Old 03-12-2014, 08:09 PM   #1107
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Originally Posted by Ironsquid View Post
For what it's worth the 35r isn't laggy at all on this compression. It would be easier to hit your target as well.
Haha, I'm not sure if i want to run 15 psi on the stock block :P
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-12-2014, 08:12 PM   #1108
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
I thought you were building the block ;P
Ironsquid is offline   Reply With Quote
Old 03-12-2014, 08:13 PM   #1109
pmccut
Drives: Blue Subarus
I was making 353 on 91 with the base 2871 at 15psi. 9:1 c/r. Installed the gtx3076r for the same reason. Won't have numbers for awhile tho. I doubt 450
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 03-12-2014, 08:13 PM   #1110
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Did you drop the car at bill ?
Sent from my IBrick
Old 03-12-2014, 08:16 PM   #1111
Brody602
Drift King
Brody602's Avatar
Yeah, sorry I miss understood, so there would be less boost lag with lower compression pistons?
Old 03-12-2014, 08:17 PM   #1112
Brody602
Drift King
Brody602's Avatar
I'm curious to see numbers, I'd love to know so I can make a decision from there
Old 03-12-2014, 08:59 PM   #1113
pmccut
Sent from my IBrick
It's there. Ran into unforeseen issues so it'll be a couple weeks I think. Need to get the downpipe and header ceramic coated and try to fix the oil leaks again.
I have the exedy stg 1 clutch back in it, so I don't think I'll be able to push it past 300wtq anyways I'll definitely post once it's done. 400/300 is the goal.
Old 03-12-2014, 09:01 PM   #1114
Brody602
Drift King
Brody602's Avatar
Not acceptable. I want numbers, NAAAOOOOOOOWWWW!
Hahaha, I was hoping for 450/350 but it seems like that might not happen unless I go even bigger haha
Old 03-12-2014, 09:07 PM   #1115
mike the snake
What oil leaks did you have? I had my car back and enjoying it for maybe 3-4 days before finding the turbo was leaking oil. It's out for repairs now. I think I've had every problem possible so far.
Old 03-12-2014, 09:11 PM   #1116
pmccut
Hose end fittings on both sides - oil cooler and sandwich plate. I replaced them with the ones LJ sent me 3-ish weeks ago but they still seem to be leaking (much less though). I definitely could've done it wrong. @Sterz mentioned his were replaced with XPR lines and are still leaking as well, so I really don't know what to do.
How the hell did the turbo go bad? How did you notice that?
Old 03-12-2014, 10:22 PM   #1117
mike the snake
I noticed a bit of smoke coming out the headlight after I shut the car off at night. Looking around, I found a small bit of oil on the skidplate and oil return line. I took it in and the shop tightened the AN oil drain line, but the leak remained, so I got the car on a lift myself and saw the oil was coming from between the two halves, where the iron and aluminum halves meet. Oil was seeping from there and burning and smoking. The car also was smoking during warmup.
I took it to my shop, they removed the turbo and confirmed it was the shaft seal.
No one has seen this happen on a turbo with this few miles (maybe 150-200 miles), it's just my luck.
It's being shipped out for repairs, hopefully it won't take long. I was really digging driving my car with good power.
The Following User Says Thank You to mike the snake For This Useful Post:
pmccut (03-12-2014)
Old 03-15-2014, 11:32 AM   #1118
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Anyone run the coolant hose to the turbo from the fitting near the driverside behind the head and the upper coolant passage under the manifold? Deleting the TB coolant lines. @King Tut is that how you did it?
Old 03-15-2014, 10:19 PM   #1119
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That is exactly how I did it. I essentially had the coolant route through the turbo instead of through the throttle body.
Old 03-16-2014, 12:35 PM   #1120
Reaper
Reaper's Avatar
Drives: violent
I wonder why they didnt run the coolant into the tb, out of the tb into the turbo, out of turbo into coolant passage under the manifold? @FullBlown ? That would have kept the heated tb and eliminated all the T's. I like our way @King Tut though.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
