Old 03-06-2014, 06:28 PM   #15
Imrac
Drives: 13 SWP BRZ Prem
I have mine done at the local Discount Tires (American Tires in other parts of the states). They just walk around the car scanning the sensors, then use the OBD2 port to upload. The only issue is their tool isn't updated for the BRZ/FRS yet. Tell them to use a 2012 Toyota Camry preset and it will work just fine.
Another thing you can use is the Toyota's Tech Stream and a cheap USB to OBD2 port dongle and update the codes yourself. (Although I haven't tried it yet, I believe it will work).
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 03-06-2014, 06:41 PM   #16
CoupedUpSubie
Drives: 2013 BRZ Limited
If a Subaru dealership can't do it there is one of two reasons. They want to sell you OEM sensors or they aren't experienced at all with the BRZ. Chances are they are trying to get you to buy from them.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 03-06-2014, 07:45 PM   #17
raptor87
Drives: 2013 DGM BRZ Ltd
works, just did mine today
raptor87 is offline   Reply With Quote
Old 03-06-2014, 09:18 PM   #18
qijian
Drives: FRS
how you do it? j/w
qijian is offline   Reply With Quote
Old 03-07-2014, 12:57 AM   #19
RL_BRZ
Drives: BRZ WRB Pearl Limited Manual
Originally Posted by aschnell View Post
If you want to do it yourself get a ATEQ quick set. $150 from Amazon. Then you can swap wheels on your own. Need the ids from tire rack. I went to local tire dealer to read out codes since tire rack messed up one of my codes. Subaru was useless.
I did this... And it works for me...
RL_BRZ is offline   Reply With Quote
Old 04-19-2014, 07:30 PM   #20
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Is the code needed by the ECU printed on the sensor itself, or can it only be read wirelessly with some type of tool?
I just ordered a set of used sensors on ebay, as well as a ATEQ Quickset reader from Amazon. I'm now trying to figure out how to get the codes to input into the tool.
B-R-Z is offline   Reply With Quote
Old 04-20-2014, 08:40 AM   #21
aschnell
Codes should be printed on the out side of the sensors
aschnell is offline   Reply With Quote
Old 04-20-2014, 06:24 PM   #22
connorlug
Drives: #1553 10 Series FRS
The codes are printed on the outside of the sensor
it'll be like a 'BU78362' 7 digits, all in caps. some letters and numbers.
bring the codes to a toyota dealer and give them the ID #'s. tire rack should have given those ID #'s to you. we usually charge a half hour of labor to reprogram the tpms. anything more than that you're getting robbed.
or if you can get your hands on toyota techstream software you can do it yourself.
click on tire pressure monitoring once you connect to the vehicle, then hit utility on the left hand side. you'll see it.
connorlug is offline   Reply With Quote
Old 04-20-2014, 08:04 PM   #23
B-R-Z
B-R-Z's Avatar
I'll have the ATEQ Quickset so I'll be fine to do it myself. Thanks for the reply
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 09:11 AM
TPMS on and off? dem00n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-06-2012 10:56 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 09:25 AM
TPMS? 636 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-22-2012 11:57 AM
TPMS smbrm CANADA 2 09-21-2012 12:17 PM
