#687 | |
Drives: Scion FR-S 2013 Raven
Finally, my setup will be : front hollow Hotchkis 25mm sway bar with the rear solid Whiteline 16mm with the brace and link. What do you think?
o= FR-S =o |
#688 |
Well our RCE bars are 25mm hollow front and 19mm hollow rear (equivalent to 16mm rear).
So...I bet you can tell what I think. ![]() - Andy |
#689 | |
B6 will definitely pair well with Yellows. I'm thinking B6 + RCE Yellows and B8 + RCE Tarmac springs will be the packages to get. When it comes to GTWORX struts we're just not sure at the moment. Bilstein having Sports for this car is good news for everyone but it means the market is much smaller for our own GTWORX/Bilstein struts. Whereas for WRX there were zero options other than hacking up your stock stuff for Konis. We'll see though. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Calum (01-24-2014) |
#690 | |
Drives: FR-S Whiteout
| The Following User Says Thank You to solidONE For This Useful Post: | DAEMANO (01-27-2014) |
#691 | |
I adjusted my camber in the front as far as I could. Probably have a little toe now, but nothing I can feel. Definitely an improvement on cornering that I needed. I'm aiming for the -2 though. |
#692 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Can you please give me a quick (but detailed if possible) overview and summary b/n the differences of V3 vs. RCE Tarmac II's ..(ie: spring rates, valving for use with?, which is better for motorsports, which is better for road/street, etc., etc).
Seeing how they are the same price and same manufacturer, I would love to know the difference. (or, links..if it's been already discussed). Also, I would like to know other people's preference of the V3/TarmacII coilovers vs. other coilovers in the same price range (which do you think/like more? the V3/TII or the others?). think I read before (when I was researching MonoFlex) that CSG (or some other people?), prefer the V3 over the MonoFlex. I am getting a bit interested in the V3 and RCE coilovers.. as I am finding out that many competitive racers and highly built 86's are using them (griffen trd, evasive, etc.). I want to know if the are specifically using KW/RCE because they are fantastic, or maybe if it's just because of sponsorship hoopkups. A list of which famous brz/frs racecars using KW/RCE coilovers would be welcome too ![]() In short: I want to hear the differences between the V3 vs Tarmac II. And also I want to hear your personal opinions of deciding between the V3/TII's vs. the others I am interested in that are in the same price ($2k'ish). Specifically, vs. the - MonoFlex and Ground Control kit |
#693 |
The differences between V3 and TII are exactly what the listings describe. Higher spring rates and RCE spec'd valving.
For more track focus the TII's are better, for a daily driver that might see the occasional lapping day the V3's will be more comfortable on the street. Both are great options, it really just depends on what your spring rate needs are and what fits you better.
#694 |
Ok... TII vs Monoflex vs GC kit? ....for track/autox/motorsports focus.
#695 | |
#696 | ||
That Guy
Drives: 2013 asphalt FRS MT
#697 |
Question mostly for Andy or Myles, but I'd love to hear from anyone that may have tested this.
What's the effective stock front spring rate when you factor in the bump stop in a typical corner?
#698 |
Drives: '13 BRZ Ltd
Racecomp - are your T2 struts slotted the same amount as V3's (i.e. is it the same body)?
#699 |
Drives: 2015 WRX
#700 |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
