Old 03-06-2014, 01:47 PM   #43
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by wparsons View Post
So what you're saying is... the bug is between the seat and the tablet?? D'Oh
I don't judge
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
wparsons (03-06-2014)
Old 03-06-2014, 02:36 PM   #44
stevo585
Drives: White 2014 BRZ
Are B series ROM's (2014 MY I think) supported?
stevo585 is offline   Reply With Quote
Old 03-06-2014, 02:59 PM   #45
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Originally Posted by shiv@vishnu View Post
Great. Good to hear that Adv Mult is now logging for you. Your throttle readings look fine. I'm not sure what you are referring to.
Also, as of this morning the bug in the Accel Pedal channel has been fixed. So now it reads correctly 0-100%. Just connect OFT to laptop and let it update. No need to update Template again if you already did it.
Cheers
shiv
Thank you Shiv!
I was referring to the throttle line dropping down to 25-35 while the pedal was pressed down to the floor and the engine speed was rising as it should on WOT. There were 3-4 gears WOT (!) pulls logged
Ondreiko is offline   Reply With Quote
Old 03-06-2014, 03:09 PM   #46
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Ondreiko View Post
Thank you Shiv!
Not a bug. That is traction control intervening. You can see wheelspin in your rpm log. Those spikes are loss of traction. They coincide with throttle closure. Sounds like fun!
Old 03-06-2014, 03:16 PM   #47
Ondreiko
RWD addicted
Ondreiko's Avatar
Oh yes! I just forgot to disable em this time. =)))
Unfortunately you cannot completely disable stupid questions
Old 03-06-2014, 03:24 PM   #48
Shiv@Openflash
Drives: 2013 FRS
Yes they are
Old 03-06-2014, 04:03 PM   #49
stevo585
Thanks @shiv@vishnu. I forgot to edit that post. I meant is IAM logging available in B series ROM's? Currently mine always says 0.00 which obviously isn't correct.
Old 03-06-2014, 06:02 PM   #50
Captain Insano
Is the OFT now only doing startup/functioning if you plug it into the OBDII port on your car while the car is not running? Before upgrading to 1.23 today I think I could plug it in while car was running and it would do diagnostics fine. Today after my car was started I plugged it in on way home from work and it just gave a white screen. I tried that 3-4 times while it was running, nothing but white screen.
After I got home I turned off the car and plugged it in. Screen worked fine and synched and then told me to key on car. And it worked properly when I started up diagnostics.
Captain Insano is offline   Reply With Quote
Old 03-06-2014, 07:53 PM   #51
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
@shiv@vishnu. On 1.23, I get an error when I try to open "Realtime Data Display".
Terrapin77 is offline   Reply With Quote
Old 03-06-2014, 07:57 PM   #52
wparsons
wparsons's Avatar
^^ See his reply to my earlier post, have you uploaded the new template file in addition to the 1.23 update? That fixed it for me.
flickr
Old 03-06-2014, 08:00 PM   #53
Shiv@Openflash
Drives: 2013 FRS
Did u update the template as well?
Old 03-06-2014, 08:21 PM   #54
Captain Insano
I have the updated template. I did it twice to be sure. Not sure what my problem was with the white screen.
Old 03-06-2014, 08:36 PM   #55
Victor Draken
Drives: Toyota Gt86
Had same problem but I'm still on the old firmware. OFT didnt work for a bit, tried 10 Times to connect it and disconnect, same white screen.
Dunno what happened then it started working again.
Victor Draken is offline   Reply With Quote
Old 03-06-2014, 08:45 PM   #56
Shiv@Openflash
Drives: 2013 FRS
White screen means the OFT didn't boot up properly due to poor connection at the obd2 plug. Often this happens if it is not plugged in properly causing a flakey power connection. All you need to so is unplug it, wait for 5 seconds and plug it is again. It will boot up fine then. Nothing to do with firmware or template update.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
Captain Insano (03-06-2014), Victor Draken (03-06-2014)
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
OpenFlash Tablet Firmware 1.19 Now Available: Stores up to 5 ROM on the OFT Shiv@Openflash Software Tuning 33 12-20-2013 09:38 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
