Old 03-04-2014, 09:29 AM   #15
wparsons
wparsons's Avatar
Originally Posted by Victor Draken View Post
GREAT STUFF!
I still need to understand how to fix if slightly uphill and how to understand if the pull is done properly or not, will make few test soon.
For ppl like me where for ONE launch on the dyno they want around 100euro this program is a life saver
There's a few good threads on other sites with instructions on how to get GOOD logs for accurate Virtual Dyno charts. The long and short of it is that you NEED a good flat road as the starting point. The consensus on how to tell is to take a log in each direction and see how close they are.
flickr
Old 03-04-2014, 09:52 AM   #16
Victor Draken
Drives: Toyota Gt86
Originally Posted by wparsons View Post
Open the CSV in a proper text editor, not in excel/open office/etc.
like what?
I have used a text editor, I can't make it work to read past 5k rpm. It's getting annoying.
File Attached.
Have a look please.
@wparsons
Victor Draken is offline   Reply With Quote
Old 03-04-2014, 10:10 AM   #17
wparsons
wparsons's Avatar
Textpad, notepad, notepad++, etc.
flickr
Old 03-04-2014, 10:53 AM   #18
Victor Draken
Drives: Toyota Gt86
makes not much sense
Old 03-04-2014, 10:56 AM   #19
jamesm
i've run virtual dyno against a log i made while on an actual dyno, and the results were within 1hp. i'd say it's pretty damn accurate when done properly.
Old 03-04-2014, 11:32 AM   #20
wparsons
wparsons's Avatar
If the setup is done right, and the road is dead flat then you get REALLY good results.
If you're using it just for tuning purposes the road doesn't matter as much as long as you always do your pulls in the same direction. Your chart will be skewed from someone else, but it'll be accurate to past pulls/charts and it'll show you if you gained or lost power with whatever you changed.
@Victor Draken, I don't have virtual dyno here at work (or my working logs). I'll have a look tomorrow when I get home, not going straight home tonight.
flickr
Old 03-04-2014, 12:05 PM   #21
jamesm
i'm in florida, so it's pretty much all flat. i just put it in 3rd, stab the throttle wide open at 2.5k and run it out to redline. gives me nice repeatable results every time. pretty simple and effective really. great way to tell if what you're doing is helping or not, though i agree they're pretty much useless for comparison (then again, so it every dyno that isn't a dynojet).
Old 03-04-2014, 12:27 PM   #22
bfrank1972
Drives: 2013 FR-S Argento
If you're pulling in higher gears wind resistance will probably come into play, no?
Old 03-04-2014, 01:02 PM   #23
Victor Draken
Drives: Toyota Gt86
thanks man, appreciated.
Will wait for your response.
Old 03-04-2014, 07:46 PM   #24
jeebus
Is not properly working for me, Can't display past 5krpm
My dyno stop at 5,2k rpm. any suggestion?
Anyone can upload his csv file that works so I can compare with mine?
I think openoffice is fucking up the size of the column or somethingelse.
Any suggestion?
I was having the same issue. Not sure why it fixed it, but I deleted a few rows down low (every other row), probably deleted like 10 rows only then reloaded and it worked fine after that.
jeebus is offline   Reply With Quote
Old 03-04-2014, 07:56 PM   #25
Captain Insano
Cool functionality for the OFT logs!
Captain Insano is offline   Reply With Quote
Old 03-04-2014, 07:57 PM   #26
jeebus
here's mine. 3rd gear e85 vs 91 octane.
Old 03-04-2014, 09:14 PM   #27
Victor Draken
Drives: Toyota Gt86
can you post the log that work with it, so I can see it and compare with mine?
Old 03-05-2014, 01:15 AM   #28
DriftHappens
Drives: '14 FRS White
For anyone having the RPM stopping short issue, I found a fix. Change all of your throttle position values to 100. VD has an issue where it assumes non-WOT below a certain value (not sure what the value is or how to change that yet, im working on it). All of my TP values were hovering just above 90% above 4k or 5k rpm and it wasn't plotting those.
DriftHappens is offline   Reply With Quote
Data Logs! Post them here. feldy Software Tuning 2164 08-17-2026 10:43 PM
Anyone help interpreting data logs? cuddefred Engine, Exhaust, Transmission 8 10-11-2013 06:30 PM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
