
#87 |
Drives: 2013 Raven
Anyone know if these will have high beam functionality?
#89 |
Drives: 2013 FRS M/T Firestorm
#90 |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I'm ready for these now.
#91 |
We have a bunch on order should be arriving to us in April. We'll be sure to do our usual work on these.
| The Following 3 Users Say Thank You to FT-86 SpeedFactory For This Useful Post: |
#92 |
Regional Moderator
#93 |
Drives: Firestorm Scion FR-S
#94 |
Drives: 2014 Scion Frs Whiteout
Any update on these??
Edit: Nevermind found they are out in the clear housing, waitnig for the black! |
#95 |
They're out an about.. Already installed on my car..
#96 |
Black housings are out too...
#97 |
Had these for about 2 weeks now and in black housing.
Also, if you're doing HID's, do NOT use H1 bulbs. Get D2S bulbs and the light output is great and so is the fitment. You will need D2S > Amp adapters if you already have ballasts. Otherwise, get a new HID kit made for D2S. Lastly, you can retrofit the whole thing to whatever you want. Mine are wired for DRL's so I have my high beams on in this picture to get them to show. Second picture is the hole I drilled for the HID's that I originally had for the H1 bulbs and the rubber grommet. You don't need to drill ones this big if you use D2S. Not sure if @FT-86 SpeedFactory have tested the D2S bulbs for fitment so you guys can sell those instead of the H1's from Morimoto. I know @fteightysix now sells D2S with their kits now because of a severe lack of info from the vendor. Worst part is the instructions call for an H1 bulb, but you will see just how bad the light output is once you put them in and attempt to adjust. ![]() ![]() ![]()
| The Following 3 Users Say Thank You to FR-S Matt For This Useful Post: |
#98 | |
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 01:36 AM |
| R/T Tuning & R/T Tuning Speed Shop Review Thread | R/T Tuning | User/Vendor/Sponsor Reviews, Feedback, Comments | 37 | 10-03-2014 02:23 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 06:33 PM |
