Old 03-04-2014, 11:02 AM   #1
BuhhDill
Drives: 2014 Scion FR-S
4 point harness
I've never had or installed a 4 point harness. I'm trying to figure out where the proper place to mount them is. I do not have a cage or harness bar yet so it will be to the floor. So I'd just like some input or ideas of where to mount.
BuhhDill is offline   Reply With Quote
Old 03-04-2014, 11:08 AM   #2
CoupedUpSubie
Drives: 2013 BRZ Limited
As discussed in another thread you should really have a harness bar. Also be sure that the rules for whatever series you plan to race in allows a 4-point as I have seen many that don't.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 03-04-2014, 11:20 AM   #3
BuhhDill
I have a roll cage goin in soon. but for now would like to get the harnesses install if i can. and im drifting the car locally so nothing major. just added safety for myself.
Old 03-04-2014, 12:49 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It won't be "added safety" if you don't have a cage to go along with the harness.
You're better off just waiting for the cage.
-alex
Basket Case (03-07-2014)
Old 03-04-2014, 03:47 PM   #5
BuhhDill
Yea I was getting impatient but i called and the cage is gonna be in next week so i might as well wait now. Thanks anyways
Old 03-04-2014, 03:48 PM   #6
Kanye
Drives: FRS
NEVER MOUNT A HARNESS TO THE FLOOR. I included a picture of some of the points where you could mount it properly but in the event of an accident its harmful or even fatal due to the geometry of how the belt will restrict you during impact. Before i had a bar, i mounted mine in the rear seat buckle location and the bolt under the seat.
Kanye is offline   Reply With Quote
The Following User Says Thank You to Kanye For This Useful Post:
BuhhDill (03-06-2014)
Old 03-05-2014, 03:58 PM   #7
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i used mounting point D as the picture above... oem seat belt area and the seat base
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 03-06-2014, 11:41 PM   #8
BuhhDill
thanks for the diagram ill be getting it in soon and some pictures up of the car.
Old 03-07-2014, 09:45 AM   #9
wparsons
wparsons's Avatar
I don't know of a single sanctioning body (even auto slalom or HDPE) that allows 4/5/6 point belts without a cage. Stock belts let you slump down in the seat in a rollover, 4/5/6 point belts won't let you. Without a cage this means an increased potential for a broken neck.
Another thing to keep in mind is that all the sanctioning bodies up here require equal safety for the passenger, so if you put in a better seat and multi point harness for yourself the passenger seat requires something equivalent if you want a passenger in the car.
flickr
Old 03-07-2014, 12:29 PM   #10
wheelhaus
wheelhaus's Avatar
I'm not stating this as gospel, of course a roll cage/bar is still the best, but wasn't there some studies done recently that showed the 4+pt rollover/no slump issue was mostly a myth? I can't remember exactly, might have been something to do with the forces involved or something. I think they were saying the fear and paranoia of the roof collapsing directly down on your head was blown out of proportion or something and is actually extremely unlikely. And the anti-submarine concern is alleviated with breakaway straps that extend under impact to allow your upper body to fold forward a bit. I'll search around and see what I can find...
Old 03-07-2014, 01:12 PM   #11
wparsons
wparsons's Avatar
^^ You very well could be right, but it doesn't change the rules for any sanctioning bodies around me. They're pretty clear on it, if you want to run multi point belts the car needs an approved cage.
I'm sure it's partially to clear up any potential grey areas, and make tech inspections easier to manage.
flickr
4 Point harness mounting locations for stock seat raytrix DIY (Do-It-Yourself) Guides 29 04-11-2014 11:36 PM
FS: Authentic Takata Harness 4-Point 3" Short (Pair) CHEAP!! Joe-G Interior Parts (Incl. Lighting) 1 01-20-2014 08:33 PM
FS: Authentic Takata Harness 4-Point 3" Short (Pair) CHEAP!! Joe-G Canada Classifieds 0 01-19-2014 04:58 PM
FS: Sparco Shoulder Pads and Tuner Style 4-point Harness Aznsky Interior Parts (Incl. Lighting) 7 07-21-2013 09:57 PM
FS: Sparco 4-Point Racing Harness JPxM0Dz Canada Classifieds 2 01-12-2013 01:10 PM
