#855 |
That Guy
Drives: 2013 asphalt FRS MT
#856 |
Junior
Drives: a car
im stuck between the ST coilovers and the KW V1's. I cant really justify the extra $200 for the RCE T'0's although i know they are an amazing coilover.
Basically what im trying to get at is: The ST are corrosion resistant where as the V1 are corrosion proof. Given that I live in seattle, and its rainy 7/12 of the months here, snows on the occasion, is the corroision proof worth the extra bucks? Or go the ST route and save myself some money?
#857 | |
Drives: Vortech Supercharged FR-S
I got KW V3 and it is hard to find some good damper setup example. Seems like everyone is hiding their damper value.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
#858 | |
- Andy |
#859 |
Junior
Drives: a car
I asked my dad the same compairison, even though he isn't exactly a car guy, he said how the PNW doesn't get nearly enough salt on the roads to warrent the need for KW's...I hope he's right
#860 |
Drives: Subaru BRZ Limited M/T
Quick question on the Bilstein B8's.
Could I still use the OEM springs with the B8's and still be in CS class for autocross. Then next year buy the tarmac's and go STX Sent from my iPhone using Tapatalk |
#861 | |
Drives: 2015 WRX
How long do you plan on keeping the car? Is the savings of $200 worth the hassle of removing the coilovers if they do suffer from a corrosion failure? If you plan on keeping the car for more than 5 years are you ok with purchasing new coils if you do have a failure? (ST's only have a 5 year warranty, KW has a lifetime warranty) If it were me, $200 isn't enough of a savings to not get the superior product/warranty, but your values/goals may be different than me. |
#862 | |
i'm sorry, what?
Drives: Canada
B8's are most certainly fine.
#863 |
Someone needs to make sure they are identical to stock though...on the MINI for example the perches on a Bilstein B8 are 7mm lower front and 5mm rear. That would make it illegal for stock class if I'm not mistaken.
I don't know if the B8's are identical to stock or not. - Andy |
#864 | |
i'm sorry, what?
Drives: Canada
ohh boy, another thing to worry about
#865 | |
Senior Citizen
Drives: Scion FR-S
Bilstein B6 HD shocks are for OEM length springs. If you were to look to race in CS, you might just want to look to go with the B6's to start off with... |
#866 | |
Junior
Drives: a car
No the difference between the KW and the RCE T0 is about $200. They are both stainless. The difference between the ST (corrosion resistant) and the cheaper of the two Stainless Steel options is still $600+ more than the ST coilovers, which are already corrosion resistant. So basically its a savings of $600+ for the difference of SS vs. Galvanized steel.
#867 | |
Drives: 2015 WRX
Honestly it's a no brainer to me (T0's) but is your money. Plus the T0's have RCE's custom valving. |
#868 | |
Junior
Drives: a car
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
