Old 03-11-2014, 01:39 AM   #519
CSG Mike
CSG Mike's Avatar
Originally Posted by glamcem View Post
It seems like I should be able to fit the OEM cooler in there though
Not to bash the JR cooler kit but I would rather use the OEM cooler for the following reasons:
  • ability to utilize radiator for cooling so with the upgraded radiator the oil temps can be increased or decreased accordingly (thermostat radiator)
  • one less item in front of the IC
  • Cost
other than that JR cooler looks pretty good and I am pretty sure it does what it's supposed to do
The OEM cooler is not quite enough
Old 03-11-2014, 04:49 AM   #520
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by ATL BRZ View Post
It actually mounts behind the IC alongside the Rotrex cooler.
yes, I should've looked closely and thanks for clarifying but still, it blocks some air that goes to the radiator
I wish we could compare the logs of the two options OEM vs air to air oil coolers so that we'd be able to tell how effective are the both units . I personally like the simplicity and the effectiveness of the OEM unit since it utilizes the size and functionality of the radiator. Having said that, I would like to get a bigger radiator (most likely a Koyo) and combine with the Oem cooler ..Since my car will be daily driven and will see some occasional track events, keeping the temps in ideal zone (not too cold in the morning) instead of cold all the time would be ideal imo.
In addition, it seems like the 2015 WRX will use the same OEM cooler (as I can see in the below pic). I think it should provide adequate cooling for the most part.. in the end, the whole reason I am getting a Rotrex unit instead of a turbo is to be able to fight with heat and heat related issues
glamcem is offline   Reply With Quote
Old 03-11-2014, 05:28 AM   #521
CSG Mike
CSG Mike's Avatar
It's the same reason track-going STIs replace the OEM cooler with an air cooler. It's suitable for some spirited driving, but not really for track driving, particularly when you also need to cool a turbo.
Old 03-11-2014, 10:12 AM   #522
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Maybe it's my lack of understanding, but I can't see how the OEM oil cooler is efficient enough to combat FI heat you get from multiple pulls and/or track days. Maybe I'm a noob, but you get all the real estate and rows of the satreb up front with more oil getting cooled than a small amount near the filter on the OEM... Maybe I'm not understanding how the OEM one works... Idk
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 03-11-2014, 10:54 AM   #523
*LongFella
*LongFella's Avatar
^ Great info! I'm always amazed on all the info and what I learn on this forum!
Old 03-11-2014, 10:55 AM   #524
*LongFella
*LongFella's Avatar
I'm so jealous of you Cali guys that can track all year round.
But our CA 91 gas SUCKS! lol
The Following 2 Users Say Thank You to *LongFella For This Useful Post:
CSG Mike (03-11-2014), sklimo (03-11-2014)
Old 03-11-2014, 03:07 PM   #525
CSG Mike
CSG Mike's Avatar
Originally Posted by normancw View Post
From the OEM oil cooler thread, it seems to work at the track for NA.
http://www.ft86club.com/forums/showt...27#post1362527
Not sure how it will do for FI, but I'll find out in May. I'm so jealous of you Cali guys that can track all year round.
The thing is, it's still approaching 235-240F, which is higher than even the cheapest oil-air oil coolers, AND you're adding more strain to the engine coolant.
Old 03-11-2014, 05:43 PM   #526
OrbitalEllipses
Drives: Attitude
Originally Posted by *LongFella View Post
So is there anything that comes down below the lowest point of the compressor housing?
@CSG Mike or anyone else?
Old 03-11-2014, 05:48 PM   #527
*LongFella
*LongFella's Avatar
Looking at it from the front, there is the bypass valve to the right under the exit tube of the rotrex unit...
Here is the best pic I could find that I took:
Is that what you are getting too?
Old 03-11-2014, 05:51 PM   #528
OrbitalEllipses
Drives: Attitude
Just trying to eyeball whether or not a certain longtube header would fit.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Calum (03-11-2014), CSG Mike (03-11-2014)
Old 03-11-2014, 07:19 PM   #529
MidnightRunner
MidnightRunner's Avatar
A certain header that will remain.. nameless, perhaps?
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
The Following 2 Users Say Thank You to MidnightRunner For This Useful Post:
Calum (03-11-2014), OrbitalEllipses (03-12-2014)
Old 03-11-2014, 08:13 PM   #530
OrbitalEllipses
Drives: Attitude
@*LongFella how much space would you say there is between the top edge of the crank pulley and the bottom of the Rotrex/lowest point on the unit (including the BPV - is it plastic?)?
Old 03-11-2014, 08:37 PM   #531
jamesm
Tuned one of these the other day... blew out the MAF immediately. How are you guys tuning these things without speed density (or on the stock MAP sensor since the kit didn't seem to come with one)? It's almost as if they designed the MAF to hit 5v right at redline on a stock car lol.
Old 03-11-2014, 08:49 PM   #532
CSG Mike
CSG Mike's Avatar
That would be accurate... it gets really sketchy around 4.85V, but then that's why the kit took this long to get to market right? >.<
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
