Old 03-04-2014, 11:19 AM   #43
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Originally Posted by jdrxb9 View Post
Are the back-to-back weekends keeping folks away from the Blytheville Pro? Just a bit too far from TX? Something else?
In my case, I'm the best man for a friend's wedding and the bachelor party will be that weekend. Otherwise, I'd be up in Bville for some fun on the new larger courses.
Autocross nut
AustinTX is offline   Reply With Quote
Old 03-04-2014, 12:21 PM   #44
itzmik3
DBC Racing
itzmik3's Avatar
Originally Posted by AustinTX View Post
Well, it took me 4 events to get the elusive top PAX out of the car. Yesterday had some weather issues with a warm and rainy 1st group and dry/cold 2nd+3rd group, so let's not all run to Rick Ruth and tell him he was right just yet I asked Vivek Goel to come out and codrive with me to help me understand any driving issues that I have. We ended up with a 1-2 finish in the Pro class and in PAX out of 138! The car was set at 38F/32R air, and half turn from stiff front + half turn from soft rear.
Results:
https://axwaresystems.com/axorm/file...ar2014_pax.htm
Videos:
My run
Comparison of best runs
out of curiosity what program did you use to do a split screen?
#194 SM
itzmik3 is offline   Reply With Quote
Old 03-04-2014, 12:28 PM   #45
vroom4
I cant see your videos because of a work filter...what is a good place to mount gopro to help improve driving? Im thinking of sunction to back window to view hands and head movement, but havent tried it yet...thoughts?
vroom4 is offline   Reply With Quote
Old 03-04-2014, 12:40 PM   #46
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I'm not registered either, but if there were more than 2 signed up in CS and if the long range forecast shows something significantly more promising than what we've had here in PA the past few weeks, I'd be REALLY temped to make the 12 hr drive to AR.
On a more important note, why are you not registered for the Wilmington Match tour??
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-04-2014, 01:08 PM   #47
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Well, getting seriously OT now, but:
1. As much as I like auto-x, I'm really not a fan of the match or champ tour formats - the 4+2 or 3+3 runs never seem like enough.
2. I'm actually going to EVO school that weekend - never done one and it is less than 30 min from my house. With not much left to do on the car, I'm committed to working on the driver this year and EVO and some DA are part of that.
jdrxb9 is offline   Reply With Quote
Old 03-04-2014, 01:16 PM   #48
AustinTX
AustinTX's Avatar
Vivek did the split screen using iMovie. He used "precision editor" to manually monitor the timing at some of the cones frame by frame.
Autocross nut
Old 03-05-2014, 10:01 AM   #49
AustinTX
AustinTX's Avatar
We used the back window for the last set, but it's very difficult to reach back there to turn the camera on. We used the phone app to start/stop the GoPro.
Autocross nut
Old 03-05-2014, 11:40 AM   #50
vroom4
I have solostorm so it turns on everything when you get to the staging area.
Thanks!
Old 03-05-2014, 03:17 PM   #51
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
That auto-start for Solostorm sucks for me. I just end up doing it manually haha
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 03-10-2014, 11:21 AM   #52
AustinTX
AustinTX's Avatar
Another event, another pretty good result. Yesterday's event was run on a race course and had some very high speed sections. The top speed was 85+MPH in one spot. Drew Vanderploeg codrove with me this time, and we ended up 5th and 6th in PAX. We were over 2 seconds back from Vivek's time in the SSR C5Z, but that's to be expected on a horsepower course. He won the PAX by 1.2 seconds!
Car setup was identical to the last event.
Results:
https://axwaresystems.com/axorm/file...event2_pax.htm
I did not take videos this time.
Autocross nut
Old 03-10-2014, 12:39 PM   #53
piknockout
Drives: 2014 BRZ
So what you're saying is that you had fun, but due to the nature of the course, the results don't really mean anything. Got it.
piknockout is offline   Reply With Quote
Old 03-10-2014, 12:39 PM   #54
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
John, are you willing to comment on what you've settled on for toe, and what camber values you were capable of achieving?
I measured my camber this weekend after I got the car uncovered and found I am around 0.95 degrees front on both sides with the crash bolts and about 0.8 degrees on the driver side of the rear (couldn't access the passenger side where the car was parked). This is using a longacre bubble gauge with the quickset adapter. I didn't try to level the car in my garage, so there is a bit of a grade towards the front of the vehicle.
Old 03-10-2014, 12:48 PM   #55
AustinTX
AustinTX's Avatar
I do not know what the camber numbers are, as I've never racked the car. It's as much as I could get, so that's all I've got anyway I may get real numbers just for grins at some point, but I don't want to know if it's a bad number right now. Tire wear is very good, so I'm assuming it's fine.
Rear toe is around 1/8" per side and front toe is 0 based on string checks.
Autocross nut
The Following User Says Thank You to AustinTX For This Useful Post:
Sccabrz192 (03-10-2014)
Old 03-10-2014, 12:49 PM   #56
AustinTX
AustinTX's Avatar
You just need to pollute threads with nonsense - you'll fit right in with SSR!
Autocross nut
DC's Progression Thread. DC@RoadRace Member's Car Journals 8 11-10-2014 09:22 PM
Henry's C Street (SCCA Solo) progression Kido1986 Tracking / Autocross / HPDE / Drifting 74 05-04-2014 08:20 PM
[Elysiam]Kayhettin's 1st '86 Firestorm 6MT Progression kayhettin Member's Car Journals 1 12-06-2013 08:01 AM
What is your progression with Toyotas? WLY AFRICA 26 11-18-2013 01:08 PM
