| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2013 FR-S Whiteout
Forgestar F14 vs. Work Emotion CR-KAI
Any opinions on which of the two wheels look better cause I am torn between the two? The work emotions seem impossible to find so I was thinking of replacing them with the rota torque but none the less, split 7 poke or split 5 poke I cannot decide!
#2 |
Kouki-Monster
I resent my F14's simply because almost nothing for lug nuts fit. Even with the smallest Muteki spline type lug, the key will eventually damage the holes. I even got the smallest profile inside-hex lug nut ... which wasn't quite small enough to not rub the sides.
Keep looking, there's a lot more wheels that fit what you are looking for. Don't bother with Rota, buy from a company with some originality that has also truly earned their certifications for spec.
Rich Anderson
EMPOWER AUTO |
#3 |
Drives: WRB LMTD '13
maybe enkei?
#4 |
Drives: WRB BRZ
Aren't F14s much cheaper and are actually forged and not cast? Two good reasons there.
#5 |
Thanks
#6 |
Drives: WRB BRZ
Care to explain?
#7 |
Drives: 2013 Subaru BRZ Limited (CBS)
Indeed. Please explain! Inquiring minds want to know...
#9 |
Drives: Subaru BRZ Limited
I think the F14's look much better.
#10 |
Drives: 2013 Scion FR-S - Argento
#11 |
Drives: 2013 FRS
Oops double.
Sent from my SGH-T999 using Tapatalk 2 Last edited by Slash; 03-09-2014 at 11:34 AM. |
#12 |
Drives: 2013 FRS
Me too.
Sent from my SGH-T999 using Tapatalk 2 |
#13 |
Drives: 04' Saab 9-5 Aero
Essentially this, the original cast wheel is heated, and then compressed with rollers into it's final width and offset, so it's a hybrid of forged and cast. Which is A) why they are so light for the size they come in and B) why you don't pay $4000 for a set of wheels
#14 |
Drives: 2003 Subaru Outback
I like forgestars because they are all custom. You can run the proper offset so you don't have to run such ridiculous camber. People running 18x9.5 +30's should look into these.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
| WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** | RavSpec | Wheels and Tires | 18 | 12-10-2013 06:19 PM |
| 18x9.5 +38 Work Emotion CR kai Work Metal Buff | Jive Turkey | Wheels and Tires | 22 | 05-20-2013 02:54 AM |
| Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts | serial gixxer | Wheels and Tires | 41 | 03-29-2013 04:14 AM |
| Wheel Directory: Work Emotion XC8 18x?.? +?? | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 09-14-2012 02:42 AM |
| Work Emotion CR Ultimate BRZ ad | Hanzo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 07-18-2012 02:59 AM |
