Old 03-05-2014, 02:54 PM   #57
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
Originally Posted by blkwrxwag View Post
OP - it is very likely that the tires you have bought are complete crap at this point, and they will be worse than decent street tires. If they are ok, your car will be fine and you will not die a horrible death.
How could I tell if they are crap? Would they be hard? Is it possible for the tires to be soft, but still be crap? These tires seem quite soft.
Thrustin is offline   Reply With Quote
Old 03-05-2014, 03:01 PM   #58
blkwrxwag
Drives: DS FRS
Well, experience mostly. How does you car normally feel on good tires? How is the surface? An abrasive surface can help scrub off the harder outside and get back down to the good stuff. Heat will help as well. However, those tires must be years old, so it will also depend on how they were stored.
-Max H.
blkwrxwag is offline   Reply With Quote
Old 03-05-2014, 04:33 PM   #59
Thrustin
I meant, how can I tell before I drive on them? The guy I got them from was an autocross guy, and had them in storage while he was overseas (military). They don't seem at all like they sat outside, or in a cold garage.
Old 03-05-2014, 04:52 PM   #60
TrqlessWonder
Drives: 2014 FR-S
With certainty? I'm not sure you can tell before taking a run. The fingernail test and/or durometer gauge are still only approximate at best. I suppose you could additionally just leave them in the sun for a 10-20 minutes and see if the surface gets a little tacky, but at that age, I'm not sure that'd be a very accurate indicator, either.
You bought 'em, may as well learn something by using them. Take a brave pill and give it a shot. Or, have a local instructor take the car out, and that'll do a better job of answering your question than any of this interweb chatter can.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 03-05-2014, 05:05 PM   #61
Thrustin
I think I'll take a brave pill, lol.
Old 03-05-2014, 05:09 PM   #62
blkwrxwag
Drives: DS FRS
That's pretty much the thing to do
Good luck - I hope they are ok for you.
-Max H.
Old 03-05-2014, 05:46 PM   #63
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by SeanRTR View Post
FYI, several people run A6's in road racing, and they work quite well. Is it cost effective? Not really, but...
A friend running NASA Northeast in an ST2 Corvette runs A6s. According to him, it goes like this: he races off and leaves his competitors in the first few laps, maintains that lead for awhile, and then hangs on for dear life in the last few laps. After the win (~70% of his races), Hoosier awards him...yes, you guessed it: four more A6s.
That's the spirit - nothing ventured, nothing gained. You say they're still soft, I say you'll have a ball on them.
dradernh is offline   Reply With Quote
Old 03-05-2014, 07:33 PM   #64
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by dradernh View Post
No, no, no!!! Some of us would dearly love to hear what a hotshot like yourself thinks about this subject. Seriously.
What my video wasn't evidence enough that it's a kick ass idea? Ha ha
Element Tuning is offline   Reply With Quote
Old 03-05-2014, 08:08 PM   #65
Element Tuning
Ok since this thread has moved so far away from the original question I'm just going to share my experience with the FRS exclusively on a few track tires. In his case its not about what will net me the fastest lap for a given class or the fastest average lap for an entire race.
This car is light and the rear end is extremely light. The biggest problem most of us have had racing the car is getting heat into the rear tires. It is so difficult I wouldn't even entertain running anything but an "A" comp equivalent even for track days. I really struggled when I raced the car in a "140" wear rating tire class until I ignored everything everyone told me about the correct pressures for Hankook RS3s. I ran the rears super low on pressure so I could accelerate heating the tires up so they were at a better working temp.
This where the debate starts with tire width, diameter, and compounds. Most class regulated racers are going to keep the diameter small so they have better/quicker gearing, and they will settle on a width and compound that will get enough heat so the tire performs as it should.
While its easy to get A6s greasy on a 3400 lbs STi running 4 qualifying laps the is not the case on the FRS.
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
CSG Mike (03-05-2014), dradernh (03-05-2014)
Old 03-05-2014, 09:36 PM   #66
dradernh
Ahh...missed it. That's quick for a car with these specs, and makes this prospective buyer even more inclined to pick one up.
Nice use of all the curb in T5, BTW!
Old 03-06-2014, 11:43 AM   #67
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
I bought some of these tires a couple of years ago for my CRX, they were old tires then too. They still have grip but are harder than they would have been new. They will give you some idea of what sticky tires feel like but not totally. Mine seemed to heat cycle out quickly too. That is the tires get harder as they are heated and cooled after each run. Just keep in mind that new A6's will be much stickier than what you have, but these will still be fun to get a feel for things. They are old purple crack, but they are still purple crack! Be warned, you may not be able to stop yourself from buying a new set of Hoosiers after your experience.
MTCRX is offline   Reply With Quote
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 08:37 PM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 10:07 AM
07 WRX wheels & 225/45 Dunlop ZII Stock autocross set up -max- Wheels and Tires 0 04-29-2013 04:26 AM
Completely stock BRZ / FR-S needed AMR Engine, Exhaust, Transmission 11 04-03-2013 10:01 AM
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
