Old 03-07-2014, 12:11 PM   #1317
jamesm
Originally Posted by ecko04 View Post
It's ok. It's not that it won't work or can't work, it just takes time to get dialed in. A lot of time, probably more than a single dyno session can do. Make sure you have a cable and dongle so you can log and have periodic updates performed until it's fully dialed in. That's the best way that I found that worked.
if you're tuning closed-loop MAF on a dyno, that's your problem not the hardware . it can be done on a load dyno, but that would be a colossal waste of money. closed-loop MAF tuning is best done on the street, since street time is free and the key to getting it right is lots of data, and lots of data takes lots of time to collect. also IAT's on the dyno can skew MAF readings considerably compared to what you'll actually see out driving, basically invalidating any data collected while stationary.
i agree though it's a perfectly serviceable design, you just need to get the MAF properly dialed in closed-loop on the street before going to the dyno. this is true of any aftermarket MAF setup, though. on average i'd say it takes me about an hour to dial in this particular MAF design to <3% fueling error in closed loop (starting from my base which gets me within 5% usually). developing that base probably took 3-4 hours. in open loop i only use SD, so i can't speak to that.
Old 03-07-2014, 02:23 PM   #1318
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
I'll try and get a pic of it tomorow
lbroskee is offline   Reply With Quote
Old 03-10-2014, 10:06 PM   #1319
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
I picked up a prodrive boost solenoid this week. Any guidance on how the electrical connections are typically made? Would also be interested in mounting locations used by others.
Sent from my Nexus 7 using Tapatalk
pixel67 is offline   Reply With Quote
Old 04-24-2014, 01:04 PM   #1320
alpine
Not what you think
alpine's Avatar
Drives: 718 GTS 4.0
Hellooo, recently installed my 60 Trim EL Turbo Kit made 320hp/243tq on @jamesm virtual dyno and his tuning. My Build link is here http://www.ft86club.com/forums/showthread.php?t=53069
alpine is offline   Reply With Quote
Old 04-24-2014, 01:23 PM   #1321
lbroskee
lbroskee's Avatar
How are u makin so much tq on OEM clutch chris??
Old 04-24-2014, 01:26 PM   #1322
lexusb3
Drives: FRS
That's when the clutch starts to go around that tq
lexusb3 is offline   Reply With Quote
Old 04-24-2014, 01:26 PM   #1323
alpine
Not what you think
alpine's Avatar
Drives: 718 GTS 4.0
I'll tell you how I've had the kit on for 4 days now and my clutch is already slipping haha.
The Following 2 Users Say Thank You to alpine For This Useful Post:
SkAsphalt (04-25-2014), Sportsguy83 (04-24-2014)
Old 04-24-2014, 01:28 PM   #1324
lexusb3
Drives: FRS
Hey you were at the Subi meet last week when it started to rain right?!
Old 04-24-2014, 01:29 PM   #1325
alpine
Not what you think
alpine's Avatar
Drives: 718 GTS 4.0
Yeah but I was N/A
The Following User Says Thank You to alpine For This Useful Post:
lexusb3 (04-24-2014)
Old 04-24-2014, 01:30 PM   #1326
lexusb3
Drives: FRS
Yeah but I was N/A
Lol but now times have changed
The Following 2 Users Say Thank You to lexusb3 For This Useful Post:
alpine (04-24-2014), Sportsguy83 (04-24-2014)
Old 04-24-2014, 01:34 PM   #1327
alpine
Not what you think
alpine's Avatar
Drives: 718 GTS 4.0
they have! and they will change even more!
Old 04-24-2014, 01:58 PM   #1328
lbroskee
lbroskee's Avatar
I thought it started slipping at 225? And what PSI u running? 10?
Old 04-24-2014, 02:45 PM   #1329
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
You can't put an exact number on it. Every dyno will read different amongst other things, so when one person says theirs isn't slipping at 240 lb-ft on dyno A during weather X, but another says theirs is slipping at 230 lb-ft but they are on dyno B during weather Y..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following 4 Users Say Thank You to woode For This Useful Post:
Hawaiian (04-24-2014), lbroskee (04-24-2014), SkAsphalt (04-25-2014), Sportsguy83 (04-24-2014)
Old 04-24-2014, 03:46 PM   #1330
sw20kosh
Drives: 2013 Black FR-S
Mine started slipping after a few wot 3rd gear pulls at 220-230 ft lbs
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
