Old 03-12-2014, 09:44 PM   #575
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
It is, in the sense that it's regulated by the coolant...
The coolant in your engine is regulated. The coolant in your radiator is not. So a guy in Canada (eh?) commuting to work in Winter would see his oil chilled quite undesirably.
Water entering the radiator does so at the temperature of the water outlet manifold, but under low load, that water flow is really small and it's cooling rapidly as soon as it hits the radiator.
Ralph Spoilsport is offline   Reply With Quote
Old 03-13-2014, 02:55 AM   #576
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
And the car comes with nothing stock...
In any case, I'd prefer the "OEM" cooler in-line with an air to oil cooler if that makes sense. The problem with coolers is that they are too efficient (see: winter) and this engine already has a cold oil issue as well as a hot oil issue - either a higher temp thermostat, a piece of cardboard, or the two cooler solution I speak of is what I'd be interested in.
Or this cooler with a more efficient radiator would also work and be less complex while still providing both adequate cooling and heating.
Exactly, I believe the OEM cooler should work as a nice "regulator" and would be enough with a better radiator. If the top mounted intercooled turbo FA20 engine works fine in desert with OEM radiator, it should also work fine with a bigger radiator and a FMIC'd Rotrex unit.
glamcem is offline   Reply With Quote
Old 03-13-2014, 03:23 AM   #577
CSG Mike
CSG Mike's Avatar
A better radiator isn't going to keep your coolant any cooler under normal circumstances.
Have you guys seen how little the contact area is?
Old 03-13-2014, 05:38 AM   #578
Calum
That Guy
Drives: 2013 asphalt FRS MT
You might just be right. I was thinking the water flow being so little would prevent the oil from being cooled further. But the water sitting in the radiator is going to cool while it sits in there and thus cool the oil as well. The temperature difference created by the oil heating the water would likely be enough to cause the water in the radiator to flow internally, ensuring the oil is cooled even more.
Thanks for the eye opener, eh.
Old 03-13-2014, 05:58 AM   #579
FAER
Drives: Silver BRZ
anyone used the larger Rotrex unit? If so, what power is it making
FAER is offline   Reply With Quote
Old 03-13-2014, 11:37 AM   #580
sw20kosh
Drives: 2013 Black FR-S
So we know the ecu pulls back at 240 F oil temps. Does it pull back power at the lower end of the spectrum too? Anyone know this temperature?
Old 03-13-2014, 11:43 AM   #581
OrbitalEllipses
Drives: Attitude
I can't verify what the engine control logic is, but oil that is TOO cold isn't good either - I think we can all agree on that. It's about the middle path, as Aristotle said.
glamcem (03-13-2014)
Old 03-13-2014, 02:20 PM   #582
sw20kosh
Sweet spot is? 180 - 230F OIL?
Old 03-13-2014, 08:28 PM   #583
Poodles
Drives: 2015 Series.Blue
Yep, not hot enough and you don't boil off the water and fuel that gets into the oil. You also don't set off the additive pack until it's warm (additive pack stuff could take up an entire other thread)
Keep in mind that any thermostatic oil cooler is never truly closed all the way (how else would you fill the heat exchanger?), same goes for the coolant thermostat.
Factory oil to water coolers are used all the time because they're cheap. While they work, there's a reason race cars run thermostatic air-oil coolers...
The Following User Says Thank You to Poodles For This Useful Post:
CSG Mike (03-13-2014)
Old 04-15-2014, 05:23 PM   #584
FullTuneZN6
Novice Drifter
FullTuneZN6's Avatar
Drives: 2013 Asphalt FR-S
i read somewhere that there is a 10psi pulley....is that the factory pulley or the upgraded? @*LongFella are you running the perring overpipe too with your exhaust setup? thanks
FullTuneZN6 is offline   Reply With Quote
Old 04-15-2014, 08:25 PM   #585
4032pauln
Drives: lexus
It is the factory pulley
4032pauln is offline   Reply With Quote
The Following User Says Thank You to 4032pauln For This Useful Post:
FullTuneZN6 (04-15-2014)
Old 04-15-2014, 09:02 PM   #586
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
I believe the kit is stock at 10 psi. Don't quote me though, I'm not 100%.
Nope on the Perrin over pipe. I will eventually do the whole exhaust including headers, but I'm waiting "patiently" as CSG Mike recommended. I figured if this secret is really good, which I'm sure it is, I'll spend the money on it...upgrade the entire exhaust too, and have a custom tune done
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
The Following User Says Thank You to *LongFella For This Useful Post:
Old 04-15-2014, 09:02 PM   #587
*LongFella
*LongFella's Avatar
Oh and don't forget I want to eventually run e85
Old 04-17-2014, 08:48 AM   #588
4032pauln
Drives: lexus
You should gut out ur headers in the meantime, it real easy and quick, and ull get extra power
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
