#57 |
Drives: 2015 WRX
Thats the beauty of the OFT. You can easily swap back to your stock map in minutes with no trace of you ever flashing a tune.
| The Following User Says Thank You to Malt For This Useful Post: | jc1993 (03-09-2014) |
#58 |
Drives: '13 Whiteout FR-S (M/T)
Hi all, thanks to everyone who has contributed to this thread. I've learned a lot and know where I'll be looking to for future mods.
At this point, there's no more need for additional posts. Thanks!
#59 | |
Drives: 2013 GBS BRZ Limited
1- unless the pulleys underdrive the accessories (Water pump, Alt., & A/C), then they cannot make more HP. 2 - Even if you replace the pulleys "because it gives you a lower mass rotating assembly" then the pulleys are the LAST part you should worry about. Being near the cneter of rotation, the pulleys contribute the least to the rotational inertia of the rotating assembly. (the drive belt probably contributes more) If you want to reduce rotating mass, then go ahead and replace the pulleys, but a lightened flywheel & clutch assembly makes a MUCH bigger difference. 3 - There is still a debate about the pulley's contribution to balance on these engines. If you build a racing boxer engine, you pay extra to have the rotating mass balanced. Were these engines balanced at the factory? (no-one knows - at least on this forum). IF the engine was balanced, changing the pulley without a rebalance is a bad idea. 4 - If you want to argue - "But lighter pulleys reduce the overall weight of the car by pounds". If you believe that so strongly, then take the wheel balance weights off your wheels. That is a few pounds of unsprung weight.... |
#60 |
Drives: 2013 WRB BRZ Sport Tech
props to the moderators for banning NYCsubaruBRZ, that guys attitude is not needed here.
also, is pretty obvious that catchmyvett and NYCsubaruBRZ is the same person which is effin hilarious. @1Cor10:23 see what u started lol! |
#61 | |
Drives: 2015 WRX
#62 |
Fanboy
Drives: 2013 ultramarine frs
I'm gonna guess they go to the same school at least.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
| The Following User Says Thank You to FrsDuke For This Useful Post: | DAN_BRZ (03-05-2014) |
#63 |
Drives: 2015 WRX
#64 | |
Drives: 2013 FRS
| Done modding until its lowered...anyone else in the same boat? | BlueDubbinTDI | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 11-10-2013 05:03 PM |
| Modding stock muffler | Ghost 86 | Engine, Exhaust, Transmission | 6 | 07-15-2013 05:11 AM |
| Modding your car and the law | GIMMICK | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 06-02-2013 02:57 AM |
| EU to Ban Modding | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 11-04-2012 01:56 AM |
| Not modding - wheels and suspension available | Z86 | AUSTRALIA | 0 | 10-08-2012 10:48 PM |
