Old 03-03-2014, 04:37 AM   #239
Aidos
Aidos's Avatar
Drives: Orange GT86
OpenFlash Tablet v1.55b: BIN files added!
Hi @shiv@vishnu
I flashes my 86 with the stage 2 uel tune couple of days ago, and today I the CEL with the P0420 code
My mods are Revworks uel, perrin overpipe, perrin filter and inlet tube.
I know the code Is the cat inefficient one but I thought that was disabled in the stage 2's?
Aidos is offline   Reply With Quote
Old 03-03-2014, 05:32 AM   #240
brn12345
brn12345's Avatar
Originally Posted by Aidos View Post
Hi @shiv@vishnu
Are you running both oxygen sensors? If not, you need to run them both. I run the Revolution header which came with just 1 o2 fitting. I installed another fitting and have been running Stage 2 EL for few months with no issues.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 03-03-2014, 05:39 AM   #241
Aidos
Aidos's Avatar
Drives: Orange GT86
Yeah I'm using both. Revworks comes with both fittings
Old 03-03-2014, 07:43 AM   #242
Victor Draken
Drives: Toyota Gt86
I think you have a Leak, I remember shiv re-enabled the o2sensor cel to warn if there was a leak in the exhaust.
Take it with a grain of salt because I'm not 100% sure of what I'm Talking about.
Victor Draken is offline   Reply With Quote
Old 03-03-2014, 07:46 AM   #243
Aidos
Aidos's Avatar
Drives: Orange GT86
Oh really? I will definitely have a look at that. Would that be a leak at the sensor or elsewhere?
Old 03-03-2014, 08:10 AM   #244
Victor Draken
Drives: Toyota Gt86
elsewhere, I remember shiv talking about re-enabling the sensor so we could know when we had a leak or not.
BUT I'm not that sure. Just PM him or wait for a reply here.
@shiv@vishnu
Old 03-03-2014, 03:57 PM   #245
steve99
Drives: FT86
Hi @shiv@vishnu
If you open you tune file in RomRaider and go to the DTC/CEL tables you should be able to see that code, obviously is enabled at present but you could disable it if required.
The leak theory sound good, did you use new gaskets ??
Old 03-03-2014, 05:16 PM   #246
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Actually you only need a O2 bung on the 2nd O2 sensor, which is primilarily used to detect if the first cat is present. I've been running my catless EL header with a built in O2 bung on 2nd O2 sensor and so far it only once did the CEL came up.
Burn is offline   Reply With Quote
Old 03-04-2014, 01:04 PM   #247
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Hey @shiv@vishnu can you let me know what you think of my data log?
This is the stg2 UEL 1.55b tune w/ OFH and 2.75" header back. I feel like there might be a leak somewhere since I reused gaskets but not sure if you can tell through reading datalogs...
http://datazap.me/u/rhythmm/oftstg23rdgearpull03032014
edit: Forgot to mention I already put on about 230 miles after flashing the ECU with the stg2 tune and installing the OFHeader.
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 03-04-2014, 02:13 PM   #248
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Looks pretty darn perfect. Full timing. No knock. Good AFR. But if you re-used gaskets, I would HIGHLY suggest replacing them immediately. If they don't leak now, they will leak soon in my experience. And when they do, it will cause all sorts of fueling issues.
Shiv@Openflash is offline   Reply With Quote
Old 03-04-2014, 08:55 PM   #249
celica73
Speaking of gaskets, there appears to be a rough side and a smooth side. Are they directional?
Old 03-04-2014, 10:06 PM   #250
Shiv@Openflash
Drives: 2013 FRS
I don't believe so.
Old 03-04-2014, 11:24 PM   #251
rhythmM
rhythmM's Avatar
Thanks for the input!! I thought reusing the gaskets would be okay because the car only had about 2500 miles on it. I get some news soon then.
Old 03-05-2014, 07:58 PM   #252
Captain Insano
Hey @shiv@vishnu Are you going to start a thread for the 1.56b version or use this existing 1.55b thread?
Captain Insano is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
