Old 03-08-2014, 03:30 PM   #1
Maruthas
Drives: SWP BRZ
hydro dipping silver interior trims
what do you guys think? better than wrapping it.. i think.
but! never done hydro dipping.. any thoughts?
Maruthas is offline   Reply With Quote
Old 03-09-2014, 11:26 PM   #2
kanundrum
Drives: 2013 Whiteout FR-S
While Hydrodipping is a cool process the results and longevity of the dip does not stand up to toughness at least in car parts
Old 03-09-2014, 11:45 PM   #3
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
^ Source? I've seen people dip valve covers with great results. I imagine if it can hold up on a valve cover, it'll work just fine on interior trim.
sdemo is offline   Reply With Quote
Old 03-09-2014, 11:49 PM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
It's the same as waterborne base coat. Which is basically what every body shop in the state of md is using on cars
Old 03-09-2014, 11:55 PM   #5
kanundrum
Saw a few posts somewhere on the interwebs as I was looking into it, but basically if its a surface that has a lot of contact with anything it will fade over time.
Old 03-09-2014, 11:55 PM   #6
kanundrum
Durability against something like constant contact?
Old 03-10-2014, 12:15 AM   #7
spitfire481
Drives: 2JZ FRS
It has to be clear coated. Either straight clear, or clear with a flattener mixed in. Base coat itself is not durable at all, waterborne or solvent based
The Following User Says Thank You to spitfire481 For This Useful Post:
kanundrum (03-10-2014)
Old 03-10-2014, 01:09 AM   #8
kanundrum
Yea I guess that is what I was looking at, seems like a lot of trouble compared to wrapping a part.
GI: Hydro dipping Rims - Toronto Area Hamza7 CANADA 24 03-03-2014 05:01 AM
Plasti-Dip Interior Trims br0nc0boy Southern California 10 02-18-2014 03:43 PM
Full Silver Interior Superhatch Interior Parts (Incl. Lighting) 16 10-09-2013 08:37 PM
Anyone tried hydro dipping before? Frs300 Cosmetic Modification (Interior/Exterior/Lighting) 14 07-07-2013 03:29 PM
Silver interior trim removal for plasti-dipping ph0en1xtk Cosmetic Modification (Interior/Exterior/Lighting) 1 10-06-2012 10:54 AM
