Old 02-27-2014, 05:17 PM   #57
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Thats what i thought.
The codes im getting are
P0138
U0073
P2097
P013a
They all seem to be related to the o2 sensor, so should be good.
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Sportsguy83 (02-27-2014)
Old 03-09-2014, 12:39 PM   #58
welllam
Drives: STi
If you are getting O2 code, you should check your O2 Sensor #2 - Voltage (V) reading in ECUtek, because you might be ground the signal ground incorrectly. I got P0138 and found the brown signal ground cable isnt ground properly to the chassis. The Normal reading should be 1.5-4.5V.
@Sportsguy83 do you find your gauge reading vs your logged reading slightly off? Mine is about 0.7 richer than gauge displayed at idle. Also can you close your fuse box after you use the add a fuse?
welllam is offline   Reply With Quote
The Following User Says Thank You to welllam For This Useful Post:
Sportsguy83 (03-09-2014)
Old 03-09-2014, 01:02 PM   #59
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I used for ground the bolt that holds the fuse box in place.
I need to take a log of OEM AFR and wideband to compare but looking at them live data seem pretty close.
The fuse box has no cover anymore.
Whitefrs hates my phone signature
Old 03-09-2014, 10:36 PM   #60
welllam
Drives: STi
Take a look at my attached log. If you look at max my voltage read is 4.19, while the target of the liftoff cruising should be 4.5 @ AFR 18 on gauge display. So it is 0.31V off. What about yours?
Old 03-09-2014, 10:40 PM   #61
Sportsguy83
Drives: Limited BRZ
I'll take a log this week and check it out.
Old 03-10-2014, 05:02 AM   #62
Kodename47
Kodename47's Avatar
Drives: UK GT86
Out of interest, which wideband sensors are people using?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-10-2014, 06:36 PM   #63
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Would there be a way to add wideband data to the CAN bus if the wideband controller could output the signal for CAN Bus? Like this:
http://www.ecotrons.com/products/wid...oller-alm-can/
^GT5 Replay Photo Mode^
Old 03-13-2014, 05:49 PM   #64
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
This is really cool and I am tempted to go this route when my car gets retuned. Would it be possible to utilize a different input besides secondary 02 sensor? Not sure what else may be available but effectively disconnecting secondary 02 concerns me. My concern isn't based on fact, just an uneasiness messing with factory 02 sensors. I would much rather see all 3 running in parallel.
pixel67 is offline   Reply With Quote
Old 03-13-2014, 06:26 PM   #65
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The secondary O2 sensor is used solely to calculate a difference in reading between the first and the second sensor to tell the ECU if the cats are working properly.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
pixel67 (03-13-2014), SirBrass (03-13-2014)
Old 03-13-2014, 06:58 PM   #66
pixel67
pixel67's Avatar
Paranoia... Any emissions testing concerns?
Sent from my SPH-L710 using Tapatalk
Old 03-13-2014, 10:14 PM   #67
Sportsguy83
Drives: Limited BRZ
I belive one of the "readiness" checks won't be ready.
You can use the CPC input, but I believe that one also throws a not ready.
Old 03-17-2014, 07:25 PM   #68
gdrider77
gdrider77's Avatar
So i did this as well. For people that are curious, i actually did this under the pass dash at the main ecu harness.. I have no worries cutting and soldering wires, etc... Its not really too hard to get to. What i did was unplug the harness and then cut and solder.
Here is the ECU with the harnesses unplugged. Dont have to do this, but unplugging makes them pretty easy to work with.
Here is the wire for the rear o2, what i did was cut this in half. The wire that feeds back into the harness goes to your wideband sensor output.
The other side of the wire that goes back to the actual factory o2 sensor, i simply extended it slightly and then capped off via heat shrink. This will allow me to wire back to stock without having to pull the harnesses, etc. later if need be.
The wire for the CPC input. I cut this and extended it a bit, so later if i want the flexfuel input or for other uses, i can simply get to this in the kick panel without pulling the harneses, getting under the dash, etc.
The two wires cut and soldered/shrink wrapped.
Hope this helps anyone that wants to keep the wiring inside the car. Great to have this feeding and logging. Amazing how far off the stock is vs the wideband.
The Following 3 Users Say Thank You to gdrider77 For This Useful Post:
airrick (07-31-2020), mrk1 (04-08-2014), Sportsguy83 (03-17-2014)
Old 03-17-2014, 07:48 PM   #69
pixel67
pixel67's Avatar
Thanks, but... I believe flex fuel is already using it.
Sent from my Nexus 7 using Tapatalk
Old 03-17-2014, 08:59 PM   #70
Sportsguy83
Drives: Limited BRZ
SOL.... Those a only two inputs available
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
Aftermarket Rear Diffuser Realm Cosmetic Modification (Interior/Exterior/Lighting) 8 05-08-2013 11:23 PM
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay xxscaxx Exterior Parts (Aero, Lighting, Etc.) 10 03-27-2013 10:17 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 09:53 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
