Old 03-10-2014, 08:03 PM   #505
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Originally Posted by normancw View Post
I just ordered my kit from CSG
Thanks to @CSG Mike I'll just put off retirement for a little while longer and drive faster! Can't wait to get this on the track!
You are going to LOVE it!
CSG is a great shop to work with
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
The Following 2 Users Say Thank You to *LongFella For This Useful Post:
CSG Mike (03-10-2014), sklimo (03-11-2014)
Old 03-10-2014, 09:47 PM   #506
*LongFella
*LongFella's Avatar
Jackson Racing Rotrex Supercharger System Info and Discussion
@CSG Mike
I WIN!
Haha! You never said I had to be at cruising speeds and not stop & go traffic
On a side note, the temps are usually below 190 with normal driving (with a few hard pulls). It's a nice comfort knowing I won't have to deal with heat issues with this kit. ANOTHER WIN for Jackson Racing!
The Following User Says Thank You to *LongFella For This Useful Post:
sklimo (03-11-2014)
Old 03-10-2014, 09:52 PM   #507
CSG Mike
CSG Mike's Avatar
^ That's hotter than I've ever gotten the coolant on track with the kit on...
Old 03-10-2014, 09:56 PM   #508
*LongFella
*LongFella's Avatar
Hmmm... Maybe it's the stop and go traffic and never really getting any air flow through the front...
Old 03-10-2014, 10:11 PM   #509
utekineir
blowhard
Drives: frs, project forester
Scangauge work for boost?
utekineir is offline   Reply With Quote
Old 03-10-2014, 10:11 PM   #510
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
@CSG Mike , two questions....
any potential issues running the CARB tune with an aftermarket UEL catted header, specifically the FT86SpeedFactory catted UEL?
and can the JR oil cooler kit be ran without the JR SC kit?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 03-10-2014, 10:15 PM   #511
CSG Mike
CSG Mike's Avatar
The volumetric efficiency is altered, so you may have issues with the CARB tune. You have no torque dip with the SC anyways
The NA version of the oil cooler (different mounting solution) will be released soon.
sklimo (03-11-2014), smbstyle (03-10-2014)
Old 03-10-2014, 10:15 PM   #512
CSG Mike
CSG Mike's Avatar
Within the limitations of the factory sensors, yes.
Old 03-10-2014, 10:47 PM   #513
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by *LongFella View Post
SUCCESS! We have ignition. No code, idles nice, new Raceseng crank pulleys run smooth. Belt is perfect! Still need to put the driveshaft on, but I could notice (subtle) the revs were a little quicker and de-rev'd faster too.
Attachment 69750
looking at the pictures, it seems like I should be able to use OEM oil cooler with this kit unlike the KW kit , sandwich plate wouldn't fit in there.. I assume
glamcem is offline   Reply With Quote
Old 03-10-2014, 11:07 PM   #514
*LongFella
*LongFella's Avatar
Even if it could measure boost, I really wouldn't rely heavily on it.
I use my scan gauge as merely a "nice to generally know" where I'm at. I don't think it's 100% accurate, but gives me a good idea of where things are at...
Old 03-10-2014, 11:10 PM   #515
*LongFella
*LongFella's Avatar
It doesn't look like there is much room there...
The JR Oil Cooler is pretty hardcore and I'm impressed with the quality/fitment of it. The mounting points for both the rotrex and oil cooler are beautiful behind the intercooler. Even down to to JR logo
Old 03-10-2014, 11:19 PM   #516
glamcem
glamcem's Avatar
It seems like I should be able to fit the OEM cooler in there though
Not to bash the JR cooler kit but I would rather use the OEM cooler for the following reasons:
  • ability to utilize radiator for cooling so with the upgraded radiator the oil temps can be increased or decreased accordingly (thermostat radiator)
  • one less item in front of the IC
  • Cost
other than that JR cooler looks pretty good and I am pretty sure it does what it's supposed to do
Old 03-10-2014, 11:30 PM   #517
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
[*]one less item in front of the IC
It actually mounts behind the IC alongside the Rotrex cooler.
The Following User Says Thank You to ATL BRZ For This Useful Post:
*LongFella (03-10-2014)
Old 03-10-2014, 11:32 PM   #518
*LongFella
*LongFella's Avatar
B e a utiful!
The Following 3 Users Say Thank You to *LongFella For This Useful Post:
86-tundra (03-10-2014), CSG Mike (03-11-2014), sklimo (03-11-2014)
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
