Old 03-07-2014, 07:03 AM   #1
Noz
Drives: Ultramarine Blue FR-S
GT86 Headlight Conversion
I recently bought the left hand drive GT86 headlights from nigel-jdmparts.com and had them installed recently by Tommy @ Musicbox located in El Monte. The headlights came with factory ballast and bulbs. I had the LED DRL wired so they stay on 100% power. Came out great so I just wanted to share.
This thread led us to the correct direction for rewiring the harness.
http://www.ft86club.com/forums/showt...ight=headlight
The LED DRL wire I believe was connected to the ignition part of the fuse in the fuse box under the hood. You can see the black wire where it's hooked up. So the DRLs turn on when I turn the key, regardless if the headlights are turned on or not.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Here's some pics installed. I may have Tommy rewire it so the DRLs work how it should factory wise, where it dims to 50% when the headlights are turned on. It's pretty damn bright at night. Also, I'm probably going to swap out the bulbs to 6000K to match the rest of the lights.
Here's some pics of them installed.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Noz is offline   Reply With Quote
The Following 3 Users Say Thank You to Noz For This Useful Post:
Dadhawk (04-14-2014), FRSGT86 (04-15-2014), nigel-jdmparts (04-14-2014)
Old 03-07-2014, 07:37 AM   #2
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
Very nice indeed!
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
Calavera is offline   Reply With Quote
The Following User Says Thank You to Calavera For This Useful Post:
Noz (03-15-2014)
Old 03-07-2014, 02:45 PM   #3
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
MORIMOTO D4S XB35 XENGREEN comes in three flavors at Lightwerkz and TRS
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
Noz (03-15-2014)
Old 03-07-2014, 07:48 PM   #4
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
Looks excellent!!!
MPI_Jack is offline   Reply With Quote
The Following User Says Thank You to MPI_Jack For This Useful Post:
Noz (03-15-2014)
Old 03-15-2014, 04:17 PM   #5
Noz
Thanks fellas. Diggin the theme you got going on your car MPI Jack. Looks great!
Old 03-15-2014, 07:44 PM   #6
MPI_Jack
Thanks man!
Old 04-14-2014, 04:26 PM   #7
nigel-jdmparts
nigel-jdmparts's Avatar
Drives: 86
http://www.ft86club.com/forums/showthread.php?t=63344
These will be the best lol
nigel-jdmparts is offline   Reply With Quote
Old 04-14-2014, 05:16 PM   #8
Skurj
Drives: SOLD...
The GT86 lights just make sense.. saw an FRS with them tonight while omw home from work the car looked awesome.
BTW.. don't mean to derail Noz but what are the rims and tires you have on that car!
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
The Following User Says Thank You to Skurj For This Useful Post:
Noz (04-15-2014)
Old 04-15-2014, 05:38 AM   #9
Noz
They are Enkei RS05RR. 18x9.5 +43 square setup. The tires are Falken 453 255/35/18.
Old 04-15-2014, 10:30 PM   #10
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
Those look really good!
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
Old 04-16-2014, 01:48 PM   #11
DarkCard
Drives: Asphalt Scion Frs 6MT
Please tell me that wire is temporary and you aren't leaving it like that?
The lights look great though
DarkCard is offline   Reply With Quote
Old 04-16-2014, 02:00 PM   #12
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Your electrical-fu is very weak. Do it right before you burn your car down. Mini Add-A-Circuit
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following 3 Users Say Thank You to Acree For This Useful Post:
86-tundra (07-23-2014), sshole (04-16-2014), wheelhaus (04-16-2014)
Old 07-22-2014, 11:35 PM   #13
dchan8
Drives: Toyota Celica
Noz - I'm thinking if buying the same headlamps. Did you have to re-pin the lights or was it direct plug and play? Any help is appreciated
dchan8 is offline   Reply With Quote
ZN6 Headlight DRL switch back Conversion lvl up Cosmetic Modification (Interior/Exterior/Lighting) 7 11-14-2013 09:05 AM
FR-S to BRZ Headlight Conversion? tdoggy57 Cosmetic Modification (Interior/Exterior/Lighting) 7 01-30-2013 02:28 PM
Headlight conversion? Noz Cosmetic Modification (Interior/Exterior/Lighting) 14 01-09-2013 03:18 AM
JDM Headlight Conversion, anyone do it yet? HATED1 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-11-2012 09:51 PM
