Old 02-22-2014, 09:44 PM   #1
Carban
Grease Monkey
Carban's Avatar
Drives: Whiteout FR-S
Custom Voltmeter Gauge Install on my FR-S
A quick write-up on my procedure of installing an interior voltmeter. For anyone who's interested in a reference of the cars voltage on the fly.
Why?
-Monitor battery and alternator performance before getting stranded
-Recognizing an excessive voltage drain (or spikes) before a problem becomes a serious issue
-Use accessories when the engine is off while knowing when to start the car for a recharge
I bought a few of these on ebay, yes, they were cheap but they work pretty well and are perfect for custom applications
Accuracy +/- .1v Refresh rate about .5 seconds
I used the 12v dc cig lighter behind the glovebox for power and connected ground to one of the bolts holding the head unit housing
Removed the passenger side dashboard plastic cover, then removed the center dashboard plastic cover (pictured). Started my cutout for the meter by measuring where i wanted it then drilling a couple small holes followed by a good amount of filing down until the meter fit just right
Not perfect, but the flaws should be covered by the time im finished
Meter fits nice and snuggy Also to help keep it in place i used a couple pieces of one-sided adhesive foam behind the cutout
Finished off by adding a piece of tinted film over the front.
Measures accurately and refreshes constantly
Thanks for looking!
R.I.P. '92 Honda Prelude you will be missed
Carban is offline   Reply With Quote
The Following 9 Users Say Thank You to Carban For This Useful Post:
Alain (02-23-2014), illicitstylz (05-11-2014), iniguez310 (05-14-2014), jcw99 (07-03-2016), luv85 (02-24-2014), Nomed Alucard (02-24-2014), Pacific (02-24-2014), Tye300 (05-11-2014), userjack6880 (02-24-2014)
Old 02-23-2014, 10:04 PM   #2
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
You about to get more pics of it connected up in the glove box at all?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 02-23-2014, 10:24 PM   #3
KkSc
KkSc's Avatar
Drives: 86
Very impressive...thanks for the write up!
5000k HID/ Switchback LED signals/ Valenti LED Tail/ TRD Air Intake/ H&R Supersport with Koni Yellow Shocks
KkSc is offline   Reply With Quote
Old 02-24-2014, 01:12 AM   #4
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
Personally, I would have stuck this on the driver side of that trim panel, but I guess this is all up to preferences.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
Old 02-24-2014, 11:11 PM   #5
Carban
Grease Monkey
Carban's Avatar
Not much to see. this is basically what i did: Unplug cig lighter, connect power wire from the meter into the power(12v) slot of the cig lighter's connector. done. just one small wire.
Let me know if you do happen to need pics tho ill do my best to provide.
The steering wheel blocks that spot from my vision. Also that side of the panel was at too much of an angle. Oh and because there was no room behind that side of the panel. Maybe a good spot for something in the future
Old 02-25-2014, 12:18 PM   #6
userjack6880
Good 'nuff. I could have sworn there was ample room behind that trim there.
Old 03-15-2014, 09:02 AM   #7
sirisvirus
Drives:
Good write up but why would you need to know the voltage on the fly.
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
Old 05-10-2014, 07:47 PM   #8
Carban
Grease Monkey
Carban's Avatar
See top of original post:
Why?
DIY: ATI 60mm Vent Pod Install With Defi Gauge RallySport Direct DIY (Do-It-Yourself) Guides 70 11-26-2017 11:05 PM
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
Custom Gauge Cluster? Ingen Cosmetic Modification (Interior/Exterior/Lighting) 34 07-03-2014 10:41 PM
FS: FA20Club Stage 1.5 Custom Turbo Kit Dan@AWD Engine, Exhaust, Bolt-Ons 49 05-20-2014 02:26 PM
FA20CLUB FR-S/BRZ Gauge Integration- Install other sensors question mtimney Electronics | Audio | NAV | Infotainment 2 07-24-2013 03:27 PM
