#85 |
Hey bro trust me it works.
Looks good. That's totally normal. You just need to buy it, don't worry about any real data to back any of it up or installation manuals, or anything else. Been doing this for 20+ years.
#86 |
Drives: frs
Most of the time, longer intake runners (however they are employed either different manifold or spacers) will add to top end. It was a simple way back in carburetor days to get a good performance boost in the upper half of the RPM range. (Think stoplight to stoplight and drag racing) Carb spacers also did the same thing, but with less affect. Sometimes it actually robbed bottom end performance though. I have built a few Chevy and Ford small blocks back in the day, and this is some of what we did. For more bottom end you went low rise dual plane manifold.
Edit: BTW I did forget to mention that adjusting and sometimes rejetting the carburetor was a must. Curious how this is possible without a remap of fuel injection at the very least Last edited by twag4; 03-13-2014 at 01:38 PM. Reason: More info added |
#87 | |
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#88 |
BTW that was 100% serious. I am ordering a set today. Lets find out how well they work! I'll try and get a car in for baseline this weekend.
#89 |
Drives: 1996 Acura Integra GS-R
Crawford Billet Power Blocks
Just saw this announced by Crawford Performance, basically:
"our BPB sandwich between the cylinder heads and the intake manifold to create longer intake runners. The lengthened intake runners enhance the volumetric efficiency of the engine which translated into an increase of 19 Horse Power, 15 Pound Feet of Torque and narrowed up the torque dip by 300RPM on a totally stock (GT86)." How exactly does this work? I'm trying to picture it. $400 for +19hp? http://www.crawfordperformance.com/p...er-blocks-bpb/
#90 | |
Drives: Whiteout FRS
Sent from my SM-N9005 using Tapatalk |
#91 |
Drives: 2013 firestorm FRS
The reason Toyota/Subaru probably didnt raise the manifold was due to manifold to hood clearance for pedestrian impact regulations if this modification indeed works.
#92 | |
The fact that you are changing the fuel stratification on the port injection and likely direct injection side is enough for me to avoid it. Correct me if I am wrong but your port injection spray is now altered and the airflow change would almost certainly require tuning changes.
#93 | |
Prior to 5,200 you are running pure DI until 2,400RPM. Which it quickly interpolates to 50% as you get to 2,000RPM.
#94 |
NASA SpecE30 Racer
Has anyone asked Toni @ FA20Club if he could make some in the same design but in polymer? I hear he has experience in this area.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#95 | |
#96 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Whats up with the hate/comments about Crawford?
#97 |
Drives: '13 FRS - STX
Engines operate on a lot of fluid dynamics assumptions. Every time a valve is opened or closed there is a sonic boom as the pressure differential is so great that the gases moving around break the sound barrier, there's a shockwave from this that can be used to aid (or hinder) in airflow not only to the single cylinder but to the system as a whole. By running simulations and some experimentation an intake system is tuned to the engine for certain characteristics: sound, efficiency, performance etc. by varying the size of the resonant chamber which is what this mod does.
Pretty picture of a 2 stroke engine which relies on exhaust tuning to get more power and efficiency: ![]() Now the real question is "is this too good to be true?" My answer is "probably", if 20hp was this simple Toyota would have done it. Maybe the idle is rough, probably to get the most out of it the tune required (it is required for the gains they claim) isn't compliant with emissions. I'd gamble that there's a folder in Toyota's hard drives with at least a preliminary analysis of this intake design that was discarded for some reason or another. If you want 20hp, don't care about passing emissions or an aftermarket reflash then it looks pretty trick to me. |
#98 |
NASA SpecE30 Racer
Their support of the BRZ/FR-S and FA20 motor has been a joke up to this point. I have yet to find one owner with their turbo kit. Their built motor price is a joke. They tried to convince us that our motors were all going to explode if we didn't buy a built motor, and now they are selling spacers as a 20 hp part.
*Crawford is not a paying vendor to my knowledge, if they are, I will delete my post.
- King Tut
| Tags |
| billet, crawford, magic blocks |
| Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 | ZetaVI | BRZ Photos, Videos, Wallpapers, Gallery Forum | 22 | 04-01-2014 05:19 PM |
| short blocks? | 350matt | Engine, Exhaust, Transmission | 4 | 11-04-2013 08:37 PM |
| Billet Oil Catch Can #BC-175 by Billet Custom | Tim_Asphalt_FRS | Engine, Exhaust, Transmission | 48 | 10-27-2013 02:29 PM |
| ***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 1 | 10-07-2013 09:40 PM |
