#3935 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
It is a shame that the numbers don't show the full glory of the Phantomcharger and how it transforms the powerband. There is a lot more gained than one realizes from just
the end numbers. |
#3936 | |
Drives: Raven FR-S
Fenton since I am bored I will warm the ride up and take a video just for you. Look for in the next hour or so. |
#3937 | |
1)What are the effects on the vehicle of engagement of the ESC below 2000rpm with a tune? 2)Is there any intelligence built into the dump battery charging circuit or is it a standard constant current transitioning into a constant voltage? Will LiFePO4 battery charging be supported at some point? 3)Will there be controller updates that might require sending the controller back to Phantom? 4)What method is used to determine the ESC motor position at the moment it is engaged? Does this induce starting latency? 5)What is the true latency from engagement of the ESC to full boost at different engine RPMs? Please quantify with numbers. 6)Will proportional boost(motor) control be supported by Phantom? 7)Assuming an infinite power supply, what is the duty cycle of the ESC motor? |
#3938 |
#3939 | |
Sent from my HTC One using Tapatalk |
#3940 |
Drives: Raven FR-S
Only for you Fenton.
If you have time watch the entire video a couple of good pulls. Sorry for the shaky video and noise from the phone cradle. Also note the windows are down. Enjoy [ame="http://www.youtube.com/watch?v=0EZiTdEqI40"]Nameless 3" Header, Op/DP w/ Perrin CBE Exhaust - YouTube[/ame] |
#3941 | |
This is with the ESC as well correct? Did you end up getting a retune? |
#3942 | |
Drives: VW
2) Charging is regulated for SLA's and has de-rate fail safes. Show me a LiFE stack that is commercially available and is suitable/cost effective. 3) Always will support my stuff 4) Sensorless. No hall effect required. 5) 250 to 750 ms ... depends on battery condition and if a DR pre-spools it 6) Perhaps, but much higher boost pressures will need to be achieved. 7) Duty cycle of the entire system is balanced, I have no infinite power supply, but the controller/ charger units fail safes trump the compressor motor. I think FAQ's related to the present system would be beneficial ... as sub systems / revisions happen they will be added. Fenton. FAQ #1. Dump pack needs conditioning/ formatting ... ~ 4-6 hrs of total driving and cycling use. New batteries typically discharge @ 80% of capability. |
#3943 | |
Drives: VW
#3944 |
Drives: 2013 Asphalt 6spd
would it be safe to condition the batteries by sitting in the driveway with everything hooked up except the esc in hand, and then manually hitting the wot switch? I realize you would have to leave the factory intake pipe hooked up for this and have a friend to hold the esc or hit the switch. Then you could wait till it's fully charged, hold the switch till it's drained, then wait till it charges again and do it like 5, or 6 more times. Could you effectively condition the batteries in 10 minutes this way, or would you need a slower burn in or: quote "4-6 hrs of total driving and cycling use", to do it properly? I realize there would be no load on the esc, and this constant use could cause heat problems.
#3945 | |
Plus the heat of the engine by gets the batteries to their sweet spot as well. Sent from my HTC One using Tapatalk |
#3946 | |
#3947 | |
Thanks
#3948 |
Drives: WR Blue BRZ, 240Z
No doubt, both headers offer impressive performance. The advantage of the OFH is that it is paired with a tune for both the header and the ESC. That seems like a slam dunk...unless you were planning on going with another tuning option.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
