Old 03-07-2014, 10:24 PM   #3809
tendogy
Originally Posted by normancw View Post
Thank you for this post and your similar post in the Kraftwerks thread as well! Any plans to read the Vortech thread, lol?
You're welcome! I plan to do this for the Vortech and Jackson Racing threads as well.
I have updated the original post based on the clarifications by kit owners.
tendogy is offline   Reply With Quote
Old 03-07-2014, 10:40 PM   #3810
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by CK_Bladesmith View Post
My fuel mileage is absolutely terrible now. Around town I use to get 250+ miles per tank before a fill up when I was NA.....now I'm lucky to get 170-200, and I'm not constantly in the boost either.
Unless you have a heavy foot since installing the SC, in theory your fuel consumption should not change much under normal driving.
I'm getting better consumption since installation and in fact run less than most stock 86 in my area.
By the above that's driving conservatively and changing gear when the car indicates.
21 mpg normal driving = 7.5L/100km
30 mpg harsh driving. = 13 L/100km
Hope I got my conversion correct
Ryan86 is offline   Reply With Quote
Old 03-08-2014, 06:19 AM   #3811
Kodename47
Kodename47's Avatar
Drives: UK GT86
If I go by my display, on a mixture of driving NA I managed an average of 40-44mpg. Now I get 32-34 mpg. Thats UK temperature and roads etc.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-08-2014, 06:23 AM   #3812
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I'm in south Texas so weather is pretty mild this time of year. I can fill my car up, drive to my woman's house which is 13 miles away (highway miles) then drive back to my house, not getting on the throttle at all, and be close to 3/4 of a tank.....it might be 30 miles total drive. I don't know why my mileage sucks so bad.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 03-08-2014, 10:01 AM   #3813
Calum
That Guy
Drives: 2013 asphalt FRS MT
That's using the imperial gallon. In US gallons that's 33.3 - 36.6 mpg.
Old 03-08-2014, 10:05 AM   #3814
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
In the middle of installing - did everyone have to remove the fuel hard line on the drivers side? The instructions don't mention needing to remove this. Wondering if there's another way.
mikalem is offline   Reply With Quote
Old 03-08-2014, 02:02 PM   #3815
olorin
olorin's Avatar
Drives: GBS Premium
Yes, I couldn't remove the cover without doing this.
olorin is offline   Reply With Quote
Old 03-08-2014, 05:39 PM   #3816
mikalem
mikalem's Avatar
Can anyone tell me what the small plastic hose is that goes from the back of the supercharger to the bottom of the throttle body intake, just past the butterfly? Had a small problem during the install and this line snapped the plastic - wondering what its purpose is - can't find any schematics on it at all.
Old 03-08-2014, 05:50 PM   #3817
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Plastic on the intake arm or on the back of the blower? That's the PCV hose (one of them....)
Xero-Limit is offline   Reply With Quote
Old 03-08-2014, 05:52 PM   #3818
mikalem
mikalem's Avatar
Its the small clear plastic tube that was pre installed on the blower. It snapped right at the point the tube has a plastic elbow into a circular plastic piece.
Old 03-08-2014, 05:59 PM   #3819
mikalem
mikalem's Avatar
This the tube I'm talking about (hopefully this attaches)
Old 03-08-2014, 06:03 PM   #3820
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Hate to brake it to you. But that's the pneumatic cylinder for the bypass valve. You might as well take the blower back off and return to stock because you aren't running with that broken. Probably need a new one. That black round thing attached to the manifold just past the butterfly.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 03-08-2014, 06:05 PM   #3821
mikalem
mikalem's Avatar
An entire blower? Was looking to see if they have a sub assembly that can be replaced. Not good.
Old 03-08-2014, 06:12 PM   #3822
Xero-Limit
Xero-Limit's Avatar
It's a standard eaton type actuator. You can probably get one from Innovate, if not then search around. One of the guys here used a buick one to do a custom WMI bypass. Not the end of the world, but definitely no road trips until that's fixed.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
