Old 03-05-2014, 10:35 PM   #3795
NickFRS
Drives: 2013 Asphalt FRS
This is an awesome read to understand your blower!
http://www.kennebell.net/KBWebsite/C...nd_Analyze.pdf
HOW TO AVOID & ANALYZE SUPERCHARGER PROBLEMS
Would be awesome if Innovate came out with something like this.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
The Following 4 Users Say Thank You to NickFRS For This Useful Post:
CK_Bladesmith (03-05-2014), DarrenDriven (03-09-2014), evan (03-06-2014), Lawnik (03-06-2014)
Old 03-06-2014, 06:02 PM   #3796
IAMTHEWG
IAMTHEWG's Avatar
Drives: Scion Fr-s
Not to jack the thread, but after reading through 100+ pages of this and deciding on the Innovate stage 2, does anyone know a good shop around Centralish Jersey to get the install/tuning done?
IAMTHEWG is offline   Reply With Quote
Old 03-06-2014, 06:31 PM   #3797
evan
Drives: fr-s
Prime Motoring
"wacks on..wax off"
evan is offline   Reply With Quote
Old 03-07-2014, 04:55 PM   #3798
tendogy
Compilation of Owner-Mentioned Hiccups
Multiple people have stopped by to ask what issues the owners are having, because that is often one of the top questions by people trying to decide on a kit. Slogging through dozens of pages is laborious, so here is a compilation of the hiccups/issues reported by the owners here.
The numbers in the grid are the post numbers where the hiccup is mentioned, and the resolution is in parenthesis. "sr" means the issue was self-resolved by the owner, "ic" means the issue was resolved by Innovate/Sprintex; the number inside the parenthesis indicates the post number where the resolution was resolved. For example, xjohnx reported his blower was missing a clip in post 739 of this thread and reported in post 775 of this thread that this was resolved by Innovate/Sprintex.
There are 56 owners currently listed in OP. Of those owners, fifteen of them (26%) mentioned a total of 29 hiccups/issues.
Of those who mentioned hiccups/issues:
20% reported coil failures.
15% suffered a belt failure.
15% suffered a idler pulley failure.
15% discussed the weak/loose plastic elbow fittings.
15% discovered an intercooler coolant leak.
15% had to deal with disintegrating bolts/fasteners.
all other issues were only reported by 1 or 2 people.
Feel free to interpret the data however you wish. I hope it was useful to have it compiled from 174 pages to one image.
Last edited by tendogy; 03-07-2014 at 10:22 PM. Reason: Updated based on owner clarifications
tendogy is offline   Reply With Quote
The Following 8 Users Say Thank You to tendogy For This Useful Post:
Assunta (03-07-2014), Calum (03-07-2014), CK_Bladesmith (03-07-2014), jamesm (03-07-2014), kbogarto (03-09-2014), NickFRS (03-07-2014), R2 (03-07-2014), Xero-Limit (03-07-2014)
Old 03-07-2014, 05:02 PM   #3799
TemeCal
Drives: 86
25% reported coil failures.
18% suffered a belt failure.
18% suffered a idler pulley failure.
18% discussed the weak/loose plastic elbow fittings.
18% discovered an intercooler coolant leak.
18% had to deal with disintegrating bolts/fasteners.
FYI...I didn't have an idler pulley failure. I had some squeaking, which I thought was the idler pulley. I replaced it with a new one, but it didn't go away.
TemeCal is offline   Reply With Quote
Old 03-07-2014, 05:30 PM   #3800
olorin
olorin's Avatar
Drives: GBS Premium
The code I got was a cylinder 1 miss fire not a coil failure. I have not gotten it again. It was hypothesized that it could be a bad coil pack.
olorin is offline   Reply With Quote
Old 03-07-2014, 07:29 PM   #3801
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
You can put me down for a chirping idler pulley as well. My fault though as I did not shim it in the back and the belt is riding more towards the front of the pulley instead of in the middle. Good thing napa has them for only $16. . Btw what's the best way to shim it anyway?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 03-07-2014, 08:15 PM   #3802
sam69
Drives: GT 86
Been looking through the last 30 or so pages and have done a search for how big a hit the sprintex chargers have on economy as I do alot of country runs.
I know it will be worse than standard and I expect that but as long as it's not huge so if anyone can even say how much they have lost per tank or mpg / LTs to the 100 k .
sam69 is offline   Reply With Quote
Old 03-07-2014, 08:54 PM   #3803
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Our consumption went from 33 to 32 MPG when cruising. The blower freespins when under low loads, so it is pretty much taken out of the equation except for a tiny bit of bearing drag/rotational mass from the rotors.
Xero-Limit is offline   Reply With Quote
Old 03-07-2014, 08:58 PM   #3804
CK_Bladesmith
Drives: Raven FR-S
My fuel mileage is absolutely terrible now. Around town I use to get 250+ miles per tank before a fill up when I was NA.....now I'm lucky to get 170-200, and I'm not constantly in the boost either.
Old 03-07-2014, 09:04 PM   #3805
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Bill from delicious is addressing this in his next tune update. Should be released this weekend or maybe next. I think after the update 33mpg was seen IIRC. I get around 28 in the cold on winter tires. Before winter I was getting 31mpg.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 03-07-2014, 09:05 PM   #3806
Calum
That Guy
Drives: 2013 asphalt FRS MT
What tune are you running?
Old 03-07-2014, 09:07 PM   #3807
CK_Bladesmith
Drives: Raven FR-S
Delicious tune. His update should be out soon as stated above. Can't wait for it
Old 03-07-2014, 09:27 PM   #3808
scarfo
Drives: gts 86
What would the ease of an intercooled version be to someone who knows there way around tools but not on car applications?
scarfo is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
