Old 03-13-2014, 09:50 AM   #3907
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by calispec View Post
IIRC Sprintex shipped a new MAP sensor with the stage two kit. It also had AIT built in. They had so many problems with it that they stopped shipping the map sensor and told all their customers to switch back to the OEM map sensor. I was going to switch my map sensor as well but after hearing all that I stayed away. I talked briefly to Bill and he said I was better off staying OEM.
Sorry to hear about all your problems. It's super easy to make the switch so why not give it a try to rule it out.
True its easy to swap it, but I will need an updated map for the sensor.
xxscaxx is offline   Reply With Quote
Old 03-13-2014, 09:54 AM   #3908
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Your tuner should be able to scale it back pretty quick. Unless he is using the MAP as an input past 5 psi. I would still ask.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 03-13-2014, 09:55 AM   #3909
xxscaxx
Unfortunately my tuner is at texas2k and won't be around for the next couple days lol. Thats why I was making a deal about the map swap
The Following User Says Thank You to xxscaxx For This Useful Post:
calispec (03-13-2014)
Old 03-13-2014, 11:33 AM   #3910
sw20kosh
Drives: 2013 Black FR-S
Maybe remove the laminova core and isolate the problem? Run it on the dyno Non intercooled?
Old 03-13-2014, 11:36 AM   #3911
xxscaxx
I don't want to remove it, if its not needed. I rather keep it. Thats a last option.
But at that point I might be a little pissed and who knows what I end up doing
Old 03-13-2014, 11:47 AM   #3912
OrbitalEllipses
Drives: Attitude
So what is going on here, the intercooler is allowing you to push the blower to its limits and at the limits the blower is kinda...blah?
Old 03-13-2014, 12:15 PM   #3913
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
So bear in mind we said "at this time".
Just swapped MAP sensors to stock. No more misfires
We'll verify on the dyno but I'm 99% sure that's the issue.
Xero-Limit is offline   Reply With Quote
Old 03-13-2014, 12:16 PM   #3914
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Meaning the sensor was bad, or you can't run a 3/4 omni with the IC?
mikalem is offline   Reply With Quote
Old 03-13-2014, 12:34 PM   #3915
Xero-Limit
Xero-Limit's Avatar
IC and 3/4 bar map sensors are not compatible. Every other FI setup they are fine.
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
Drift-Office (03-13-2014), mikalem (03-13-2014)
Old 03-13-2014, 01:10 PM   #3916
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
This would be bizarre. But I have found that the Omni o-ring is too large for the MAP sensor plate. Even lubing it up, its extremely hard to get it in there without ripping the o-ring.
Yep, special care needed on that one!
Cheers!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 03-13-2014, 01:19 PM   #3917
xxscaxx
what is the reason?
Old 03-13-2014, 01:52 PM   #3918
Xero-Limit
Xero-Limit's Avatar
Originally Posted by mad_sb View Post
What Map Sensor are you using?
He also tried everyting tuning wise, cam sweeps, fueling, timing etc etc nothing made it any better until he went back to the stock map sensor. I don't understand it, but I trust what he was telling me. Seems crazy but there could be a reference to the map sensor that is not exposed in some of the tuning platforms is all i can figure.
We had 5 different tuners/their customers we've been in touch with recently who were all having the same issue and tried the same things. I looked back and the only customers we had that didn't have the issues had stock map sensors. Since the CARB tune used a stock MAP sensor, that is why they were not having the issue.
what is the reason?
It is for a few reasons, some of which I don't have the time to get into. But basically because of how the SC flows, the cam phasing is critical, and unlike turbos and the centrifugals; it creates a different flow pattern right at the runner and is the reason for the wobbly MAP signal.
In double checking and making a few phone calls we know that not the omni, the OEM honda, nor the denso IAT based map sensors will work. I think any >1.3 bar sensor will have the same issue when intercooled.
Drift-Office (03-14-2014), xxscaxx (03-13-2014)
Old 03-13-2014, 01:59 PM   #3919
xxscaxx
Thanks for the reply. I wasn't looking for an elaborate explanation so that worked just fine
Are you still seeing power loss? Or has all been basically resolved now?
Old 03-13-2014, 01:59 PM   #3920
Xero-Limit
Xero-Limit's Avatar
Spinning the wheels top of 2nd with 255's on pump gas
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
Lawnik (03-13-2014), Subzero (03-13-2014), xxscaxx (03-13-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
