Old 03-12-2014, 09:49 PM   #57
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Originally Posted by FullBlown View Post
In stock and shipped
Awesome!! Thanks!! Do you provide a tracking number by chance?
Dustin is offline   Reply With Quote
Old 03-12-2014, 10:10 PM   #58
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I will Pm you in the morning.
FullBlown is offline   Reply With Quote
Old 03-12-2014, 10:13 PM   #59
Dustin
Twin Screw You
Dustin's Avatar
Old 03-12-2014, 10:16 PM   #60
mike the snake
The Full Blown radiator also is designed with the mounting posts positioned to move the radiator forward for a little extra clearance if you're running a front mount turbo kit.
I ended up modifying the mounts and moving mine forward even more to gain the clearance I wanted, but the FB radiator does mount further forward than other aftermarket radiators. It's a nice unit.
Old 03-12-2014, 10:26 PM   #61
Ryan P
Price for the radiator and shroud w/out the fans? I already have twin 12" Spal fans
Ryan P is offline   Reply With Quote
Old 03-12-2014, 10:51 PM   #62
FullBlown
FullBlown's Avatar
Drives: Scion FRS
PMd
The Following User Says Thank You to FullBlown For This Useful Post:
Ryan P (03-12-2014)
Old 03-13-2014, 12:07 PM   #63
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
For what it's worth, having the FBM Shroud+Rad helps the SPAL fans instantaneously cool off the radiator.
My car warms up to 213 in hot Florida, I hear the fans come on and drops to 203-208 within 10-15 seconds.
In fact it really only runs hot when oil temps are too low. Even then nothing above 213, pretty solid IMO and I'm not worried about Florida Summer heat anymore.
Also fwiw, the FBM oil cooler keeps me below 230 oil temps even at idle with 98 deg ambient
Ironsquid is offline   Reply With Quote
The Following 2 Users Say Thank You to Ironsquid For This Useful Post:
Brody602 (03-13-2014), FullBlown (03-13-2014)
Old 03-13-2014, 12:38 PM   #64
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Do you think one can get away without a vented hood with this new setup or would recommend a vented hood to help with the heat?
I have reason to believe you might be able to make an educated guess wether a vented hood would be beneficial on hot days with spirited driving.
Thanks!
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-13-2014, 12:49 PM   #65
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
ahhh shitttt!
FRS-HHH is offline   Reply With Quote
Old 03-13-2014, 12:56 PM   #66
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Thanks!
I had other cosmetic reasons for a vented hood than just heat scavenging, but honestly in Canada I don't think you "need" one. There's plenty of turbo guys in Florida without vented hoods that run fine.
It's really more pain than it's worth if you can't park it under cover or have a second daily driver IMHO. If there was a solid downpour here and I parked it outside it would soak the entire engine bay.
Having said that there are some vented hoods with raid guards, my new Varis hood has them so I keep them in the trunk. I'm in the garage at home and at work so I'm too worried.
Old 03-13-2014, 01:03 PM   #67
Brody602
Drift King
Brody602's Avatar
Yeah I mean we'll get some days of 86-90 degree weather but for the most art in my area it stays around 74-78.
I do however think I would get the Varis as well due to the rain guards, how do they work? Do thhey just slide into the openings ontop of your hood?
I think my best bet would be to drive it agressively it on one of our hotest days and see what happens temeratures wise. It is my summer DD so about 6 months of the year, so I can see the hood becoming a PITA with a lot of rain..
Thanks for the input!
Old 03-13-2014, 01:06 PM   #68
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Seibon apparently has rain guards too.
The Varis ones bolt into the underside of the hood and channel the water to the front bumper drainage.
Just for quick installation, I'm going to buy wingnut bolts to make it faster to put them in in-case of an emergency
Old 03-13-2014, 01:08 PM   #69
Brody602
Drift King
Brody602's Avatar
Hmm I thought I recalled you stating your previous seibon hood didn't come with rain guards.
So I am guessing the vents become useless when the guards are in place or would they still manage to pull some heat out? I'd love to see a picture of the hood with them installed.
Old 03-13-2014, 01:11 PM   #70
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Mine did not, however this was last year, I heard they have them now.
The vent do not function with the raid guards in place, basically seals the hole.
I might be able to get some pics this weekend.
The Following User Says Thank You to Ironsquid For This Useful Post:
Spal Fan Shroud & Koyo Radiator Carolina Dyno Forced Induction 64 12-14-2016 08:38 PM
FBM Aluminum Radiator $279 shipped FullBlown Engine, Exhaust, Bolt-Ons 0 01-06-2014 05:40 PM
Aluminum radiator install and impressions Tye300 Engine, Exhaust, Transmission 15 10-28-2013 01:52 PM
Product Release! Mishimoto Peformance Aluminum Radiator for Scion FR-S / Subaru BRZ! Mishimoto Announcements, Contests, Giveaways 1 10-01-2013 11:44 AM
BRZ STI front under spoiler and 17" aluminum wheels released in Japan yajin BRZ First-Gen (2012+) — General Topics 99 05-31-2012 06:09 PM
