Old 02-16-2014, 12:35 AM   #15
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Extreme86 View Post
17 x 8 35s with 225 PSS in the polished finish (stock suspension):
Do you have a link to his/her build thread? I want to see a fill pic of this car with the wheels on
Astroboy is offline   Reply With Quote
Old 02-17-2014, 02:24 PM   #16
Doughboy
Drives: 2013 FRS, 1993 Toyota FZJ-80
19x8 235/35 Nittos
Doughboy is offline   Reply With Quote
Old 03-09-2014, 12:29 AM   #17
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Thinking about getting the 17x8 +35 Nurburgring's, can anyone tell me what the widest tire is that I can get on them with no bulging issues? I wouldn't mind a 245/35/17, also can anyone tell me if the caliper clearance is either the same if not more than stock? I have plans for a wilwood bbk, which will fit with the stock wheels, so aslong as these have the same or better clearance I'll be good!
@trevorovert maybe you can help me out?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-09-2014, 01:08 PM   #18
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Hmmmm. It's hard to say. I think you'd be fine with 245s, won't bulge really, but I can't speak for any clearance on the calipers. I would honestly doubt you would have any issues because of the +35 and +1" you're adding to the offset. And if you did, you could just throw a 5 or 10 mm spacer on it. But yeah if you are putting breaks that fit in the stock wheels you will be perfectly fine.
86-tundra is offline   Reply With Quote
The Following User Says Thank You to 86-tundra For This Useful Post:
Brody602 (03-09-2014)
Old 03-09-2014, 01:17 PM   #19
Brody602
Drift King
Brody602's Avatar
Yeah, the Wilwood's fit with the stock wheel, so as long as there is the same or more clearance with these I think these will be my wheel of choice, fairly light weight, affordable, nice design!
I might settle for the 235's, but if once I go FI, my goal is 450whp which I intend on achieving, so the wider the tire the better :P
Thanks for the insight !
Old 03-10-2014, 11:58 PM   #20
PNW FRS
PNW FRS's Avatar
17 x 8.0 / 35 TSW Interlagos
17 x 8 / 35 offset (sq.) TSW Interlagos Wheels / Mich PSS 225/45/ZR17 / Stock suspension
Temperatures are on the rise in SW Washington... so finally swapped OEM out... snow tires will eventually go on OEM wheels.
Front-left
Left-rear
Left-rear
Props to the Discount Tire in Lacey... they had me in and out in 30 minutes... and it might have been quicker, but once the rig was up on the hoist, most of the staff suddenly had something "to do" at that hoist. Cost: $0 -- what better way to start a Saturday?
Post swap note: TPMS light came on about two hours later during a drive (as the DT employee had cautioned, "Might happen..."). So, went back (per his instructions) and they re-did the sync of the TPMS with the ECU - took about 10 minutes. Thanks DT.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 01-03-2016, 05:23 PM   #21
bhmax
Drives: 13 BRZ, 17 Focus RS
I bought these in gunmetal last year for a WRX. I just put some winter tires on the stock wheels on it. Figured I'd throw these on the BRZ to see how they look. 235/45-17 Bridgestone S-04 and stock suspension.
bhmax is offline   Reply With Quote
Old 01-02-2017, 04:59 PM   #22
WorldRallyB
Performance Ricer
Drives: 19 WRX, 19 ND2
TSW Nurburgring 18x8.0 +35 on 245/35-18 stock height
ask if you'd like to see more..
WorldRallyB is offline   Reply With Quote
Old 04-28-2017, 11:16 AM   #23
Hazeypoo
Drives: Ultramarine FRS
Can you show me these from the front? Im trying to see how much they poke or if they do.
Hazeypoo is offline   Reply With Quote
Old 04-28-2017, 11:38 AM   #24
WorldRallyB
Performance Ricer
That picture was at stock height, im now 1" lower on eibachs. This image might help, i dont have a good front shot on hand. On 245 wide tires its almost perfect, no poke at the top of the fender. If you dont mind waiting ill get more pictures in a couple days
Old 05-01-2017, 11:45 AM   #25
WorldRallyB
Performance Ricer
Here you go, looking directly down the side of the car the top of the fender lines up exactly with the face of the wheel. You'd have more taper in the wall of the tire if you were on 225s, im on 245s
Old 10-05-2017, 07:19 PM   #26
Hazeypoo
I wanna get these.. Hmmm how have they held up to use? specifically directed towards more spirited w minor abuse type of driving.. that's if you drive that way at times. haha.
Old 10-06-2017, 01:23 PM   #27
D3nali
Drives: F-RS, FJ Cruiser
These hold up very well, I am happy I purchased these for looks and quality. I am running the 18x8, they go through a ton of abuse and have performed above my expectations.
D3nali is offline   Reply With Quote
Old 01-20-2019, 08:43 PM   #28
Dumpster Dan
Drives: 2018 BRZ PP
Has anyone fit the 17x8 +35 Nurburgrings on a performance package BRZ? Or is anyone willing to check their wheel against a brake clearance template that I made?
Dumpster Dan is offline   Reply With Quote
Wheel Directory: TSW Nurburgring 17x8.0 +45 post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 04-28-2019 07:17 PM
TSW Nurburgring Mickeyt86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-05-2013 04:04 AM
XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop AGM6789 AUSTRALIA 17 11-10-2012 05:10 AM
TSW Nurburgring usptwins Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 10-17-2012 11:02 PM
TSW Nurburgring Zoomie Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-26-2012 02:41 PM
