Old 03-10-2014, 02:37 PM   #3907
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by xxBrun0xx View Post
Looks like a very cool project. Anyone have any insight as to lifespan of the batteries? As far as I understand, when you discharge and recharge batteries quickly, it cuts down on their max capacity. Can't wait to see how reliable these kits are and what effects they have on our engines over time. Great work so far, looks like a LOT of progress is being made!
I am pretty sure most if not all the testers have been running the same dump batteries for over a year now. Not all batteries are the same, and while I have not looked into it, I trust Rob did his homework before giving them the go-ahead. I believe these batteries were designed for this type of usage, and infact work better after conditioning them and "warming them up", with quick discharge/charge.
Target70 is offline   Reply With Quote
Old 03-10-2014, 02:41 PM   #3908
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I haven't looked at the specs in a while, but some batteries work best in high discharge applications. I believe this are those such batteries. With those batteries, they actually last longer being drained quickly.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Robftss (03-10-2014)
Old 03-10-2014, 02:48 PM   #3909
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
The SLA batteries used in the ESC can also be found in electric wheel chairs and other motorized vehicles. They are designed into these devices for their ability to survive deep discharge and fast recharges. They are low cost and light-weight. The ESC indicator provides the condition of the 28VDC bus. When it begins to not charge back up to 28.4-28.6 VDC AND discharges too long, it is time to replace them.
As far as I know, no one has gotten to this point yet. And when the batteries get to this point, a replacement pack is less then $100. It's analogous to belts and oil changes with other FI systems.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following 3 Users Say Thank You to Gary in NJ For This Useful Post:
DAEMANO (03-10-2014), Luckrider (03-10-2014), Robftss (03-10-2014)
Old 03-10-2014, 05:11 PM   #3910
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Clarkson is not a bad driver. He has excellent car control and is reasonably fast. He's no racing driver, sure, and his focus isn't always the fastest lap, sure, but he's probably faster around a track then at least 90% of this site's members.
Old 03-10-2014, 07:46 PM   #3911
Robftss
Drives: VW
Only ones posted are with the tq300 which isn't out yet and the header...none with the tq250 that comes with the kit and the header
Name:  TQ250 TQ300.JPG
This is the present (red line) TQ250 kit with OFH and 91 (Vishnu Facebook)
Blue is TQ300.
Robftss is offline   Reply With Quote
The Following 4 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (03-10-2014), Gums (03-10-2014), raven1231 (03-10-2014), robwbright (03-10-2014)
Old 03-10-2014, 08:20 PM   #3912
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by Robftss View Post
Attachment 70012
Blue is TQ300.
Mmm. Thanks. Well, I think I can live with 209/189 at the rear wheels.
That's what, about 250/215 if measured at the crank?
Was the max on the TQ250 with 91oct about 205/180? If so, that's not that big a jump for the header, but there's obviously more to it than just the peak HP/TQ.
robwbright is offline   Reply With Quote
Old 03-10-2014, 08:25 PM   #3913
fenton
I'm not certain if that had the header though. We will need shiv to confirm for sure because there was a lot of stuff all posted at the same time.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 03-10-2014, 08:30 PM   #3914
robwbright
Pretty much my opinion based on what I've seen of his driving... which is why I can't figure out why I can pull a 0-60 nearly a second faster than he apparently can...
The Following 2 Users Say Thank You to robwbright For This Useful Post:
DAEMANO (03-10-2014), raven1231 (03-10-2014)
Old 03-10-2014, 08:43 PM   #3915
raven1231
Attachment 70012
Blue is TQ300.
Thanks sir
Old 03-10-2014, 08:50 PM   #3916
EAGLE5
Dismember
EAGLE5's Avatar
Depends on how hard you want to abuse the car, surface condition, atmospheric conditions, and a ton of other factors. You know that some cars are stronger than others.
Old 03-10-2014, 09:41 PM   #3917
robwbright
Oh, I know, but 1 full second stronger? My conditions were barely above freezing on stock tires - hardly ideal.
And if spinning the rear tires a bit is abusing the car, then I certainly did. But I hardly dumped the clutch and I only made about 6 or so runs total.
Old 03-11-2014, 12:52 AM   #3918
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by LBC Por Siempre View Post
Clarkson IS that bad of a driver. The only thing he knows how to do is drive a car sideways and perform donuts on factory fresh tires. Don't get me wrong I love his personality and all three of the group on the "Top Gear" show have, I say - and for me, the beat cohesion out of any other men's talk/test/whatever show in the English speaking world. That is why I hate the American version of Top Gear so much. The guys on the show just don't go together. They could keep the guy with the beard. But get rid of the others. And make Patrick Long the American Stig.
I'm good friends with Tanner. Known him for over 10 years back when he was a Evo VIII customer. Our mutual friend Paul Gerrard did some of the driving for Top Gear UK (the episode where they drove super cars around NYC). Paul was Clarkson's uncredited driving double (in the 458). I don't believe any of the UK drivers are especially quick. Nor do they really have any reason to be. But Tanner is fast as hell in anything you put him in. I just wish the did more stuff in TG US that took advantage of the that. Oh, and I think I know who the American Stig is (no, it's not Tanner)
Shiv@Openflash is offline   Reply With Quote
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (03-11-2014), Gary in NJ (03-11-2014), Sojhinn (03-11-2014)
Old 03-11-2014, 01:06 AM   #3919
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Damn that wAs my guess. Onto the next rockstar member for my guess now
Installed Mods:
Old 03-11-2014, 07:37 AM   #3920
WNDSRFR
Drives: FR-S,GTI
And he IS pretty heavy.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
