Old 03-12-2014, 07:46 AM   #1
Victor Draken
Drives: Toyota Gt86
Update stock ROM (EU)
Hello!
I have ZA1JA00G as stock rom and I assume that the new rom would be A01G or 700G. How is it possible to update my stock rom to the new one?
I have read that the new roms are better in regards to the different issues find on the FA20 engine (DI failure, rpm dip, etc.)
Do I have to go to my dealer and say that I have some specific issues? Or should I just go there and ask for an update?
I don't know if my writing make any sense, I hope so.
Victor Draken is offline   Reply With Quote
Old 03-12-2014, 09:55 AM   #2
akyp
Drives: 2012 86
Last time I went in for a regular oil change I told them the car had rough idling and asked if there were any ECU updates. They said they would take a look for me and of course they did nothing about it and I still have my ancient 700G ROM. I too would like to know what conditions would prompt a dealer to update the ECU. Seems the TSBs are a USDM-only thing.
akyp is offline   Reply With Quote
Old 03-12-2014, 12:24 PM   #3
jamesm
The best way to make sure it's always up to date is to get a tune or flashing mechanism of some sort. For that purpose a $160 tactrix cable and ecuflash would do just fine.
Old 03-12-2014, 12:31 PM   #4
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Victor Draken View Post
Hello!
I believe you have an OFT. If that is the case, all our OTS maps for the G series ROMs have a A01G CAL ID. No need to do anything unless you want to your stock tune (original file) to be updated to A01G as well.
Shiv@Openflash is offline   Reply With Quote
Old 03-12-2014, 03:55 PM   #5
Victor Draken
Drives: Toyota Gt86
Yes Shiv I have one.
I have to check when I get home (1 week left), because I think that I have A00G CAL ID and when I tried to Upload the A01G bin file it didn't make me do it so I had to use the A00G bin file.
I'm not 100% sure, need to check the rom I have flashed in my car.
When I connected the first time the OFT it did upload a different CAL ID map that was opposite to the Stock CAL ID. (ex. I have A00G and it did automatically upload a A01G or viceversa) I tought it was a mistake so I just deleted all the files on the OFT and uploaded manually the corrected OFT map.
I'm quite a noob about these stuff, I'm just trying to have the most updated map, to avoid having any engine problem etc. Can't trust my dealer for shit, they have never dealt with a gt86 and don't even care much about it.
Old 03-12-2014, 04:07 PM   #6
Shiv@Openflash
Drives: 2013 FRS
That's fine. If you are running ANY of our OTS maps, you are running a A01 rom. Regardless of what the Cal ID says. It will still say A00G (or 700G or 900G) if you check in ECU Info section. But all our bins are based upon A01 ROMs.
Old 03-12-2014, 04:11 PM   #7
Victor Draken
Drives: Toyota Gt86
Oh that's great. So it doesn't matter what ROMs it lets me update, they are all updated one.
Any chances that we will get the new B01 rom?
Old 03-12-2014, 04:59 PM   #8
Shiv@Openflash
Drives: 2013 FRS
Yep that is correct. I'm doing some tests on the B01 roms but I'm not convinced there is any reason to update unless you already have a B01 rom. We have already incorporated an idle drop fix in all our A01 roms. And it's probably more effective (although less emissions friendly) than the approach used in the B01 rom.
Old 03-12-2014, 05:38 PM   #9
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Hey Shiv, curious - for those who have B01, do you still apply the A01 as a base map in the OTS? I'm sure your maps are very up to date in terms of function, just curious on whether the A01 or the B01 maps in OFT OTS form retain any of their native characteristics from factory or if they're completely overwritten by your modified A01.
Thanks.
1Cor10:23 is offline   Reply With Quote
Old 03-12-2014, 06:10 PM   #10
Shiv@Openflash
Drives: 2013 FRS
Thanks.
Those who have the B00 or B01 ROM do get OTS tuned ROM based upon a B01 ROM. So far I haven't seen any notable functional difference between them. The only difference being the A01 ROMs are slightly more defined, offering FFS and Launch control at this time.
Old 03-13-2014, 02:21 AM   #11
regal
Drives: Scion FR-S/Toyota Yaris
Simple question. I hate going to the 50 mile away dealer and waiting for hours.
My understanding is that they will now flash toB01 fixing the 2012 built cars.
simple up to date factory rom.
I want to do that in my driveway.
But it sounds like you are saying you either don't have this rom and must use a modified version of the last ROM.
Now correct me if I am wrom but this Motorola 32 bit ECU has thousands of tables and not all defined. The reason I was going to buy the OFT is simply to keep up with the factory calibrations at this point.
Why wouldn't you just give you customers (and potential ones) the pure 01B factory rom to flash?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-13-2014, 02:25 AM   #12
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
I believe he was considering this at one point, but it fell by the wayside when they updated all the roms.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-13-2014, 02:38 AM   #13
Shiv@Openflash
Drives: 2013 FRS
If there were more hours in the day, I would have done all the testing I needed to do and would have already updated all OTS maps to B01C. But I don't like making changes for the sake of changes without testing thoroughly. I understand people's needs to have things now. But if something doesn't go as expected, they aren't the ones that need to face the music. I have yet to see any functional difference between the A01C and B01C ROMs which makes this change more of a can-do than a must-do at this moment.
Old 03-13-2014, 03:03 AM   #14
regal
Shiv I like you and don't take this the wrong way but Toyota didn't change the calib for no good reason. Its the first cal update that they will flash on a 2012 build car that ought to tell you something right there.
You are confessing that its a huge time consuming task, so there could very well be some changes with B01c that improve the engine life.
Personally thought the whole business cass for OFT was for the customer to tweak the latest factory rom. But doing all this tuning, flex fuel, vortec, headers, etc.
I think there are a lot more people who just want to avoid the dealer and tinker than risk E85 and Vortec on this iffy engine. JMHO
Mods:
PS3 (GT6?) won't update 1.03 ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 3 01-22-2014 01:33 AM
Mod Update.... UM FRS CANADA 12 12-25-2012 01:50 PM
Module ECM update? dem00n Issues | Warranty | Recalls / TSB 1 12-21-2012 11:52 AM
HQTScion Rep Update on FR-S HQTSCION REP Southeast 0 06-06-2012 11:18 AM
GT5 2.0 Update!... MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 11 10-15-2011 02:53 PM
