Old 03-14-2014, 12:07 AM   #239
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Originally Posted by OoLong View Post
My body shop painter friend said any matte sealer from Rust-oleum or other major brand should work fine for simple body kit matte painting. He said it is good idea to seal because of the reason of easier to clean, avoid fading and longer color life.
which Sealer Spray are you using ?
thanks
ucsmfu is offline   Reply With Quote
Old 03-14-2014, 01:09 AM   #240
OoLong
#TeamAURA
OoLong's Avatar
Drives: BRZ Limited Lighting Red '13
thanks
The paint products I used (from left to right: primer, paint, sealer)
Recommended sandpaper 220 grit, perfect!
Result:
Mistakes:
If this happens to you, be patient! Let it dry for at least 48hrs and then sand down the messed up part and respray. Do not, I repeat DO NOT try to remove the messed up paint shortly after you realize you've messed up. Wait. Sand. Spray.
Hope that answers your question.
OoLong is offline   Reply With Quote
The Following User Says Thank You to OoLong For This Useful Post:
uEih (03-18-2014)
Old 03-14-2014, 01:34 AM   #241
Vis101
Vis101's Avatar
Drives: 2013 Limited BRZ
@OoLong Eager to see this installed. Let us know what you do for mounting the lip and spats. Cheers.
Sent from my HTCONE using Tapatalk
Vis101 is offline   Reply With Quote
Old 03-14-2014, 01:56 AM   #242
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Result:
Mistakes:
damn, looks clean. I might actually sand mine, primer and use the paint spray again. Does it look like a matte black colour ? not too glossy right ? Can I directly sand over the painted part ? how many coats of each did you use ?
Old 03-14-2014, 02:00 AM   #243
OoLong
#TeamAURA
OoLong's Avatar
It is a matte finish with not much gloss at all. Yes you can sand your painted parts but make sure they've been dried for at least 48hrs before sanding (which I presume they are). For each part I've been doing at least 8-10 coats (I lose count sometimes because I'll be doing other stuff while waiting for the paint to dry) to make a perfect smooth finish.
All I have left are the side skirts and then installation time!
Old 03-14-2014, 02:08 AM   #244
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
wow, nice !! how many bottles of each have you used ? home depot ? for primer why did you use grey and not black ?
BTW, have you compared your painted replicas to the OEM one to see if the colours match ?
thanks
Old 03-14-2014, 02:21 AM   #245
OoLong
#TeamAURA
OoLong's Avatar
thanks
Got them all at HomeDepot.
1 bottle of primer (only need 1 coat per item, the flat-black also have some primer in them)
2 bottles out of 4 so far (front lip + rear aprons)
I couldn't find any black primer, all I found was white or grey. I choice grey because it will be black anyways for the top coat.
I haven't found anyone around my area with OEM, I think it is too damn expensive for pieces of plastic... Even the replicas are a little on the expensive side for me
Also, PRO TIP:
Apply the clear coat after all your pieces has been completely dried for at least 48hrs. I can't stress this enough. If you apply it just after the black dries then you will have a gray-ish color instead of more of a flat black.
jwSubMOA (03-19-2014)
Old 03-14-2014, 03:06 AM   #246
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Also, PRO TIP:
got it, thanks OoLong, will re-do everything properly when the weather gets better
thanks
Old 03-18-2014, 11:00 PM   #247
uEih
Drives: CBS Subaru BRZ Limited
I'm really liking how it looks there, a little shine but not too much. If you didn't put the clear coat on would it have looked the same? I was planning to just sand without spraying primer, would primer help that much even if you sand?
uEih is offline   Reply With Quote
Old 03-19-2014, 02:29 PM   #248
OoLong
#TeamAURA
OoLong's Avatar
Having a matte seal on it will give you a little bit more sheen and depending on what angle you are looking at the piece, it can be a tad bit gray. I've decided not gonna do a clear seal and see how it goes. If it starts fading, I'll just paint it again.
uEih (03-19-2014)
Old 03-19-2014, 08:54 PM   #249
uEih
I'm a little torn between semi gloss and matte black, a lot of people did matte black but from what I read with the STi lip it's semi-gloss and I also wanted to get it as close to that as possible but no real world comparison to really base my decision on.
Old 04-15-2014, 01:52 PM   #250
OoLong
#TeamAURA
OoLong's Avatar
So I am done painting all the parts and was install my kit this weekend. This is the only problem I ran into in terms of fitment issue... I took the weather strips off because the one that BaysonR provided was pos... What is the best way for me to hold that flap to the bumper? I was thinking just doing screws on the bottom part but I wanted to hear some 2nd opinions.
Old 04-15-2014, 05:09 PM   #251
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Never mind... Wrong picture
Old 04-15-2014, 05:20 PM   #252
Vis101
Vis101's Avatar
@OoLong, I will be tackling the lip and rear spat install this weekend finally. Because I am doing so in part to cover up some cosmetic issues, I have no problem using screws. Curious to see more pictures, particularly of the spats from various angles. Thanks.
STi Style Carbon Fiber Front Lip/Side Skirts/Rear [BRZ] JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 31 12-03-2013 10:57 PM
CS Style Polyurethane Side Skirts Jive Turkey Exterior Parts (Aero, Lighting, Etc.) 14 11-04-2013 09:49 PM
WTB CHARGESPEED STYLE SIDE SKIRTS. bahanii Want-To-Buy Requests 1 10-18-2013 02:06 PM
FS: CS Style Side Skirts and Rear Spats FRS2000 Exterior Parts (Aero, Lighting, Etc.) 4 09-23-2013 12:15 PM
2013 SUBARU BRZ J STYLE PU SIDE SKIRTS JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 7 05-10-2013 11:29 AM
