#3683 |
Drives: 2013 Raven Black FRS
Very nice!! Love seeing quality fabrication!
#3684 |
Drives: 13 BRZ WRB
could it be a plug for the sound generator hose in the intake elbow?
#3685 |
#3686 |
Turning is for Nerds
Drives: 35 characters is not enough
Maybe the header comes up into that area? I have not yet seen any pics of it installed, but it looks like that may be the case.
#3687 |
Grip>Slip
Perhaps it interferes with the header piping that comes up to the engine bay?
I'm not so much worried about the plug, i'm sure they can tell me where that goes pretty easily. I'm more concerned about the rumored 9-12" lifting of the motor. 1-2" for the overpipe is one thing, but 9-12? That's HUGE. |
#3688 | |
#3689 |
Fanboy
Drives: 2013 ultramarine frs
There is simply no way you have to lift the engine that far if at all for this header. Whoever told you that is fucking with you
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#3690 |
Drives: Raven FR-S
Sits more like 4" in front and 3-6" above the crank pulley.
#3691 | ||
Grip>Slip
For those who have (or might have) similar questions over the next couple days, here was the response: Quote:
#3692 |
Drives: 2014 SWP BRZ Limited
John just sent that to me as well, but here it is
"The plug is to block off the resonator on the factory intake just before the throttle body on the bottom of the runner hose that attaches to the intake. Installation is simple. Unbolt the passenger side engine mount and lift the engine up (leave the driver side mount attached) until the passenger side stud is about 1/4" above the surface of the subframe. Remove the factory manifold, then install your new manifold. The new one fits in, it just goes in a very specific way that you have to find by putting it in and moving it around. Reuse the header gaskets that you took off with the factory manifold." -Ryan @ Nameless |
#3693 | |
Drives: the girls crazy
ouch
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
#3694 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
The way the header is shaped, it certainly looks like it could, or at least come close enough to melt the plastic since the resonator on the underside of the intake tube hangs down a good 3-5 inches.
#3695 |
Drives: 2014 BRZ, 08 CBR600RR
Engine mounts don't need to be loosened to install. I just unhooked the passenger side fan connection and moved it out of the way and moved the overpipe back a few inches and it cleared just fine.
Don't mind the iPhone pics. Install was pretty easy and the header is pure porn
#3696 |
Fanboy
The fan looks alarmingly close... Seen turbo manifolds melt those, but presumably they also get much hotter.
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 02:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 10:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-18-2012 11:32 PM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 04:32 AM |
