Old 12-20-2013, 10:17 AM   #127
Dezoris
Dezoris's Avatar
Originally Posted by Amadeus View Post
Most Perrin tuned guys are getting approximately 240whp on Map 1 and about 250whp on map 3 or 4. Why are you getting 210whp? The dyno links below are on early tune files too - probably version 4 or 5 - so I would guess the newer tune files are at least as good if not slightly better.
http://www.ft86club.com/forums/showp...&postcount=401
http://www.ft86club.com/forums/showp...69&postcount=1
http://www.ft86club.com/forums/showp...0&postcount=17
When i dynod it was v10 map 1 made 210HP. Map4 made 240. But map 4 had knock.
Dezoris is offline
The Following User Says Thank You to Dezoris For This Useful Post:
Amadeus (12-20-2013)
Old 12-20-2013, 10:34 AM   #128
Dezoris
Dezoris's Avatar
Question
Originally Posted by FT-86 SpeedFactory View Post
No revisions, base line and went with it. 256WHP was the dyno on our local unit.
After logging it with out tuner here, it's definitely pig rich and could get a bit more out of but yet, it needs to be 100% reliable which it has done. We'll see how reliable it is once we start really pushing the envelope.
We will be heading west again for a couple FT86 events in 2014. Should come with us to one.
I definately plan on heading out there. Rollin together would be prime.
Surprised you never had Toni revise the tune yet but make sense if you have other plans.
Dezoris is offline
Old 12-21-2013, 11:41 PM   #129
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We're going in January if you need a winter get away.
FT-86 SpeedFactory is offline
Old 12-22-2013, 01:19 PM   #130
Dezoris
Dezoris's Avatar
Where are you heading?
Dezoris is offline
Old 12-22-2013, 01:23 PM   #131
FT-86 SpeedFactory
Going to try and make the 18th event if we can get everything to line up with another event we have to go to out in California. If not we're going to try and find some sort of track day event while out that way if we go later in the month.
http://www.ft86club.com/forums/showp...27&postcount=2
Old 01-21-2014, 09:46 AM   #132
mtsound
Hey guys I have a quick question about the APR gt-250 wing on your car.
Is it the 61 or 67 inch version? What is the height of the risers?
How is the performance on track?
I am thinking about adding the wing and a splitter for my time trial car.
thanks
mtsound is offline
Old 01-21-2014, 06:50 PM   #133
FT-86 SpeedFactory
thanks
It is the 61 inch. Risers are the ones APR sends with. I'd have to look. They designed this kit for the FRS, we got them on our website as well.
I'm liking the performance on track but I can tell it needs some front aero work as well now.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
mtsound (01-21-2014)
Old 01-21-2014, 08:56 PM   #134
mtsound
Thank you for the info that is exactly what I wanted to know
I am also looking for a front splitter, but there aren't many choices other than the APR splitter.
mtsound is offline
Old 03-11-2014, 12:28 AM   #135
FR-S89
Wow. wheels look superb! Are they still on fortune auto coils? any arms?
FR-S89 is offline
Old 03-11-2014, 09:41 AM   #136
FT-86 SpeedFactory
Still on Fortunes. Cusco rear LCA's.
Old 03-31-2014, 08:29 PM   #137
CB762
CB762's Avatar
Drives: Scion FR-S
I'm looking for good shop in Des Moines area that will do custom alignment and corner balancing. Any recommendation? TIA!
CB762 is offline
Old 04-09-2014, 05:56 PM   #138
FT-86 SpeedFactory
The Following 4 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
D_Thissen (09-17-2014), humanshield (04-09-2014), JonAvalon (04-09-2014), SkAsphalt (04-09-2014)
Old 04-09-2014, 09:58 PM   #139
humanshield
Drives: bucket
MOAR!
humanshield is offline
Old 04-10-2014, 05:05 AM   #140
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
For a second there I thought I was on a Lambo forum
UltraMarine86 is offline
Drop In Filter Dyno Results - FT-86 SpeedFactory FT-86 SpeedFactory Engine, Exhaust, Transmission 241 08-20-2018 11:22 AM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
FT-86 SpeedFactory - Exclusive Source for FR-S / BRZ / GT-86 Parts! FT-86 SpeedFactory Announcements, Contests, Giveaways 10 08-02-2012 12:50 PM
>>>KW V3 Suspension<<<< IN STOCK - FT-86 SpeedFactory FT-86 SpeedFactory Brakes, Suspension, Chassis 8 07-31-2012 11:50 PM
