Old 03-13-2014, 02:33 AM   #85
DAEMANO
Time Traveller
I think a lot of folks are mistaking 8k for 10k.
8k is more blue than 6k (which is more white),
10k is more purple than 8k (which is more blue).
Old 03-13-2014, 08:08 AM   #86
FR-Slide
Drives: 13 Whiteout 6MT
The problem with that color map is that not every company adheres to it when marketing. Someone's 8000k is another man's 6000k, etc.
Even trying to match LED to HID from the SAME company can be difficult.
That said, if these ARE close to 6000-8000, it'd probably still look good on most.
FR-Slide is offline   Reply With Quote
Old 03-13-2014, 09:47 AM   #87
KDad2
KDad2's Avatar
Drives: 2013 Raven
Anyone know if these will have high beam functionality?
KDad2 is offline   Reply With Quote
Old 03-14-2014, 08:27 AM   #88
balla_08
Drives: Satin Pearl BRZ
Will these be available for the BRZ or Nahh
balla_08 is offline   Reply With Quote
Old 03-14-2014, 06:44 PM   #89
Bushman7140
Drives: 2013 FRS M/T Firestorm
Not for the BRZ at initial release. My understanding, they will be released but at a later date.
Bushman7140 is offline   Reply With Quote
Old 03-14-2014, 08:58 PM   #90
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I'm ready for these now.
Chen is offline   Reply With Quote
Old 03-15-2014, 06:17 AM   #91
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We have a bunch on order should be arriving to us in April. We'll be sure to do our usual work on these.
FT-86 SpeedFactory is offline   Reply With Quote
Old 03-16-2014, 02:18 AM   #92
Chen
Regional Moderator
Chen's Avatar
Keep me posted for first batch!
Old 03-20-2014, 03:41 AM   #93
thientai
thientai's Avatar
Drives: Firestorm Scion FR-S
I found this from google images X__x
http://www.k2motor.com/12-up-scion-f...eadlights.html
thientai is offline   Reply With Quote
Old 05-18-2014, 01:00 PM   #94
DriftinFRS
Drives: 2014 Scion Frs Whiteout
Any update on these??
Edit: Nevermind found they are out in the clear housing, waitnig for the black!
DriftinFRS is offline   Reply With Quote
Old 05-18-2014, 01:01 PM   #95
Bushman7140
They're out an about.. Already installed on my car..
Old 05-18-2014, 06:42 PM   #96
Bushman7140
Black housings are out too...
Old 05-18-2014, 06:58 PM   #97
FR-S Matt
Had these for about 2 weeks now and in black housing.
Also, if you're doing HID's, do NOT use H1 bulbs. Get D2S bulbs and the light output is great and so is the fitment. You will need D2S > Amp adapters if you already have ballasts. Otherwise, get a new HID kit made for D2S. Lastly, you can retrofit the whole thing to whatever you want. Mine are wired for DRL's so I have my high beams on in this picture to get them to show. Second picture is the hole I drilled for the HID's that I originally had for the H1 bulbs and the rubber grommet. You don't need to drill ones this big if you use D2S.
Not sure if @FT-86 SpeedFactory have tested the D2S bulbs for fitment so you guys can sell those instead of the H1's from Morimoto. I know @fteightysix now sells D2S with their kits now because of a severe lack of info from the vendor. Worst part is the instructions call for an H1 bulb, but you will see just how bad the light output is once you put them in and attempt to adjust.
Old 05-18-2014, 10:34 PM   #98
Bushman7140
+1 on the D2S, i made the mistake and went with H1 as thats what everything called for.. I'll be changing over asap...
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 02:23 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
