Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > User/Vendor/Sponsor Reviews, Feedback, Comments
Old 02-24-2014, 12:32 PM   #15
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by PERRIN_Chris View Post
That is not normal for sure, sending PM! Sorry for the hassle. I'm not sure how many customers of ours have turbo kits installed with our header, this is the first we've seen melt! It could be that it will need additional head shielding.
Yeah I mean urethane melts around 500F an exposed header sitting 6-8 inches from it running up to 1700F. Something will give.
Ironsquid is offline   Reply With Quote
Old 02-24-2014, 01:11 PM   #16
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I also wanted to add that with aftermarket headers and especially turbo kits with dyno time and not proper airflow under the engine, additional shielding and wrapping is going to absolutely needed on the header if it's going to be used with either the stock engine mounts or aftermarket mounts. These cars aren't built from the factory to be FI, so wrapping, shields, will need to be used.
On a dyno with not enough air flowing through the engine compartment, this can happen in just one hot run!
1700 will be the EGT, radiant heat will be more around 1000 on a header, but yes that is hot! We use basically the same bushing in our STI/WRX headers, and haven't had an issue at all, and those run very close to the header as well.
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
whataboutbob (03-07-2014)
Old 02-24-2014, 01:42 PM   #17
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Correct me if I'm wrong, I don't think the STI/WRX platform has a factory sealed oven called an engine bay like the 86's do. Maybe they do, I don't know, I'm a mitsu guy >.>
Old 02-24-2014, 09:34 PM   #18
tg_1981
I have an EGT gauge i've seen 1100-1280 just driving around town tonight. I'll have to go back and check some logs to see what the high is. My headers are ceramic coated. I guess i'll be wrapping them now to prevent further issue. I have every part to keep the engine bay temps in check. I even spent the cash on a vented hood to get some air flow. I think evasive might be right in going with solid mounts is probably the next route.
The car has spent time on a dyno. They were all equipped with turbo fans
tg_1981 is offline   Reply With Quote
Old 02-25-2014, 09:32 AM   #19
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I just bought and installed these as.part of my build this weekend. I guess I'll find out soon enough since I drive a ton (over 40,000 miles logged.) They will go through several heat cycles in a short period.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 02-25-2014, 09:34 AM   #20
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I checked the passenger side mount yesterday and its not melting. I used to have the AVO turbo down there which I think would produce even higher temperatures in the area.
I am not planning on re-installing the engine bottom metal tray anytime soon.
Old 02-25-2014, 01:14 PM   #21
Ross
Drives: 85 corolla gts
Coming up we will be installing a built engine and with it upgraded mounts. We will be using products similar to these listed below for heat shields on the mounts. Similar to how many factory cars come when the mounts are close to exhaust parts. As well not everyone is a fan of wrapping exhaust parts, and to a point with good reason but it does help. Below are some manufacture parts listings that may help. Hope you get your situation sorted and I am sure perrin will help get you right.
http://vibrantperformance.com/catalo...1022_1355_1356
http://www.designengineering.com/cat...und-insulation
http://www.designengineering.com/cat...-lr-technology
Ross is offline   Reply With Quote
The Following 2 Users Say Thank You to Ross For This Useful Post:
Ryan P (02-25-2014), Sportsguy83 (02-25-2014)
Old 02-25-2014, 01:25 PM   #22
ramiram1984
Drives: 2016 STi DGM
Install is super easy...btw.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 03-04-2014, 04:43 PM   #23
jamesm
i still have stock mounts, not melted at all. no issues at all with them, actually. holding up just fine, been boosted for ~9k+ miles now. my header is wrapped, so maybe that helps.
i had planned on perrin mounts if and when mine start causing problems, but i think i'll go with solid mounts instead now.
Old 03-07-2014, 12:19 AM   #24
Sportsguy83
Drives: Limited BRZ
[ame="http://www.youtube.com/watch?v=umDr0mPuyQc"]NO GOD! PLEASE NO!!! NOOOOOOOOOO - YouTube[/ame]
Old 03-07-2014, 10:47 AM   #25
jamesm
lol that's awesome. i've actually rode in a lot of cars with the cuscos and i honestly can't tell the difference between those and the perrins. they all seem just a little more vibey than stock to me. maybe living with them every day would be another story...
The Following User Says Thank You to jamesm For This Useful Post:
Sportsguy83 (03-07-2014)
Old 03-07-2014, 10:49 AM   #26
Sportsguy83
Drives: Limited BRZ
Cusco's are solid??
Solid mounts usually add ridiculously lots of NVH
Old 03-07-2014, 10:51 AM   #27
jamesm
Cusco's are solid??
Solid mounts usually add ridiculously NVH
i don't know... i know they're supposed to be harsher than the perrins. i believe they're made out of metal rather than rubber or whatever but don't quote me on that lol.
Old 03-07-2014, 11:21 AM   #28
OrbitalEllipses
Drives: Attitude
It's not a solid-solid mount from what I recall. BRB while I check.
From RSD:
Looks like it has a far lower urethane or rubber content versus the Perrin bushings.
perrin engine mounts
Perrin or Cusco Engine Mounts and NVH APS86 Engine, Exhaust, Transmission 7 08-04-2018 02:08 AM
Engine Mounts? mrk1 Engine, Exhaust, Transmission 17 05-15-2016 04:31 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
engine mounts for FI jamesm Forced Induction 19 04-18-2013 08:57 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
