Old 03-01-2014, 04:41 PM   #1
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
E85 specific oil
There are many overblown oil threads on the internet already and on this forum. But no one with the fa20 seems to really be discussing e85s affects on oil. Or at least i cant find it.
E85 consumes detergents and drastically reduces the oil change interval so its important to look at the tbn and a bunch of other stuff im not well versed in.
the following is internet hearsay;
Ive heard motul 300v doesnt deal with the acid well but 8100 xlite does.
Trd by motul is suposedly amazing in general but only has a tbn of around 7(pretty low add pack, but there are other factors that make oil good/bad for e85 im still a noob about)
Amsoil dominator and redline seem to work well but im pretty sure they are low on moly.
Mobile1s detergents are consumed quickly so mobile recomends mobile turbo diesel instead.
I have a gm fleet vehicle that has to have its oil changed every 2500 miles when its on e85 as per contract!
Local gtr guys tell me they use a similar oil change interval and have posted alot of uoa's.
Im going to try rotella turbo diesel oil on e85 and do a blackstone uoa after 2000miles and ill post it to this thread.
Anyone else have a uoa on e85?
The Following User Says Thank You to Reaper For This Useful Post:
shiro (03-19-2014)
Old 03-01-2014, 05:17 PM   #2
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Keep us posted.
Going e85 once I get my headers.
Carlitoz3 is offline   Reply With Quote
Old 03-04-2014, 12:56 PM   #3
bluesubie
Drives: 2004 Subaru Forester 2.5XT
I wonder why? Both oils have pretty good detergent/dispersant packs with X-lite having much more calcium and 300v having less calcium but more magnesium, IIRC. You would need to do several uoa's on similar cars under similar driving condtions to verify this. Those uoa's would also need to include a Total Acid Number which people rarely do.
This oil is available in New Zealand, and I'm not sure where else, and the TBN is 6.3. A "low add pack" doesn't necessarily correlate with a low TBN. A low TBN also doesn't necessarily have a direct impact on the oil change interval, but it depends on the rate of TBN depletion.
Information fail. Dominator and Red Line both have some of the highest moly available. Although, I do not see how a friction modifier ties in with E85 anyway.
The detergents aren't really consumed quickly, but Mobil1 does recommend TDT in E85 applications.
http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Oil_Best_for_Engines_Using_E85_Fuel.aspx
But, I would not use 5W40 on stock internals. Instead, some of the regular thinner Mobil1 oils actually have a similar detergent/dispersant package as TDT. Again, lower levels of calcium and boosted magnesium.
I believe this. I've seen E85 STI uoa's on Rotella T6 and the oil was pretty trashed in 4k miles. OTOH, I've seen excellent uoa's on protuned WRX's and STI's the results were excellent.
Again, I would not run straight TDT on stock internals. That oil is even thicker than Rotella T6 in all temps. You need to look up some voa's on various oils and find one with a similar detergent/dispersant package.
That's my two cents. Frequent oil changes are your friend.
-Dennis
bluesubie is offline   Reply With Quote
The Following 3 Users Say Thank You to bluesubie For This Useful Post:
Reaper (03-04-2014), SirBrass (03-04-2014), Sportsguy83 (03-19-2014)
Old 03-04-2014, 01:10 PM   #4
Dipstik-sportech
Dipstik-sportech's Avatar
Brad Penn green oil that's all I will be using. It's designed for e85 and it's fairly cheap
The Frozen North
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Reaper (03-04-2014)
Old 03-04-2014, 01:15 PM   #5
taylork057
Drives: 2013
yep, just have to change your oil frequently. Also letting it warm up all the way helps a lot. Cold starts and shut offs are your worst enemy.
taylork057 is offline   Reply With Quote
The Following User Says Thank You to taylork057 For This Useful Post:
Gregorio3 (03-21-2021)
Old 03-04-2014, 01:49 PM   #6
Reaper
Reaper's Avatar
Drives: violent
@bluesubie thanks for that. I was worried no one with any knowledge was going to comment on this thread and I am very behind on oil knowledge. My comment on Motul 300v was because ive read some people dislike ester based oils with E85 but no one could tell me why. Seemed like internet BS. I was leaning towards rotella or TDT but i didnt realize it doesnt come in a weight that works with our clearances. Though interestingly the FA20DIT uses 5w-30 and subaru recomends using a higher weight oil in our fa20's when used under harsh conditions. So I think im leaning towards motul 8100 5w-30 (x-lite or x-cess? i need to understand tbn and calcium more to make a descision) but it's still costly. Can you think of anything else that might be more wallet friendly to change more often?
