#44 |
Drives: White 2014 BRZ
Are B series ROM's (2014 MY I think) supported?
#45 | |
RWD addicted
Drives: BRZ 6MT OFT OFH
I was referring to the throttle line dropping down to 25-35 while the pedal was pressed down to the floor and the engine speed was rising as it should on WOT. There were 3-4 gears WOT (!) pulls logged |
#46 |
Drives: 2013 FRS
Not a bug. That is traction control intervening. You can see wheelspin in your rpm log. Those spikes are loss of traction. They coincide with throttle closure. Sounds like fun!
#47 | |
RWD addicted
Unfortunately you cannot completely disable stupid questions
#48 |
Drives: 2013 FRS
#49 |
Thanks @shiv@vishnu. I forgot to edit that post. I meant is IAM logging available in B series ROM's? Currently mine always says 0.00 which obviously isn't correct.
#50 |
Is the OFT now only doing startup/functioning if you plug it into the OBDII port on your car while the car is not running? Before upgrading to 1.23 today I think I could plug it in while car was running and it would do diagnostics fine. Today after my car was started I plugged it in on way home from work and it just gave a white screen. I tried that 3-4 times while it was running, nothing but white screen.
After I got home I turned off the car and plugged it in. Screen worked fine and synched and then told me to key on car. And it worked properly when I started up diagnostics. |
#51 |
Drives: 2013 Argento FR-S
@shiv@vishnu. On 1.23, I get an error when I try to open "Realtime Data Display".
#52 |
^^ See his reply to my earlier post, have you uploaded the new template file in addition to the 1.23 update? That fixed it for me.
#53 | |
Drives: 2013 FRS
#54 |
I have the updated template. I did it twice to be sure. Not sure what my problem was with the white screen.
#55 | |
Drives: Toyota Gt86
Dunno what happened then it started working again. |
#56 |
Drives: 2013 FRS
White screen means the OFT didn't boot up properly due to poor connection at the obd2 plug. Often this happens if it is not plugged in properly causing a flakey power connection. All you need to so is unplug it, wait for 5 seconds and plug it is again. It will boot up fine then. Nothing to do with firmware or template update.
| The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post: | Captain Insano (03-07-2014), Victor Draken (03-06-2014) |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 01:31 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 10:05 AM |
| OpenFlash Tablet Firmware 1.19 Now Available: Stores up to 5 ROM on the OFT | Shiv@Openflash | Software Tuning | 33 | 12-20-2013 10:38 AM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 01:10 AM |
