Old 02-18-2014, 11:57 PM   #2829
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by Bigmaxy View Post
3000 Km's. 5psi boost. Ceramic coating peeled so they were sent to be recoated. Thanks
Sent from my GT-I9505 using Tapatalk
How old is your header ?
Was it recent ?
Sent from my IBrick
Old 02-19-2014, 12:00 AM   #2830
Bigmaxy
Drives: Pegasus GTS86
No. One of the first ones. I understand the ceramic coating only affected the early units. I would have expected to be able to pull headers off and still expect them to be flat. I only thought to check them due to this thread. May have been like that from the start. Dont know.
Bigmaxy is offline   Reply With Quote
Old 02-19-2014, 03:11 PM   #2831
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
I've been out of the loop for a long while. What sort of power can be reasonably expected with an AVO stage 2 package on 94 octane with a full turbo back exhaust?
Nolan
pheoxs is offline   Reply With Quote
Old 02-19-2014, 03:20 PM   #2832
AVOturboworld
With the standard disclaimer of "depends on tuner/exhaust/setup" a general stage 2 with full 2.5" exhaust should look like this:
8psi actuator, 2.5" exhaust, stage 2 base tune"
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
pheoxs (02-19-2014), SkAsphalt (02-19-2014)
Old 02-19-2014, 03:22 PM   #2833
Colombo
Drives: '13 BRZ
What's the release timeframe on the stage 3 kit? Any ideas on pricing yet?
Colombo is offline   Reply With Quote
Old 02-19-2014, 03:44 PM   #2834
AVOturboworld
I've got some 3" systems heading towards me right now. I'll fitting one, doing install instructions and hopefully video of the install, and then will be doing performance testing (on USA 92 octane pump gas). Generally, that should be from early next week. We will be releasing the pricing and approx. ETA for any orders/pre-orders at the same time.
Pete156 (02-20-2014), SkAsphalt (02-19-2014)
Old 02-19-2014, 04:27 PM   #2835
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The header exhaust leak: fixed with all future kits now? Or is it just a simple hack with an added washer that will hold for a really long time?
Old 03-08-2014, 12:14 PM   #2836
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Originally Posted by AVOturboworld View Post
Stage 3 testing on the AVO Turboworld Japan BRZ
We've been hard at work here at AVO on a variety of projects, with possibly the biggest one right now being the Stage 3 upgrades for the AVO BRZ/FR-S turbocharger kit. Our Stage 1 turbocharger kit has been incredibly popular worldwide, and has made a lot of people very happy by bumping the power up dramatically, from 165whp to 260+whp. Yet some people want more, much more, and we've listened to their requests.
It would have been easy enough to just up the boost and get a few glory runs on a dyno, but we are far more committed to our customers long-term enjoyment than that. We wanted Stage 3 to be as reliable as possible, with all the high-quality engineering and attention to detail that has been a trademark of AVO for the last 40+ years.
To this end, we spent a considerable amount of time and testing on our fuel pump upgrade, as the car was already starting to reach the limits of the pump at 300whp, and we were planning to go much further than that. After much time and effort, we have now got a full bolt in, no fitment compromise fuel pump that does not require any re-wiring or dremelling. It clips right in to the assembly, and doesn't require you to have the fuel filter mashed up against the bottom of the pump housing. The standard wiring harness will clip right into it as well, and it doesn't require additional O-rings to seal up.
Matched up with that is our upgraded Port Injectors. These were also designed to fit to the BRZ/FR-S, with the longer "neck" on it so that they reach down into the intake system and spray properly, unlike some other "short" designs that merely let the gas puddle down. Put these together with the fuel pump, and we now had the fueling to push the engine further.
But why so much extra fuel? Because we upgraded the turbocharger as well! The Stage 3 turbocharger utilizes a new billet compressor wheel with a more efficient design. While the overall size of the turbocharger hasn't changed, the flow has improved dramatically enabling us to push it harder at higher boost levels. This allows up to bump up the peak horsepower available while keeping the impeccable low-end torque that makes this turbo kit such a pleasure to drive.
The final piece of the power puzzle is the complete 3" exhaust system that will come with this kit. We don't mean just from the cat-back, no, this exhaust is 3" from the turbo charger exhaust housing back. The turbo discharge pipe and crossover pipe have been re-designed to provide maximum flow from the turbo all the way back.
As part of the testing we recently put the Stage 3 kit through it's paces at the RevSpeed Super Battle Time Attack at Tsukuba Circuit. It went very well, with the car going roughly 1.5 seconds faster around the circuit on the exact same tires as earlier in the year. Power through the corners was very well controlled, and it was a rocketship exiting the corners and on the straights.
Immediately after the event we put the car on the dyno to see how it was doing at the race settings. Power was quite impressive, with 373whp on tap at 6400rpm, and a peak of 318ft/lbs of torque at 4800rpm. Even more exciting is how it was doing 290ft/lbs of torque from 3300rpm. This is a quick-responding turbo!
We are still undergoing testing, but expect to see this available soon from AVO!
Any updates on this, Paul?
Pitman is offline   Reply With Quote
The Following User Says Thank You to Pitman For This Useful Post:
CxG (06-25-2016)
Old 03-08-2014, 02:20 PM   #2837
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Last time I PM'ed Paul, he said it was coming out in a month actually. And significantly more than stage 2
The Following User Says Thank You to cdrazic93 For This Useful Post:
Pitman (03-08-2014)
Old 03-10-2014, 11:41 PM   #2838
BRZranger
Lol, I did ask him about this as well... Nothing confirmed yet for arrival, just hopes that it comes out soon...
BRZranger is offline   Reply With Quote
The Following User Says Thank You to BRZranger For This Useful Post:
cdrazic93 (03-10-2014)
Old 03-10-2014, 11:45 PM   #2839
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Its unfortunate that it will cost more than stage 2 ugh, makin me want more and more expensive things...DAMN YOU PAULLL
Old 03-11-2014, 12:28 AM   #2840
BRZranger
Nothing wrong with stage 2, more than adequate! Let us be the guinea pigs for stage 3! I contemplated this myself, since stage 1.5ish has been very reliable and plenty of power.
By the time you upgrade to 3, I'm sure someone will be selling a used 3" exhaust OR AVO will have them in stock!
Old 03-13-2014, 04:41 PM   #2841
WhiteRose
Drives: 2013 Genesis Sedan
AVO Stage 1 Turbocharger Kit for the 2013 Subaru BRZ and Scion FR-S 2.0!
Quick question was the tomei 3" exhaust a catback? Header back? Turbo back? Because I was thinking going avo turbo with cats on so I may have a chance to pass smog
Sent from my SM-N900V using Tapatalk
WhiteRose is offline   Reply With Quote
Old 03-13-2014, 04:48 PM   #2842
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You're a terrible person for quoting all of that.
Tomei is a full exhaust, it replaced another full header back exhaust.
The Following 5 Users Say Thank You to SkAsphalt For This Useful Post:
DoctorNick (03-13-2014), ill86 (03-13-2014), nataku (03-13-2014), Skorov (03-13-2014), Sportsguy83 (03-13-2014)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