Old 03-04-2014, 02:05 PM   #7
Reaper
Reaper's Avatar
Drives: violent
@Dipstik-sportech
Brad penn specifically says DO NOT use e85 with their oils it will cause gumming
http://penngrade1.com/CMSFiles/File/..._BRAD_PENN.pdf
The Following 3 Users Say Thank You to Reaper For This Useful Post:
DinkinFlicka (08-08-2016), gonzo (12-21-2014), Sportsguy83 (03-19-2014)
Old 03-04-2014, 03:00 PM   #8
Dipstik-sportech
Hmmmm. Maybe I should tell my buddies that run it
The Frozen North
Old 03-04-2014, 03:19 PM   #9
bluesubie
Rotella does come in a semi-synthetic 10W-30, although that could still be too thick on stock internals.
Between those two Motul oils, X-Lite 0W-30 is a very thick 30 grade oil, with a high HTHS so it would act more like a 40 grade oil. It does have lots of calcium, but I wouldn't run it because it's thick. X-cess is only 5W-40. X-clean is a 5W-30 with lower phosphorus levels to be cat friendly, but it's also a thick oil. Eco-nergy is a thin 30 grade, but has slightly higher ZDDP levels since it meets the older API SL spec.
The more robust oils will be the ester based race oils (Dominator, 300V, and Red Line) and I would actually just reach out to the manufacturers to see what they say about E85.
Here's a Mobil1 0W-20 virgin oil analysis that shows the lower calcium levels and boosted levels of magnesium (like Rotella or M1 TDT):
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2243763
And here's a TDT voa (although it's from 2010):
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1939477
I'm really surprised that M1 recommends TDT in applications that call for 5W-20. I believe that some of their 20 and 30 grades were reformulated to include more magnesium when the oil switched to API SN and I do not know if that "Ask Mobil" question was before or after the reformulation.
I would probably go with 300V or Red Line 0W-20 unless you can find more evidence of problems running ester based oils with E85 (Red Line is very good at responding to emails). Or for a daily driver, I would probably just go with whatever 0W-20 or 5W-20 that is easily available (like Pennzoil Platinum or Ultra Platinum or Mobil1).
-Dennis
The Following User Says Thank You to bluesubie For This Useful Post:
arvidj (08-16-2014)
Old 03-04-2014, 05:14 PM   #10
Reaper
Reaper's Avatar
Drives: violent
Amsoil dominator comes in a 0w20 and isnt horribly expensive if bought at wholesale.
Old 03-04-2014, 05:45 PM   #11
bluesubie
Actually, 5W-20. Although, the only difference is that the cold cranking test on a 0W is performed at -35C and a 5W is performed at 30C.
http://www.amsoil.com/shop/by-produc...code=RD20QT-EA
It's a fairly thick 5W-20 at 8.9 cst's at 100C (30 grades start at 9.3) and it has an HTHS of 3.0 which is the same as many 30 grades. And regarding base stocks, most oils these days are a blend of 2-3 base stocks so I wouldn't get too hung up on that. There's a Tech Dept. phone number at the very bottom of Amsoil's web site if you want to give them a ring.
It also has more ZDDP than 300V or Red Line.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1247342
-Dennis
Old 03-04-2014, 06:15 PM   #12
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
so whats the best oil lol
I'm running 300v 5w-30
Old 03-04-2014, 06:29 PM   #13
bluesubie
There is no one best oil, IMO. Although I would switch to 300V 0W-20. The 5W-30 has a high HTHS and will behave like a 40 grade oil.
http://www.motul.com/system/product_...pdf?1339171623
I know there's a thread with a bunch of uoa's here, but I don't recall if there's one on E85.
-Dennis
Old 03-04-2014, 06:46 PM   #14
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
-Dennis
I heard 5w-30 is better for boosted cars
I love boost!!!!!!
WTB: UEL HEADERS! Non specific Asian Delight Engine, Exhaust, Bolt-Ons 1 02-07-2014 04:51 PM
Specific Vishnu OFT threads... Tromatic Software Tuning 6 12-07-2013 03:09 PM
Looking for a specific spoiler ... Need help finding it. pwnisher Cosmetic Modification (Interior/Exterior/Lighting) 8 07-10-2013 10:56 PM
Anyone know where to get FR-S specific key chains? mmieszanek Scion FR-S / Toyota 86 GT86 General Forum 4 02-26-2013 04:28 PM
Specific iso bdanisi Engine, Exhaust, Transmission 1 02-12-2013 09:31 PM
